Pls help with poor OTA reception with a 4228 antenna - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 11-16-2006, 12:48 AM - Thread Starter
aus
aus's Avatar
Location: Seal Beach, which is right next to Long Beach (90740).
My home is about 20 feet down from the homes behind me.
I can only get 2,4,5 vis a 4228 antenna. 7 almost comes in, but then the HD-TiVO box say's no signal. I have pretty long runs of from the antenna.
I was wondering if I should try an pre-amp, and which one is recommended and where could I get one.
Or should I look into a directional antenna? antennaweb say's the distance is only 32 miles.
And could someone explain what the colors mean on antennaweb and how I'm suppose to pick an antenna based on the color?
aus is offline
post #2 of 16 Old 11-16-2006, 04:28 AM
jeffloby's Avatar
Here is your antennaweb results. Many channel at 348 degrees and I would guess they are at the same tower farm based on mileage to the tower.
DTV Antenna
Type Call Sign Channel Network City State Live
Date Compass
Orientation Miles
From Frequency
Assignment
* yellow - uhf KJLA-DT 57.1 IND VENTURA CA 348° 32.4 49
yellow - uhf KCET 28 PBS LOS ANGELES CA 349° 32.2 28
* yellow - uhf KCET-DT 28.1 PBS LOS ANGELES CA 349° 32.2 59
* yellow - uhf KFTR-DT 46.1 TFA ONTARIO CA 348° 32.4 29
yellow - uhf KAZA 54 AZA AVALON CA 348° 32.3 54
* yellow - uhf KAZA-DT 54.1 AZA AVALON CA TBD 348° 32.4 47
* yellow - uhf KCOP-DT 13.1 MNT LOS ANGELES CA 348° 32.5 66
yellow - uhf KLCS 58 PBS LOS ANGELES CA 349° 32.2 58
* yellow - uhf KPXN-DT 30.1 i SAN BERNARDINO CA 349° 31.4 38
yellow - uhf KRCA 62 IND RIVERSIDE CA 349° 31.5 62
* yellow - uhf KRCA-DT 62.1 IND RIVERSIDE CA 349° 31.5 68
yellow - uhf KXLA 44 IND RANCHO PALOS VERDES CA 348° 32.4 44
yellow - uhf KTBN 40 TBN SANTA ANA CA 349° 32.2 40
* yellow - uhf KTBN-DT 23.1 TBN SANTA ANA CA 349° 32.2 23
* yellow - uhf KTLA-DT 5.1 CW LOS ANGELES CA 348° 32.4 31
* yellow - uhf KTTV-DT 11.1 FOX LOS ANGELES CA 349° 32.2 65
yellow - uhf KMEX 34 UNI LOS ANGELES CA 348° 32.3 34
* yellow - uhf KMEX-DT 34.1 UNI LOS ANGELES CA 348° 32.4 35
* yellow - uhf KCBS-DT 2.1 CBS LOS ANGELES CA 348° 32.7 60
yellow - uhf KOCE 50 PBS HUNTINGTON BEACH CA 348° 32.3 50
* yellow - uhf KOCE-DT 50.1 PBS HUNTINGTON BEACH CA 348° 32.4 48
yellow - uhf KDOC 56 IND ANAHEIM CA 348° 32.4 56
* yellow - uhf KDOC-DT 56.1 IND ANAHEIM CA 348° 32.4 32
* yellow - uhf KCAL-DT 9.1 IND LOS ANGELES CA 348° 32.4 43
* yellow - uhf KABC-DT 7.1 ABC LOS ANGELES CA 348° 32.4 53
green - vhf KCBS 2 CBS LOS ANGELES CA 348° 32.7 2
green - vhf KABC 7 ABC LOS ANGELES CA 348° 32.4 7
green - vhf KTTV 11 FOX LOS ANGELES CA 349° 32.2 11
green - uhf KPXN 30 i SAN BERNARDINO CA 23° 37.0 30
green - vhf KCAL 9 IND LOS ANGELES CA 348° 32.4 9
green - uhf KWHY 22 IND LOS ANGELES CA 348° 32.4 22
green - vhf KTLA 5 CW LOS ANGELES CA 348° 32.4 5
green - uhf KSCI 18 IND LONG BEACH CA 349° 31.4 18
green - uhf KVEA 52 TEL CORONA CA 349° 31.4 52
* green - uhf KVEA-DT 39 TEL CORONA CA TBD 349° 31.5 39
* green - uhf KLCS-DT 58.1 PBS LOS ANGELES CA 349° 32.2 41
green - uhf KFTR 46 TFA LOS ANGELES CA 348° 32.4 46
green - vhf KNBC 4 NBC LOS ANGELES CA 349° 32.3 4
* green - uhf KNBC-DT 4.1 NBC LOS ANGELES CA 349° 32.3 36
green - vhf KCOP 13 MNT LOS ANGELES CA 348° 32.5 13
lt green - uhf KSMV-LP 33 IND SIMI VALLEY CA 348° 32.4 33
* red - uhf KSCI-DT 18.1 IND LONG BEACH CA 349° 31.5 61
* red - uhf KXLA-DT 44.1 IND RANCHO PALOS VERDES CA 348° 32.4 51
* red - uhf KWHY-DT 22.1 IND LOS ANGELES CA 348° 32.4 42
blue - uhf KUSI 51 IND SAN DIEGO CA 124° 98.9 51
blue - uhf KNSD 39 NBC SAN DIEGO CA 124° 98.9 39
blue - uhf KPBS 15 PBS SAN DIEGO CA 124° 98.9 15
blue - uhf KVCR 24 PBS SAN BERNARDINO CA 59° 48.1 24
* blue - uhf KVCR-DT 26.1 PBS SAN BERNARDINO CA 59° 48.1 26
Note:
I would try a Winegard HDP-269 preamp. Additionally try to get as much height as possible with your antenna
jeffloby is offline
post #3 of 16 Old 11-16-2006, 06:32 AM
mjones73's Avatar
All your digital stations are UHF and in the same direction, no need for a multi directional antenna...
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
post #4 of 16 Old 11-16-2006, 07:53 AM
shelby68gt500's Avatar
Aus, I believe your best bet is to get your antenna a bit higher. It doesn't take much of a location or height adjustment to make a difference sometimes. You have one of the best antennas, so don't believe that is your issue. If your cable run to your TV or STB is more than about 50ft, then I would use a preamp. The Channel Master 7775 (UHF Only) or 7777 (VHF/UHF) preamps are pretty much the standard and I use them myself. I used to live out in Simi Valley and could pickup all of the LA stations from behind the Santa Suzanna's with a 4228 and 7775 from about 40 miles or so from Mt. Wilson. Try moving the physical location of the antenna a foot or so at a time along with getting it higher, possibly also slightly tilting it up. Any or all of these should give you some change in reception, hopefully better! Bob
shelby68gt500 is offline
post #5 of 16 Old 11-16-2006, 08:13 AM - Thread Starter
aus
aus's Avatar
Thanks for the feeback guys. I think the house behind me is blocking my signal, but why some channels and not others?
Also, where's a good place to get these pre-amp? THanks again.
aus is offline
post #6 of 16 Old 11-16-2006, 10:00 PM - Thread Starter
aus
aus's Avatar
Rick, thanks for that info. The channels I really want are 7.1(ABC) and 11.1 (Fox) and they're both yellow. I get 2.1, 4.1, and 5.1 OK.
What if my runs are a little more than 100 ft since it goes from the ceiling to the "can" and then to the TV's. Is the HDP269 still the one to get? How do you get "signal overload?"
aus is offline
post #7 of 16 Old 11-17-2006, 03:23 AM
jtbell's Avatar
Are you on the slope or at the foot of a steep hill or bluff that drops down to sea level? If so, I can easily imagine that the earth may be seriously impeding your line of sight. That kind of location is effectively in a deep "shadow" for TV signals. Any signals you're getting would have to diffract around the top of the hill. Maybe aiming the antenna upward towards the top of the hill would help in this case.
jtbell is offline
post #8 of 16 Old 11-17-2006, 11:12 PM - Thread Starter
aus
aus's Avatar
I'm definitely on the bottom half of our complex with a row of houses above us. We're not at sea level, but this was one concern I had when getting this house. I'll try the tilting of the antenna up a little with a pre-amp. Unfortuantely, raising it much more would draw more attention and the damn home owner's association may give me trouble.
aus is offline
post #9 of 16 Old 11-18-2006, 07:26 AM
mjones73's Avatar
Your HOA can't legally stop you from putting up an antenna, FCC law prevents them from doing so.
http://www.fcc.gov/mb/facts/otard.html
Matt
mjones73 is offline
post #10 of 16 Old 11-20-2006, 12:11 AM - Thread Starter
aus
aus's Avatar
Thanks for the link. I'm not sure how this HOA will be, but the last one were pretty worthless and enforced rules randomly.
aus is offline
post #11 of 16 Old 11-20-2006, 08:30 PM
gtspm10000's Avatar
I'll second the recommendation for a preamp- I'm 27 miles from Mt. Wilson, and the CM7777 is the difference between an intermitten signal and perfect reception. And this is with a 4228 mounted only 10' off the ground without LOS.
gtspm10000 is offline
post #12 of 16 Old 11-21-2006, 12:00 AM - Thread Starter
aus
aus's Avatar
Do you have to plug in these pre-amps to an outlet?
aus is offline
post #13 of 16 Old 11-21-2006, 03:11 AM
NightHawk's Avatar
The pre-amps come in two sections. One is the amplifier which gets mounted outside close to the antenna and the other piece is the power supply. The power supply is intended to be placed indoors close to the receiver and plugs into an outlet. The two sections are connected by a single coax cable used to send the signal down from the amplifier and DC power back up to it from the power supply.
NightHawk is offline
post #14 of 16 Old 11-21-2006, 06:41 AM
DougRuss's Avatar
Looks like this:
http://www.solidsignal.com/tech_help_CM777X.asp
Yamaha RX-V479
Cambridge Audio " Azur-650c
Rega RP-1 Turntable
YAQIN MS-12B Pre-amp
GemTune BL-02 EL34*2 Hi-end Tube Amplifier
Monitor "Bronze 5" Speakers
DougRuss is offline
post #15 of 16 Old 11-21-2006, 10:39 PM - Thread Starter
aus
aus's Avatar
Got it. Thanks. I just didn't want to have to run a power wire up to the antenna. If it's all in the coax, that's easy to do.
aus is offline
post #16 of 16 Old 01-18-2007, 09:51 PM - Thread Starter
aus
aus's Avatar
Got the Winegard installed and it works perfectly on my TV's close to the antenna and pretty far from the antenna.
Thanks Rick for the suggestion.
aus is offline
Reply HDTV Technical
