How to hook up a HDTV, HD cable box, DVD, and surround sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-29-2006, 09:18 AM - Thread Starter
Bill Brasky's Avatar
The cable company installed an HD cable box and TV for me and all they hooked up was a coax cable from the wall to the cable box and component video and audio cables out from the cable box to the TV. They said that is all I needed.
Since then, I got a HDMI/DVI cable and analogue audio RCA cables to connect out from the cable box to the tv. But, when I select the HDMI source on the TV I get video, but don't get audio. What is the problem there?
Also, the cable box's instructions say to connect a splitter from the main coax cable and connect a cable to both the cable box and the tv. Do I need to do this?
The TV is a either a Panasonic CT-30WC15 or CT-30WX15. The cable box is a Motorala DVR/HDTV tuner.
I also just purchased a Sony Wega 970 that I need to hook up in a similar way.
Thank you.
Bill Brasky is offline
post #2 of 7 Old 12-29-2006, 09:25 AM
biker19's Avatar
Quoted: 23 Post(s)
For a CRT TV you're probably better off staying with the component connection you already had. The connection will be the same on the Sony. Save the HDMI input of the TV for future peripherals - like a DVD player.
The reason for the splitter and direct connection of the coax to the TV is to be able to tune/record something on the DVR and watch something else on the TV. In that case you'd use the TV's built in tuner instead of the one in the DVR. For clear QAM chs (or even analog ones) you might get better PQ using such a direct connection. If you don't plan to do this, then the splitter and extra coax are not needed.
biker19 is offline
post #3 of 7 Old 01-03-2007, 03:19 AM
HD dahl's Avatar
I'm no expert, but I think you might try an optical cable like this one: http://www.monoprice.com/products/pr...ormat=2&style=
Let us know if/when you have audio.
I have a similar problem.
My cable box only has DVI out (but I have heard Time Warner has a HDMI box) and I want to hook it up to my XBR3, but the audio will go to my HTIB. I hope it will be ok, I plan to use an optical cable.
HD dahl is offline
post #4 of 7 Old 01-03-2007, 09:38 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
Optical cable from you cable box to you A/V reciever, that's all you need. The A/V reciever will provide the sound and the TV will provide the picture.
joed32 is offline
post #5 of 7 Old 06-26-2008, 06:53 AM
airman1st's Avatar
My new ln46a550 arrives today. I have a comcast standard cable box. Do I need TO GET a HDTV cable box?
airman1st is offline
post #6 of 7 Old 06-26-2008, 08:46 AM
jtbell's Avatar
And a "ln46a550" is (hi ho, off to Google I go...) a Samsung 46" LCD HDTV. According to the specs on Samsung's web site, it has a "clear QAM" tuner. Therefore, if you plug your cable directly into it (no cable box), you should be able to get whatever digital channels (including HD) Comcast does not encrypt in your area. This probably means only the local broadcast channels (NBC, ABC, etc.). For other HD channels, you'll need Comcast's HD box, and you may have to subscribe to an HD tier.
jtbell is offline
post #7 of 7 Old 06-26-2008, 08:51 AM
mjones73's Avatar
Try the local reception area for a thread for your area to see what other Comcast users are getting via QAM.
http://www.avsforum.com/avs-vb/forumdisplay.php?f=45
As jtbell pointed out, if you want any premium HD channels, you'll need to upgrade with Comcast.
Welcome by the way, please feel free to open new threads vs digging up old ones if you can't find anything current that pertains to your question. Enjoy the new TV.
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
Reply HDTV Technical
