DirecTV HD Channels gone? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 53 Old 12-21-2006, 04:47 PM - Thread Starter
bob142's Avatar
Anyone else having problems with DirecTV's HD channels? I get "Searching for satellite" message on 73, 75, 95, and most if not all of the other HD channels. I'm wondering if it's my setup or if it is a central problem.
bob142 is offline
post #2 of 53 Old 12-21-2006, 04:49 PM
HDTVFanAtic's Avatar
I was watching the news on KABC 10 minutes ago.
HDTVFanAtic is offline
post #3 of 53 Old 12-21-2006, 04:51 PM - Thread Starter
bob142's Avatar
I was watching ch. 95 10 minutes ago, then flipped the channel to something else and by the time I got back the HD channels were gone.
bob142 is offline
post #4 of 53 Old 12-21-2006, 05:08 PM
mx6bfast's Avatar
Have you reset your reciever?
Grit N Grind
Glory Glory Man United
Go Cubs Go
mx6bfast is offline
post #5 of 53 Old 12-21-2006, 05:13 PM
mgtr's Avatar
All working fine in Florida.
Anything worth doing, is worth doing to excess.
mgtr is offline
post #6 of 53 Old 12-21-2006, 05:23 PM
did you pay your bill?
post #7 of 53 Old 12-21-2006, 05:30 PM
StuDBaker's Avatar
If you don't pay your bill wouldn't all the channels disappear? Or does D* know that one is an HDTV Fanatic and torture that person by only making HD channels disappear?
StuDBaker is offline
post #8 of 53 Old 12-21-2006, 06:03 PM
rbmcgee's Avatar
I just reported a very similar issue on this thread.
http://www.avsforum.com/avs-vb/showthread.php?t=772944
Bob
rbmcgee is offline
post #9 of 53 Old 12-21-2006, 06:54 PM
bgipson's Avatar
I live Upstate NY and I'm having the same problem. I've had a technician out three times to fix the problem. The last time, it said searching for signal on satellite 2 and then fixed itself while the tech was changing channels. What is going on?
bgipson is offline
post #10 of 53 Old 12-21-2006, 07:03 PM
wrightwing's Avatar
perhaps they compressed them so much, they disappeared!
wrightwing is offline
post #11 of 53 Old 12-21-2006, 07:19 PM
Wouldn't know....I never go to triple digit channels on D*....only use it for LA and NY local Newscasts.
post #12 of 53 Old 12-21-2006, 09:08 PM
Jeff Whitford's Avatar
Now thats funny.
Jeff Whitford is offline
post #13 of 53 Old 12-22-2006, 12:18 AM
Xylon's Avatar
Xylon is offline
post #14 of 53 Old 12-22-2006, 06:35 AM
carltonrice's Avatar
Quoted: 39 Post(s)
I've been having a similar problem for a couple of months now with my HR10-250. It is intermittent so when they came out to look at it, everything was fine. I've also been seeing a lot of reboots in the system, so I'm getting more and more convinced that maybe the box is failing.
carltonrice is offline
post #15 of 53 Old 12-22-2006, 07:20 AM
Wolfie's Avatar
Quoted: 21 Post(s)
I used to get that, but mine was because of a bad combiner module on the dish. Switched it out and all is fine now. Only get it periodically now because of weather.
Wolfie
Wolfie is offline
post #16 of 53 Old 12-22-2006, 08:19 AM
mbarloewen's Avatar
I had a similar problem that affected 70,71,72,75,76,77,78,95.
The issue was either a bad lnb on the dish or a bad multiswitch. An installer came out and replaced both and the problem was solved.
Perhaps that is your issue.
Mike
mbarloewen is offline
post #17 of 53 Old 12-22-2006, 11:53 AM
keeper's Avatar
Quoted: 298 Post(s)
Liked: 112
Could be that Rupy is moving some channels around - getting ready to add the 100 by Christmas he promised.
keeper is online now
post #18 of 53 Old 12-22-2006, 01:00 PM
Marcus Carr's Avatar
Quoted: 67 Post(s)
Liked: 119
I don't think "Rupy" gives a crap at this point.
YOU ARE READING AVS FORUM
Marcus Carr is online now
post #19 of 53 Old 12-22-2006, 02:37 PM
taz291819's Avatar
Quoted: 88 Post(s)
Liked: 63
Had the same problem in the past, the built-in multiswitch in the LNB was bad.
Vizio P65-C1 (2016)
Onkyo Tx-NR656
JBL Studio Series (Front, Center, Right), JBL 250W Sub, Kenwood Rears, Onkyo Atmos Upfiring
LG UP970 UHD Player
Nvidia Shield TV
taz291819 is offline
post #20 of 53 Old 12-22-2006, 06:19 PM
DwntwnWS's Avatar
The same thing just happened to me tonight. The local channels were OK, but not the rest of HD channels. Luckily resetting the receiver corrected the issue. I have new HR20 and slimline dish.
DwntwnWS is offline
post #21 of 53 Old 12-23-2006, 11:36 AM
Ken H's Avatar
I've been having this issue on and off for about 3 weeks. Using LG LSS3200A.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #22 of 53 Old 12-23-2006, 01:27 PM
Ken H's Avatar
http://www.avsforum.com/avs-vb/showthread.php?t=757494
Ken H is offline
post #23 of 53 Old 12-23-2006, 11:52 PM
digital_b_avs's Avatar
why ask this question here instead of asking directv?
digital_b_avs is offline
post #24 of 53 Old 12-24-2006, 09:00 AM
Digger16309's Avatar
Have you ever talked with D* customer service in India? It's a nightmare.
Anytime I have a programming issue, I look and/or post here first to see if it's just me, regional, or system-wide. If the problem does not correct itself, and if I'm not alone, I can call D*, ask for a Level II Tech, then reference the thread.
This is particularly helpful when problem arise with Sunday Ticket, or other HD aspects of the sports subscriptions.
Digger16309 is offline
post #25 of 53 Old 12-27-2006, 08:11 AM
opie168's Avatar
I've had this problem for a bit also. My issue is that ALL my channels work fine HDTV and non-hd but ESPNH never comes in and I have the searching for sattellite signal. I think its chann3l 73.
opie168 is offline
post #26 of 53 Old 12-27-2006, 11:27 AM
Tcole6414's Avatar
I've been having similar problems for the last couple of weeks. HD channels drop pixelize and then drop out and I get a "channel not purchased" message.
Problems persist with only light rain or fog. Now that the sky is clear, everything works.
Tcole6414 is offline
post #27 of 53 Old 12-29-2006, 07:22 AM
lokar's Avatar
Quoted: 43 Post(s)
Liked: 30
I had a similar problem with an H20 and disconnected the Ka-filter and just plugged the satellite dish straight into the H20. Didn't affect me much since there is no MPEG 4 in my area, I then called D* and they sent me a replacement filter within a couple of days.
lokar is offline
post #28 of 53 Old 12-30-2006, 10:04 AM
HDGreg's Avatar
This issue is effecting me also....Have had to reset my HDDVR three times in the last two weeks.......talk about a SLOW reset.......ZZZZZzzzzzzzzzzzzzzzzz..."almost there!" Calling D* is my last option always
Life is short, don't wait...do it today!
HDGreg is offline
post #29 of 53 Old 12-30-2006, 11:00 AM
Ken H's Avatar
Because here, we solve problems.
Ken H is offline
post #30 of 53 Old 12-30-2006, 11:02 AM
Ken H's Avatar
The latest from me:
It happened again last Sunday (lost a number of HD channels), just after NFL ST was finished. By later that night everything was back to normal.
Ken H is offline
Reply HDTV Technical
