Antenna Combination Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-21-2006, 08:31 AM - Thread Starter
pduncan's Avatar
I currently have a CM4228 and 7777 amp. Since one of my HD signals is Ch 9 (WISH out of Indianapolis), I get a lot of breakup, so I purchased a Channel Master 3671, which I haven't hooked up yet.
I am right in the middle between Louisville and Indianapolis. What I was thinking about doing is Pointing the 3671 towards Indianapolis and the 4228 toward Louisville. Have them on the same mast, but about 5' apart.
Now for the questions:
1. What is the best way to combine two antennas like this? Would a splitter/combiner work to join the two. ((The 7777 had two inputs, one for VHF only and one for UHF/Combo. So that won't work. ))
2. Is Five feet enough of a separation. This will be on a 30' tower so I think it will be strong enough to handle the weight.
3. Is this a dumb thing to do?
Pretty much only use this for HD, so ghosting due to two antennas pointing in opposite directions isn't really and issue (I don't think), but I understand it probably would be for Analog.
So what say the experts?
Cry Havoc and Let Loose the Dogs of War.
pduncan is offline
post #2 of 4 Old 01-10-2007, 09:37 AM
INDYSOUTH's Avatar
You should be okay with the antennas that close. I saw a pix of another setup with three antenns (UHF) and they were all within 5' of one another on the same mast.
I belive a combiner will work but I think keeping the cable lengths the same and as short as possible is important.
Maybe you can help me. I want to install an over the air antenna but not sure if I can pull in the Indy stations. I live in Springville IN and about 75 mile away. Can you give your approx. location or distance from Indy broadcast towers?
Larry
INDYSOUTH is offline
post #3 of 4 Old 01-10-2007, 06:55 PM
RTracey's Avatar
Quoted: 33 Post(s)
Didn't you already post this question in another thread?
RTracey is offline
post #4 of 4 Old 01-10-2007, 10:12 PM
kriscad's Avatar
are they outside or in your attic?
kriscad is offline
Reply HDTV Technical
