720p, 1080i, 1080p and now 1440p? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 45 Old 10-17-2006, 08:34 PM - Thread Starter
jeffdbs's Avatar
I am now reading about 1440p television screens. http://www.cmo.com.tw/cmo/english/ab...20061016155822 Is this a new standard for future HDTV programming?
jeffdbs is offline
post #2 of 45 Old 10-17-2006, 08:45 PM
DaveFi's Avatar
Quoted: 73 Post(s)
Liked: 35
My CRT display can already display 2560 x 1440. No, it's not the future for HD. 1080i/720p broadcast, with 1080p for Disc Based (Blu-Ray/HD-DVD) will be the standard for a long time to come.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #3 of 45 Old 10-17-2006, 08:45 PM
ehren's Avatar
providers can't even supply us with decent 1080i, why do they keep coming out with more crap?
ehren is offline
post #4 of 45 Old 10-17-2006, 09:09 PM
JData's Avatar
To create the 'sky is falling" so you have to buy it.
~ IMHO ... of course.
As a consumer, I think the whole HD/Digital situation is a gimmick because no one is on the ball whatsoever. Growing pains my a$$! They probably predicted all the shortcomings and as usual, this is capitalism, politics, and marketing at its finest.
I think I rather read a book and screw all the broadcasters, manufacturers.
Sorry for the vent. But it's a never-ending cycle of the same BS.
JData is offline
post #5 of 45 Old 10-17-2006, 09:12 PM
djdrock's Avatar
No doubt! Who gives a crap about the next generation TV at this point in the ballgame? Well, uhh, I guess those that just want the "best" and the companies that make it all "happen."
My 2 year old 21+" 1600x1200 resolution computer monitor must be better then, right? I am so GD sick and tired of all of this. No wonder consumers are brainwashed and left for dead.
I will give my 2nd generation 50" Samsung DLP TV, that is finely tuned, the Pepsi challenge against a bunch of this "bigger and more is better" that the media, the AV salesguy, and the Sunday advertisements fill us with.
Bigger may not be better...look where that got John Holmes.
Aren't you gonna take your skates off?
djdrock is offline
post #6 of 45 Old 10-17-2006, 09:42 PM
necrolop's Avatar
Shhhh!! They are listening, dont say the B word here, they might come after us!
*Turns up volume of TV*
CROPPED < OAR < OPEN MATTE -- OOOOH I SAID IT!
necrolop is offline
post #7 of 45 Old 10-17-2006, 09:44 PM
cavalierlwt's Avatar
Quoted: 13 Post(s)
Liked: 24
At the risk of sounding stupid (a risk I take on a daily basis!) I wonder if they should have just pushed one standard: 1280x720p at the very beginning.
1080i strikes me as a half step, not the next step, which would be 1080p--something broadcasters simply aren't ready for.
It might have been easier for the TV manufacturers to concentrate on, same with the broadasters. Even the HD dvd setup seem like it should have just improved on existing tech just enough to maybe double capacity to 18 GB or so for a dual layer DVD, plenty for a movie encoded in MPEG-II along with some extras. Skip MPEG-4 for now.
cavalierlwt is offline
post #8 of 45 Old 10-17-2006, 11:41 PM
rogo's Avatar
Quoted: 1592 Post(s)
Liked: 1790
There is simply not going to be any 1440p programming broadcast, cablecast, satellitecast, or recorded on HD-DVD or BluRay. End of story.
There's a saying about "everything in moderation". If only it was applied to well, you know...
rogo is offline
post #9 of 45 Old 10-18-2006, 04:04 AM
sneals2000's Avatar
Quoted: 242 Post(s)
Liked: 127
Isn't that just an announcement about a new PANEL resolution, rather than a new broadcast format.
This is just another display resolution - jus as you have 1024x768, 1024x1024, 1280x720, 1366x768, 1920x1080 etc. TV display panels - plus things like 1280x800, 1680x1050 etc. for PC displays...
Presumably the advantage of this new resolution is that it allows reasonably simple scaling from 1280x720, but also has high enough vertical resolution to display a 1080p source as well, albeit scaled.
There ARE non-broadcast requirements - such as medical imaging, control room displays, even desktop editing in HD etc. that require resolutions greater than 1920x1080 - and such a display would be useful for this I guess.
(An area I work in has a projection system capable of approx 13000 x 900 - it takes 7 x 1080 line HD feeds and displays them all in a row - with a bit of cropping...)
I don't think anyone is suggesting that 1440p become a new production system - though of course NHK are continuing to develop their UHD system - which improves on 1080p as a production format.
(1080p IS used in the 24p/25p flavour as an origination and post production format, and with BluRay/HD-DVD it may also appear as a distribution format in native, rather than 3:2 or 2:2 pulldown flavours. However 1080/50p and 1080/60p are still very much in the experimental, rather than routine production format, camp)
sneals2000 is offline
post #10 of 45 Old 10-18-2006, 06:47 AM
Nmlobo's Avatar
1080i, properly deinterlaced and displayed on todays flat panel 1080p screens provides significantly more resolution than 720p. Your 'half step' comment would be valid to a crt which does display an interlaced picture (540 lines, another 540 lines etc). But todays flat panels are progressive and they display all 1080 lines at once. . . . first 540 lines are held in memory, weaved together with the next 540 lines and then all 1080 are displayed at once.
Nmlobo is offline
post #11 of 45 Old 10-18-2006, 08:32 AM
sneals2000's Avatar
Quoted: 242 Post(s)
Liked: 127
Though not all displays do a proper 1080i de-interlace on 60i sourced material - as of course you can't weave fields into a frame if the source is 60i native rather than 30p or 24p in a 60i sequence, as you would get combing on motion between fields 1 and 2.
(De-interlacing 1080/60i sourced material to 1080/60p is not trivial - and doing it well isn't cheap. De-interlacing 1080/30p and 1080/24p sourced material in a 60i sequence to 1080/60p - or 1080/72p for that matter, is much easier as you don't have to play the "Is it moving, or is it detail?" game)
post #12 of 45 Old 10-18-2006, 09:22 AM
mikelets456's Avatar
This is beginning to sound like digital cameras. Example, how many of us really need 9 mega pixels? I mean come on...I have a 4.0 mega pixel Canon and have it set for 2.1 MP. For 5X7 and even 8.5 X 11 prints it's adequate, plus easier to email....heck, monitors can't even display these resolutions. it's only good if you want to Zoom in 35X or print a 48" x 72" poster....which I have never done and probably won't.
This "more pixels" the better isn't always the case.
Same with these TV's. A 42" display at 1080P vs 720P may not make a huge enoughdifference to merit the difference in cost, let alone 2160P as mentioned in the article. At some point it's not going to make that much difference in 47" and smaller displays..IMHO.
Acts 17:27
"His purpose in all of this was that the nations would seek after GOD and perhaps feel their way toward him and find him-though he is not far from any of us"
Yamaha Drum kit....
mikelets456 is offline
post #13 of 45 Old 10-18-2006, 09:56 AM
sneals2000's Avatar
Quoted: 242 Post(s)
Liked: 127
Yep - and how many people realise that display pixel counts and TV pixel counts can't usually be directly compared with digital stills camera pixel counts?
Most digital stills cameras have a single sensor with a (usually Bayessian) array of coloured filters over their sensors (often 2 green for every single red and blue) - but they count each red, green and blue sensor as a separate pixel. Most displays and TV cameras would treat an RGB triplet as a single pixel... Therefore to compare "TV" and "Display" pixels with "Digital Stills" megapixels you really need to multiple the former by 3 in many cases...
Indeed - and for a fixed sensor size, the more pixels, the smaller each "pixel" is, the less light it can collect, and thus the result is often noisier, or the sensitivity is reduced, requiring longer shutter speeds.
Research suggests that at AVERAGE VIEWING DISTANCE - you don't see the benefit of 720p over 576i (not 480i) until you get to screen sizes over 28", and that you don't see the benefit of 1080p over 720p until you get to 50". Where 1080i fits, and what happens when you are sitting closer than the average viewing distance is different.
post #14 of 45 Old 10-18-2006, 10:20 AM
scowl's Avatar
Quoted: 122 Post(s)
Liked: 39
And every field is weaved with the previous alternate field and immediately displayed giving you 60 fps.
My cable box just does simple bob deinterlacing and it still looks better than 720p.
NOW: my post on AVS Forum.
NEXT: someone else's post on AVS Forum.
scowl is offline
post #15 of 45 Old 10-18-2006, 10:31 AM
scowl's Avatar
Quoted: 122 Post(s)
Liked: 39
Let me propose a silly conspiricy theory (you can do that on the Internet, can't you?).
When 2009 comes around, TV stations won't want to give up their analog channel, so they'll come up with another long long long term plan to use it to broadcast... VHDTV. How about 1440p, 2048i, MPEG-4, lossless sound compression, and enough subchannels to make it look bad. Should be on the air by 2016. The future of American television depends on it... the Japanese are experimenting with stuff like that right now!
scowl is offline
post #16 of 45 Old 10-18-2006, 04:20 PM
Quoted: 13 Post(s)
Liked: 24
Out of curiosity, since they weave the frames together after storing one field in memory--in effect giving us progressive frames? 30 per second?? why go through the trouble of interlacing in the first place? If nothing is lost/gained, why not just flat out go with 1920x1080p@30fps? I have a tough time wrapping my head around 1080i not being a compromise of some sort. I'm told they use approximately the same bandwidth, so more bandwidth+more resolution? Something has to give.
Then again I haven't figured out the drive for 60 fps. I figured 48 would be a better goal, 48 fps for sports, and just frame doubling for 24fps movies. I'm sure there's a good reason, it's just one of the many things to learn about all this still.
post #17 of 45 Old 10-18-2006, 04:25 PM
Quoted: 13 Post(s)
Liked: 24
It's tough to see the incentive for a broadcaster to invest in HD right now, this year. If it made them more money within a year or two, they would probably be jumping through hoops to get to HD. Push comes to shove, they know content is still king, that we'd still watch a great show in SD before watching a horrible show in HD.
post #18 of 45 Old 10-18-2006, 04:31 PM
spwace's Avatar
Quoted: 29 Post(s)
Liked: 46
They do it just to agitate the conspiracy theorists on the AVS forum.
spwace is online now
post #19 of 45 Old 10-18-2006, 04:55 PM
sneals2000's Avatar
Quoted: 242 Post(s)
Liked: 127
If weave-only is used then you aren't really de-interlacing. Sure this will work with material that starts life as 24p (if you 3:2 remove) or 30p, however 60i originated material (sports etc.) where there is motion between the two fields in each frame, will need a more sophisticated algorithm, or at least a switch to bob on a dynamic basis...
post #20 of 45 Old 10-18-2006, 05:07 PM
sneals2000's Avatar
Quoted: 242 Post(s)
Liked: 127
Weaving is only an effectively de-interlacing algorithm for material that started off as 24p or 30p (and is just being carried within a 60i signal), where the information in two (or some cases three) fields is from the same point in time. This is true of much HD drama.
It isn't true of 60i native video origination - like sport. In this case 60 images are captured each second, and each field is derived from a separate point in time. You therefore can't merge the two 60i fields to create a 60p frame, as there will be motion between the two fields, and you will get combing.
1. Because 60i video delivers 60 separate images (fields) taken at 60 different points in time, giving fluid motion. What it doesn't do is delivery full vertical resolution on moving objects, because the two fields are offset by a frame-line vertically.
2. Because HD video standards, even HD, pre-date LCD and Plasma, and are designed for display on monitors without framestores, so have to have a refresh rate a lot higher than 30Hz. The 60i interlacing solves this refresh rate problem, but by interlacing 1080/60i, rather than running 540/60p, you get significant spatial resolution improvements in the analogue domain.
Because not everything is shot 1080/30p (in fact not much is)
1080/60i is used for sports and entertainment shows - with the fluid motion that 60i native capture delivers - you have to remember that 60i can carry 60 different images per second, not the 30 images that some people assume. You have to remember that the two fields in an interlaced frame don't have to come from the same picture taken at the same point in time.
(One crude way of thinking about 60i origination is to imagine a 1080/60p camera shooting the image, but only outputting alternate lines for one frame, and then the outputting the other lines for the next frame. In reality some more processing is done than this to avoid flicker)
Similarly if you only broadcast 30p - you'd have problems showing 24p source material - like almost all drama and movies. 24p converts neatly to 60i by showing one 24p frame for 3 60i fields, but the next for only 2. If you tried this trick at the frame rate you'd have far more juddery repetition.
You have to remember that the 1080/60i standard is over 30 years old in heritage...
Interlacing is a compromise - but one we've been working with since 1936 at least (when the BBC launched their 405/50i interlaced system - which ran until 1985 over here!)
You have to stop thinking of 60i interlaced systems just in terms of 30 frames per second, and think more of 60 fields per second.
What interlacing does is trade-off resolution for motion.
1080/60i signals can deliver high vertical resolution (not 1080 lines but more than 540 lines ) on static and slow moving images, (where the full vertical detail can be built up across two fields, with little movement between them), but not on fast moving images (where there is a lot of movement between fields), where it drops to closer to a 540/60p system.
However 1080/60i delivers twice as many images per second as 1080/30p, so delivers more fluid motion when using a 1080/60i source.
Effectively interlacing allows you to have some of the benefits of 1080/30p (vertical resolution) and some of the benefits of 540/60p (fluid motion) in the same system, however it does so at the expense of complexity of decoding.
1080/60i, 1080/30p and 540/60p are all effectively systems with the same line rate and thus the same bandwith.
In an ideal world, of course, we'd use 1080/60p - but this requires twice the bandwith of the above three formats.
720/60p is, of course, in use, but it manages to operate a 60p system only by reducing the horizontal and vertical resolution to reduce the bandwith.
Well in Europe we have 1080/50i (most) and 720/50p (not much) and shoot drama and film at 25p. We show 24p material as 25p and live with the speed change.
However 50Hz and even-more-so 48Hz refresh rates are much more noticably flickery than 60Hz displays, particularly in peripheral vision (i.e. the corner of your eye) In the 50Hz world many TVs double the refresh rate to 100Hz to combat this, but the processing required to do this is not good for picture quality.
Some have suggested running at 72Hz or 75Hz (allowing you to frame triple film, and capture fluid motion at even higher frame rates) - however the bandwith required for such an increase in production frame/field rates probably precludes it. (It would also not be a great format for display of existing 50i and 60i material)
post #21 of 45 Old 10-19-2006, 06:24 AM
netconcepts's Avatar
Convergence, its all about convergence. The higher the capability of the screen, the more things you can connect to it. Not just HDTV, but XBox 360 that does HD, Media Server Computers, the list is ever growing. The stuff that broadcasters put up will only diminish if they continue to forcefeed a substandard product (HDLite and Multicasting of OTA). As other media keeps improving (Computer Media Servers, HD Games) there will be a market for the higher quality displays in ever larger formats.
netconcepts is offline
post #22 of 45 Old 10-19-2006, 08:42 AM
sneals2000's Avatar
Quoted: 242 Post(s)
Liked: 127
Yep - the providers of HD content also have to find a way of delivering this material in a format that can be easily displayed. They need to find a way of opening up their closed systems (Cablecard is the nearest so far I guess) to allow material to be recorded and displayed, whilst ensuring their DRM requirements are still met...
post #23 of 45 Old 10-19-2006, 12:02 PM
scowl's Avatar
Quoted: 122 Post(s)
Liked: 39
I'm using a deinterlacing plugin somebody named "weave" that selectively "weaves" fields together where it finds motion to display them at 60 fps. It sounds like this isn't using the industry-standard weave algorithm.
scowl is offline
post #24 of 45 Old 10-19-2006, 02:41 PM
rantanamo's Avatar
tiny market
rantanamo is offline
post #25 of 45 Old 10-20-2006, 04:10 AM
sneals2000's Avatar
Quoted: 242 Post(s)
Liked: 127
I guess it selectively weaves when it DOESN'T find motion (i.e. where the two fields will merge without combing and give a higher resolution result), and when it DOES find motion it uses some other method, like bob (where the fields are effectively replicated across both frame lines in the resulting progressive frame - giving motion from only one field, but also reduced vertical resolution)
The best de-interlacers work on a block by block, or pixel by pixel basis, and use motion tracking algorithms to try and retain as much resolution as possible on moving objects. However they are highly processor intensive.
post #26 of 45 Old 10-20-2006, 11:25 AM
Originally Posted by rantanamo View Post
tiny market
Yes, But it is a fast growing market as these teens+ grow up and begin buying for themselves. I already see it today with 20 year olds buying for their gaming habits. These are the ones standing in line for the next XBox or PS3 and they have the money.
post #27 of 45 Old 10-21-2006, 04:35 PM
Quoted: 13 Post(s)
Liked: 24
Sneals2000, thanks for the reply, I just got around to reading it. Whew, that is a lot of info, I'll have to try and piece it all together. It's amazing how much technology is involved in things most of us take for granted in everyday usuage!
post #28 of 45 Old 03-04-2007, 01:22 PM
bittman's Avatar
I have been searching for a comparison between 1080/60i and 1080/30p for several hours now and can't find a definitive source.
1. Is one better than the other in terms of picture quality (e.g., 1080/60i better for motion)?
2. Are they identical aside from how the information is stored/delivered (interlaced vs. progressive)?
3. For recording, (e.g., with a Panasonic HVX200) are the file sizes identical? ...or is one more compact?
4. Aside from the questions above, is there any reason for shooting in one format vs. the other?
It's amazing how poorly this topic is documented -- even in the camera manuals. Any insight would be greatly appreciated.
bittman is offline
post #29 of 45 Old 03-05-2007, 08:35 AM
John Mason's Avatar
Quoted: 76 Post(s)
Liked: 103
1080/30p, used to capture (not deliver) some ad material, is slightly better than standard 24p because it provides somewhat more fluid motion. Since 30p is a full frame it avoids all the long-cited artifacts of interlaced capture (480/60i or 1080/60i for the U.S.). Went into some aspects of interlace vs. progressive capture in an earlier post and greater detail here .
No, interlace capture 'snaps' the second of two TV fields 1/60-sec later in time, as discussed above. My 64" CRT RPTV displays everything upscaled to 1080/60i, while fixed-pixel displays (full progressive) must deinterlace the two fields into one frame. One of the key advantages of interlace is saving (halving) bandwidth requirements. 720/60p requires about the same bandwidth as 1080/60i (30i) because it's delivering full frames, not 540-line half-frames) each 1/60-sec, although 720p can undergo higher compression because the 1/60-sec-spaced full frames are more similar to each other and the spatial resolution of 720p is half that of 1080i. -- John
John Mason is offline
post #30 of 45 Old 03-05-2007, 09:29 AM
bfdtv's Avatar
Great explanations by sneals above. Should be required reading for all members in the display forums.
I think the references to 1080p30 are mostly academic. I am not aware of any high-definition content on broadcast or cable acquired in 1080p30. Everything I have seen is either 1080p24 or 1080i60 sourced.
Virtually all high-definition movies and episodic programming shown on on CBS, NBC, TNT, and HBO is 1080p24 sourced. Specific examples include CSI on CBS and Heroes on NBC.
Note you won't get the original 1080p image on your screen unless your display correctly performs inverse telecine. Most older (and many newer) displays do not.
bfdtv is offline
Reply HDTV Technical
