TV Fool Discussion Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 12-02-2009, 01:27 PM
otaguy's Avatar
Originally Posted by andy.s.lee View Post
WELL-LD is marked as "CP OFF" (construction permit granted, but off air) in the FCC database, so it was being ignored by the system. We've put in a fix for this and we're using their 10 kW construction permit data for now. If anyone has any more specifics about the transmitter, please let us know.
Thanks Andy! They are definitely on the air but not at full power yet. My equipment can lock on it only intermittently with lots of dropouts. In response to a question, an engineer working for the station emailed me and said they are having a filter problem but hope to be at full power soon.
otaguy is offline
Old 12-10-2009, 10:51 AM
Trip in VA's Avatar
Quoted: 554 Post(s)
Liked: 147
Send a message via AIM to Trip in VA
Andy:
I've got a friend who wants to know if it would be possible to get data from a signal analysis in text form instead of image form. He's working on a program to determine what frequency would be best to use for his wireless mics without interfering with any TV stations, and he would like to pull in your analysis.
Just passing it along. =)
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
Old 12-12-2009, 01:40 AM
coyoteaz's Avatar
Looks like there's some confusion between WHBF's full-power channel 4 broadcast and the low-power channel 47. The listing for 4 is missing from the locator and online map. 47 has the right text in the box when selected on the online map, but the overlay looks to be for 4.
coyoteaz is offline
Old 12-12-2009, 02:42 AM - Thread Starter
andy.s.lee's Avatar
If the channel 47 LD transmitter on the air too? Or is it just channel 4?
andy.s.lee is offline
Old 12-12-2009, 08:09 AM
Trip in VA's Avatar
Quoted: 554 Post(s)
Liked: 147
As far as I know, both are on the air.
- Trip
N4MJC
RabbitEars
Old 12-12-2009, 09:24 AM
coyoteaz's Avatar
Both.
coyoteaz is offline
Old 02-03-2010, 05:28 PM
TV Fringe Viewer's Avatar
When making a coverage map using SPLAT how do you figure the Set dB threshold to plot?
TV Fringe Viewer is offline
Old 02-03-2010, 05:45 PM
b1gmoose's Avatar
I just got this in my email. It is very depressing that a company is charging for information made freely available via sites like tvfool.com.
Hopefully, they are doing the data collection / analysis on their own and not stealing it from tvfool.com and selling it for $35!
http://skyvision.com/store/mi6500005.html
b1gmoose is offline
Old 02-03-2010, 07:55 PM - Thread Starter
andy.s.lee's Avatar
We don't use Splat. We wrote our own software to do propagation modeling. Since I'm not familiar with the program (never actually tried it), I have no idea what that parameter does in Splat. Sorry.
You might want to ask Trip in VA. He runs rabbitears.info and uses Splat to generate coverage maps for his site.
Best regards,
Andy
Old 02-03-2010, 08:28 PM
Old 02-16-2010, 11:19 AM
powerfactor's Avatar
Hi -
First post here. Thanks for the great forum and thread.
I need some help solving an OTA riddle.
I'm located on a hill in suburbia, 15 miles S.E. of the Sutro Tower broadcasting site in San Francisco. The top of that tower is >1800'; I am at 630'. There are some trees around, and there is a 1000' hill halfway between the tower and here, but nothing that should greatly attenuate the signals. I reckon it as pretty much line-of-sight conditions.
TVFOOL predicts -27 dBm signals at my house. I should be able to get a signal with a wet noodle, no?
But I get pretty rocky reception on most channels.
So I dragged a spectrum analyzer off the lab bench and hooked it up to my antenna (a Wineguard 7080p 10 feet above the roofline).
UHF signals measure in the range of -60 to -70 dBm. That is maybe 40 dB below expectation (net of antenna gain, cable loss, etc.)
I tried another antenna/feedline in the same location and got consistent results.
I have yet to try moving the antenna site. But is it likely that slightly perturbing the location will change such a deep null in the signals?
If you have any thoughts or suggestions, I'd love to hear them.
powerfactor is offline
Old 02-16-2010, 03:32 PM
GeekGirl's Avatar
Welcome to AVS forum! My thinking is that you are experiencing multipath. I'm on the East coast and not familiar with the area, but a 1000' "hill" may have some say in the matter.
Before you move the location: In addition to pointing in azimuth (horizontal), you might try pointing in elevation (up/down). It would be interesting to see if you can find a peak that's not line-of-sight.
I'd also take a guess at some diffraction from the hill if it's in the path to the tower.
GeekGirl is offline
Old 02-16-2010, 04:26 PM
coyoteaz's Avatar
FYI, the online map for WHBF's channel 4 transmitter is currently wrong. Selecting the channel 4 transmitter brings up the channel 47 overlay.
coyoteaz is offline
Old 02-16-2010, 05:33 PM
Tower Guy's Avatar
The nulls in the vertical pattern of your receive antenna are probably less than 20 db. Changing the height a few feet may gain somewhat, but not 40 db worth.
Do the VHF stations have the same weak signal?
Is there a building in the way?
One poster found a bad balun caused a problem of your magnitude.
Tower Guy is offline
Old 02-16-2010, 06:27 PM
Thanks for the balun tip I'll take down the yagi and check it out.
VHF stations are about 20 dB stronger; that's still less than predicted but enough for solid reception.
There are no buildings in the way, just a few trees.
I'll try playing with the elevation angle, as GeekGirl suggested.
Thanks for the suggestions.
Old 03-09-2010, 12:44 PM
gmd1's Avatar
Why is WNMN sticking to channel 40? They're limiting their reach up North because of CHOT in Hull (QC).
People in Ottawa can get WCFE-DT, and would be able to get WNMN as well if it was using another channel. Come on, pick a number!
-gmd
gmd1 is offline
Old 03-09-2010, 03:10 PM
BCF68's Avatar
I still like to know why TvFool doesn't provide Google Earth maps of the Paducah, KY area
BCF68 is offline
Old 03-15-2010, 11:03 AM
Yes that is a very good question?
Market: Paducah, KY-Cape Girardeau, MO-Harrisburg-MT Vernon, IL
When will these Google Earth Maps be Available?
____________________________________________________________ _____
Local TV Reception and Dxing from Thayer, MO and The OZARKS
Everybody can view my blog that wants to!!! Check out my polls and please VOTE if you like!
Old 03-18-2010, 11:15 AM
tvlurker's Avatar
-gmd
WMNM can barely cover Saranac lake. They're only using 12 kW or so right now.
If you follow their FCC submissions, you can see that they've been plagued by Murphy's Law from the start.
In their current incarnation, I think WMNM only exists as a nominal full-power station to feed their network of translators around Vermont and to get cable carriage.
Even if they moved to channel 44, and they didn't have to protect channel 40 here in Ottawa, I doubt we would get it. WCFE is much more favourably located than WMNM, onw on a short tower in Saranac Lake rather than in Tupper Lake.
tvlurker is offline
Old 04-05-2010, 10:29 AM - Thread Starter
andy.s.lee's Avatar
OK. Consider it done for the next batch of updates.
Best regards,
Andy
Old 04-06-2010, 05:10 AM
raj2001's Avatar
Anyone know if the NYC coverage includes the applications when the freedom tower is (eventually) built? My TVFool seems way off:
http://www.tvfool.com/?option=com_wr...b7c86cef718c65
For example, my strongest NYC station on UHF (I'm talking about those that are in Manhattan proper) appears to be WNBC and WCBS. Fox WNYW and WWOR are the weakest. That's not what the signal analysis says.
Great tool otherwise though. I've recommended it to many of my friends!
Ryan, N2RJ
Opinions expressed are solely my own, and not that of my employers, its parent company, affiliates and subsidiaries.
raj2001 is offline
Old 05-21-2010, 08:03 PM
BCF68's Avatar
Best regards,
Andy
When are the next updates? You guys haven't updated in 6 months.
BCF68 is offline
Old 06-04-2010, 07:21 PM - Thread Starter
andy.s.lee's Avatar
The latest Google Earth coverage maps were just posted. For the complete list, look here.
Best regards,
Andy
Old 06-05-2010, 08:36 AM
JimboG's Avatar
Best regards,
Andy
Sweet! Once again, thank you Andy for all your hard work! TV Fool and FM Fool are indispensible tools.
Free over the air HDTV + Tivo HD + Netflix for Blu-ray and streaming = Bliss
JimboG is offline
