How to receive broadcast Hd channels without a built in tuner - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-03-2007, 09:24 PM - Thread Starter
pacer121's Avatar
I have an older hdtv that does not have a built in tuner. I do not want cable or dish I just want to receive hd channels with my antenna. What type of equipment do I need and where would I find it. Thank You.
pacer121 is offline
post #2 of 3 Old 01-03-2007, 09:33 PM
jtbell's Avatar
See http://www.avsforum.com/avs-vb/showthread.php?t=179095 which is a sticky thread at the top of this forum. Start with the section "Over the air DTV/HDTV".
The new Samsung DTB-H260F has been getting mostly favorable reviews, and Circuit City carries it, if you can find a store that has stock on hand. There's a long thread about it in this forum which you should be able to find easily.
jtbell is offline
post #3 of 3 Old 01-04-2007, 09:51 AM - Thread Starter
pacer121's Avatar
I'll check it out. thanks
pacer121 is offline
Reply HDTV Technical
