Help in South Central Kansas - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-25-2007, 12:05 PM - Thread Starter
pete424's Avatar
Hi,
I have been lurking on this board for several months and I have to admit that I have learned a great deal about TV and satellites etc. This is a terrific resource. My new Mits 65732 is in route, the Dish installer is scheduled in as well. I am dropping my COX cable due to the poor HDTV selection. My locals are not available in High Def over the sat and I need some assistance choosing an OTA antenna. Here are the Antenna references. Any help would be appreciated. I can go attic or roof top. This is Kansas so trees and tall buildings are not a major concern. I was looking at the Winegard SS2000 because it can be attached directly to the satellite dish. Will it work?
red - uhf KSCW 33 CW WICHITA KS 286° 24.2 33
* red - uhf KSCW-DT 33.1 CW WICHITA KS 286° 23.8 31
red - vhf KSNW 3 NBC WICHITA KS 283° 22.9 3
* red - uhf KSNW-DT 3.1 NBC WICHITA KS 282° 22.7 45
red - uhf KSAS 24 FOX WICHITA KS 283° 22.6 24
* red - uhf KSAS-DT 24.1 FOX WICHITA KS 283° 22.6 26
red - uhf KMTW 36 MNT HUTCHINSON KS 302° 30.3 36
red - vhf KAKE 10 ABC WICHITA KS 283° 23.1 10
* red - uhf KAKE-DT 10.1 ABC WICHITA KS 283° 23.1 21
blue - uhf K59DA 59 TBN WICHITA KS 273° 11.1 59
blue - uhf KFVT-LP 40 IND WICHITA KS 282° 12.1 40
blue - vhf KWCH 12 CBS HUTCHINSON KS 302° 44.1 12
* blue - uhf KWCH-DT 12.1 CBS HUTCHINSON KS 302° 44.1 19
blue - vhf KCTU-LP 5 i WICHITA KS 273° 11.1 5
violet - vhf KPTS 8 PBS HUTCHINSON KS 301° 44.4 8
pete424 is offline
post #2 of 3 Old 01-25-2007, 12:13 PM
DarinA's Avatar
Hey, always glad to see some fellow Kansans join AVS..... I still use Cox for HD so I am not sure what antenna to recommend to you, however check out this link...
http://www.avsforum.com/avs-vb/showthread.php?t=131977
It will take you to the Wichita Ks, OTA HD Forum.. there is lots of good info, and I believe that some people have given reviews of OTA Antennas..
Let me know how you like satellite, I have been toying with the idea of dumping Cox and going to dish... I will be interested to see what you think...
DarinA is offline
post #3 of 3 Old 01-25-2007, 03:23 PM
mikemikeb's Avatar
The SS2000 is absolute JUNK. At that distance, you should attic mount a Channel Master 3016, and point it toward Wichita. It's available from solidsignal.com for $29.
Use the balun kit included with the antenna and run some RG-6 to the HDTV. You can get some good RG-6 cable from RadioShack, Lowe's, or Home Depot. You might need only a 25-foot run, maybe longer (up to 50 feet).
mikemikeb is offline
Reply HDTV Technical
