Need QAM tuner, need advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-04-2007, 06:35 PM - Thread Starter
viks's Avatar
My TV does not have QAM tuner.
I DO have basic cable from comcast, I am using OTA for HD now.
But I would like to use cable for local HD channels.
I understand that I need QAM tuner for that.
Is there any QAM tuner available for this purpose.
I was looking in forum about this.
I saw few like samsung SIR-TS360 , MOTOROLA DCT6412 etc.
Are they only for Direct TV, DISH Network ??
Please help me out here.
viks is offline
post #2 of 3 Old 01-04-2007, 07:17 PM
jtbell's Avatar
See the list at
http://www.avsforum.com/avs-vb/showthread.php?t=179095
Scroll down to the section "Over the air DTV/HDTV" and pay attention to the entries marked "QAM in the clear". Those units are capable of both ATSC (OTA) and QAM (cable) reception.
jtbell is offline
post #3 of 3 Old 01-04-2007, 08:20 PM
dr0s's Avatar
Don't spend the money until you are sure your cable provider is broadcasting HD in clear QAM. I can only get one this way, use OTA for most. - DRb
dr0s is offline
Reply HDTV Technical
