Toshiba HD problem with Time Warner Moto box - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-28-2006, 09:15 PM - Thread Starter
brentimai's Avatar
I have a Toshiba TN50x81 Cinema Series HD TV. When I send the output of the Time Warner Motorola box (BMC9012) to the TV via the component cables, the picture will not appear in the letterbox when the output setting is 1080i (fills the 4x3 picture).
I was sure I could get this to work properly about a year ago.
I'm trying to get a 1080i output to show up as a 16x9 image.
Has anyone experienced this problem?
Thanks for your help
brentimai is offline
post #2 of 5 Old 12-29-2006, 08:02 AM
mjones73's Avatar
Is this problem on all HD channels or just channels showing SD programming at the time?
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
post #3 of 5 Old 01-03-2007, 11:51 AM - Thread Starter
brentimai's Avatar
Thanks for the question.
It happens on channels that are broadcasting in HD. When the channel is broadcasting a SD show, it appears as stretched virtically with bars on the left and right side.
post #4 of 5 Old 01-05-2007, 09:13 PM
Buk
Buk's Avatar
Greetings,
I've recently installed a 6416 and hooked it both to my receiver via optical and to the TV via HDMI. In both cases I need to turn up the volume to hear the TV show, but when the commercials come on I'am nearly blown out of the room and have to hit the mute button or drop the audio level.
I've tried adjusting the dynamic range in the receiver and the TV has a setting called StableSound, but neither seem to overcome this annoyance.
Is there something buried in a menu on the 6416 somewhere that would help level out the audio?
Buk
Buk is offline
post #5 of 5 Old 01-06-2007, 01:14 PM
mjones73's Avatar
Greetings, no, nothing you can do about the sound levels.
Please start a new thread when your question doesn't pertain to a current existing one also, thanks.
Matt
mjones73 is offline
Reply HDTV Technical
