Directv Channels - Which Satellite/Transponder? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 10-28-2006, 04:16 PM - Thread Starter
hockeynut's Avatar
Quoted: 66 Post(s)
Liked: 47
Can someone point me to the list that contains all of Directv channels and which satellite and transponder that they go to.
I know it is out there somewhere. I can't seem to find it using the "search" function.
I had to relocate my AT9 dish and having trouble with a couple of channels. That is one heavy sucker by the way.
Thanks in advance.
Mike
Mike
xbox/psn: duke63031
hockeynut is offline
post #2 of 11 Old 10-28-2006, 05:24 PM
AntAltMike's Avatar
Quoted: 129 Post(s)
Liked: 62
A link to DirecTV's 101 degree satellite transponder list can be found on DBSForums's home page and is updated daily.
http://www.dbsforums.com/tx_map.html
There is also the Scott Seligman map that shows which Satellite A beams are pointed at which markets. http://www.scottandmichelle.net/scott/dtv.html
And I think someone posting under the name timf produced this old table: DirecTV Locals Spot Beam Information: Listing by Channel Number, but I don't think DirecTV spot beam assignments change much, other than in instances when DirecTV is forced to carry more stations in a market than they can fit into one beam.
Greg Bimson posted which locals were on which DirecTV Satelliite B spotbeam in this thread, DirecTV 7S - the map!.
AntAltMike is offline
post #3 of 11 Old 10-28-2006, 06:18 PM - Thread Starter
hockeynut's Avatar
Quoted: 66 Post(s)
Liked: 47
That's great info AntAltMike. Thank you very much.
The channel I am having with right now is TNT HD, which may be located on Sat 110. It is breaking up very bad. Any other info on the other Satellites 110 and 119?
Mike
xbox/psn: duke63031
post #4 of 11 Old 10-28-2006, 06:29 PM - Thread Starter
hockeynut's Avatar
Quoted: 66 Post(s)
Liked: 47
Well, to possibly pinpoint my problem, it seems my problem with the 110 satellite is limited to transponder number 8. I am pulling in 70s for transponders 10 and 12. Perhaps reaming the dish will not help for this.
Mike
xbox/psn: duke63031
post #5 of 11 Old 10-28-2006, 07:43 PM
AntAltMike's Avatar
Quoted: 129 Post(s)
Liked: 62
Here is an old (Jan 4, 2005) list of HD programming on Sats B (119) and C(110) from WidescreenMovies
B Tr 22: 86 ABC East, 89 Fox West
B Tr 24: 87 ABC West, 88 Fox East
B Tr. 28: 72 ESPN2, 79 HDN, 97 DTV
C Tr. 8: 75 TNTH, 94-98 DTV, 99 PPV, 724 NFL, 726 NFL
C Tr. 10: 78 HDNM, 509 HBO, 543 SHO
C Tr 12: 73 ESPN, 74 UHD
post #6 of 11 Old 10-28-2006, 08:33 PM - Thread Starter
hockeynut's Avatar
Quoted: 66 Post(s)
Liked: 47
Thanks again. I will be sure to print this info.
That would explain my problem with TNTHD. I am pulling in a signal reading of 0-30 on transponder 8 on Sat C.
Since I am already pulling in 70 readings for transponders 10 and 12, I am correct in assuming that reaming the dish will not help? Is this a problem with my receiver? I have an H20.
Mike
xbox/psn: duke63031
post #7 of 11 Old 10-29-2006, 01:52 AM
SRIBB43's Avatar
i;m getting and error message on my at9 during satellite setup saying that only 4 of the 5 satellites are hookup. anyone got a message like this
SRIBB43 is offline
post #8 of 11 Old 10-29-2006, 04:52 AM
dsanbo's Avatar
SRIBB43......
A while back this "error" message showed up if the LILs on the 99 degree transponder weren't active in a particular area (the "fix" was/is to hit "IGNORE/DON'T FIX").....Not familiar with the Dallas DMA....Are your LILs on 99?
dsanbo is offline
post #9 of 11 Old 10-29-2006, 10:24 AM - Thread Starter
hockeynut's Avatar
Quoted: 66 Post(s)
Liked: 47
I think I got this error message when setting up as well. I just selected ignore. I think my LILs are on Sat 101.
Mike
xbox/psn: duke63031
post #10 of 11 Old 10-29-2006, 10:24 AM - Thread Starter
hockeynut's Avatar
Quoted: 66 Post(s)
Liked: 47
By the way my reading on transponder 8 is now back to reading in the 70s. Must be a problem with Directv.
Mike
xbox/psn: duke63031
post #11 of 11 Old 10-29-2006, 01:15 PM
Super Moderator
DrDon's Avatar
Quoted: 869 Post(s)
Liked: 1727
More likely you have something getting ready to fail, such as a combiner, or some moisture in your line or just a bad connection between the Sat C LNB and the combiner. If yours is a newer dish (no external combiner), then it's time to check the positioning or look for obstructions.
There are other factors which can afffect Sat C reception that are specific to areas on the edge of its footprint.
Doc
Walking the fine line between jaw-dropping and a plain ol' yawn.
DrDon is offline
Closed Thread HDTV Technical
