H20-100 Why No Hdmi To Panasonic Ax100 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-06-2007, 10:09 PM - Thread Starter
You can's Avatar
Problem: AX100 new out of the box today. Connected to H20-100, will not hold the HDMI connection for more than 1 second.
Context: 2 perfectly performing H20 boxes exist. One is connected to a 720p Panasonic LCD the other to a Sharp 720 lcd. NO problems.
I have tried Both boxes individually connected to the new AX100 with 6ft hdmi cables (currently successfully in use). "input select"request via remote cycles thru various options and when it selects "HDMI", it flickers then grabs the station for 1 second then returns to blue screen. No amount of teasing thru cycles makes any difference.
However, When the AX100 is fed HDMI from a DVD source, (Panasonic S97S) it plays the source immediately. Again, as i stated, the H20-100's are both playing other HDMI LCDs faultlessly.
The confirmed problem appears to be the Hand shake and hold done by the AX100. Yes, tried the, "which gets turned on first " trick--no luck.
Any ideas before I send it back? Thank you.
Robert---
Knowledge is always tentative and incomplete.
You can is offline
post #2 of 3 Old 02-06-2007, 10:45 PM
greywolf's Avatar
Location: Evanston IL 60202 11 mi from Chicago transmitters
The H20-100 has a handshake problem with TVs using the MStar HDMI chipset. Samsung and LG are other problem brands. A software patch is being investigated but it's been a while.
Pat
While I may link to and mention products as examples, I don't recommend specific products.
greywolf is offline
post #3 of 3 Old 02-07-2007, 08:34 AM - Thread Starter
You can's Avatar
Thank you for your reply. Is ANYONE connected successfully and reliably via HDMI cable from their H20-100 STB to their Panasonic PT-AX100u??
Robert---
You can is offline
Reply HDTV Technical
