RF Connectors and LCD HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-31-2006, 05:01 PM - Thread Starter
ste4en's Avatar
I am looking to upscale/upgrade my 24" WEGA TV to an LCD panel. I have basic analog cable from a wall socket and want connect an antenna for OTA HD transmissions. So I will require two RF Input connectors, I can't find and LCD panels with more than one connector - if there is one with 2, was how easy is it to jump over from one source to the other. If not would I have to have some sort of switching device to select the RF source.
Is anyone else doing this, any suggestions.
thanks
ste4en is offline
post #2 of 4 Old 10-31-2006, 05:08 PM - Thread Starter
ste4en's Avatar
Well I just found a TV with 2 Rf inputs - did not look at the Samsungs because of the glossy black suround. LN-S4095D
So how easy is is to switch between the two sources or does that depend on the TV?
ste4en is offline
post #3 of 4 Old 11-01-2006, 07:00 AM
bcrissman's Avatar
On my Samsung DLP you just hit the 'Source' button and it switches the sources....pretty straight forward
bcrissman is offline
post #4 of 4 Old 11-01-2006, 07:28 AM
mjones73's Avatar
You'd be better off asking TV specific questions in the proper forum.
http://www.avsforum.com/avs-vb/forumdisplay.php?f=40
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
Closed Thread HDTV Technical
