Motorola cable box - what's the USB port for? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-25-2007, 10:18 AM - Thread Starter
somezack's Avatar
I just got a new Motorola non-DVR HD cable box yesterday (DCT6200?). It has a USB 1.1 port on the front panel. What use is this port?
somezack is offline
post #2 of 4 Old 03-25-2007, 10:22 AM
bfdtv's Avatar
bfdtv is offline
post #3 of 4 Old 03-25-2007, 01:06 PM - Thread Starter
somezack's Avatar
Damn! I was hoping you were going to say "you can hook up an external USB drive and magically turn it into a DVR since the remote has DVR controls on it"
Ah well... maybe I'll use it to charge my iPod.
somezack is offline
post #4 of 4 Old 03-25-2007, 03:57 PM
vegggas's Avatar
Works great as an Ipod charger, or USB light in a rack.
It's actual original purpose is for a USB keyboard to use with the built in web browser. As far as I know, no cable company has licensed the MSN-TV type of browser it uses, so it's a wasted port. On SA units, you can add a remote IR reciever to the USB to hide your cable box in a cabinet and just leave the IR sensor out.
vegggas
vegggas is offline
Reply HDTV Technical
