DVI-D Male to VGA hd15 Female Adapter...? Where can I find one? - AVS Forum | Home Theater Discussions And Reviews
Old 12-18-2006, 07:07 PM - Thread Starter
LegolElf's Avatar
Does anyone know where I can find a DVI-D male to VGA hd15 female adapter?
I ordered one online, and it turned out to not work. My DVI connection on my tv is the 25 pin, (3 rows of 8 and the straight part) and I have the Xbox 360 VGA cable which is a 15 pin cable.
I can't find one that will do this online anywhere. I thought about running to my local Wal-Mart or Best Buy but I seriously doubt I will find one. Do they not make this type of adapter? I am seeing all types of others, but nothing that is 25pin DVI to 15pin VGA.
Any help from anyone would be greatly appreciated. Thanks for the help!
LegolElf is offline
Old 12-18-2006, 08:26 PM
cavu's Avatar
No such thing! DVI-D is digital and VGA is analog.
A DVI-A (analog) OR DVI-I (both analog and digital) to VGA would work as long as your DVI device supports analog.
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
Old 12-19-2006, 01:00 AM
fullcourt81's Avatar
monoprice.com , a AVS forum sponsor
fullcourt81 is offline
Old 12-19-2006, 06:40 AM
mjones73's Avatar
Just use the component connections from the Xbox, unless your set has a VGA in, you can't use the VGA cable.
As pointed out, VGA is analog and DVI-D is digital, to convert from VGA to DVI-D you would need something like this - http://www.ramelectronics.net/html/D...er.html#vgadvi
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
