Can I use two antennas with a splitter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-30-2007, 09:09 PM - Thread Starter
jester805's Avatar
I have the Channel Master 3021 four-bay bowtie antenna. I can only pick up two of four HD OTA channels. If I move the antenna, I can pick up new channels, but then lose some others.
I'm wondering if I can use two antennas with a Y-splitter?? Point one antenna in one direction and the other antenna in another direction.
Any help would be great!
jester805 is offline
post #2 of 11 Old 04-30-2007, 09:33 PM
WillieAntenna's Avatar
You have come to right place. If you post your Zip code so some of member could see what you can get and also state what channel you get at one spot and what channel you loose and gain at the other spot, also state where your antenna is at in the attic, on the roof or indoor do and do you have rotor and pre-amp state those also. You will get quicker response with all the info.
-Willie
WillieAntenna is offline
post #3 of 11 Old 04-30-2007, 11:48 PM
plumeria's Avatar
It is worth a shot and may or may not work. I use a splitter backwards and add an attenuator to one antenna (6dB from Radio Shack) - works great...
If this does not work you may want to purchase a Jointenna. Here is a good link on combining signals from two antennas.
http://www.tvantenna.com/support/tut...combining.html
peter
plumeria is offline
post #4 of 11 Old 05-01-2007, 07:40 AM
m_vanmeter's Avatar
usually there is about a 3db loss when you join two antennas with a splitter and they point in different directions. But, as the previous poster mentioned, try it......it just might work
m_vanmeter is offline
post #5 of 11 Old 05-01-2007, 07:48 AM
ToddUGA's Avatar
Quoted: 36 Post(s)
Liked: 29
You could also use a rotor.
ToddUGA is offline
post #6 of 11 Old 05-01-2007, 05:51 PM - Thread Starter
jester805's Avatar
-Willie
Thanks for the greeting. My zip code is 61554. The stations I currently get are CBC & NBC. I don't care about getting ABC, but the one I cannot get is FOX. I do not have a rotor nor do I want one because I like to setup the DVR to record different channels at different dates & times. I have Dish network and I pay for locals. It would be not if I didn't have to pay for them, but right now I cannot tune in all of my locals.
post #7 of 11 Old 05-03-2007, 07:03 AM
jester805, I see Rick0725 has look up your zip code and the antennaweb result and I agree what Rick has suggested. If you got any more question on the setup I would ask Rick as he works with the jointenna and muti-antenna setup more than I do.
-Willie
post #8 of 11 Old 05-03-2007, 08:31 PM - Thread Starter
jester805's Avatar
Originally Posted by Rick0725 View Post
* yellow - uhf WEEK-DT 25.1 NBC PEORIA IL 45° 6.1 57
* blue - uhf WYZZ-DT 43.1 FOX BLOOMINGTON IL 77° 24.2 28
suggest to combine the two antennas with a cm jointenna for ch 28
-aim one antenna directly to fox ch 28 and connect this antenna to the ch 28 input of jointenna
-aim the other antenna at about 40 degrees and connect to the "all channel" input of the jointenna
-the "to tv" output of the jointenna to the tv.
purchase the jointenna here...special order takes about 3 weeks. looks like picture. cm 0585-1 ch 28
the jointenna might attenuate ch 30 alittle but do not be concerned. that station is yellow.
http://www.warrenelectronics.com/ant...Jointennas.htm
Do you think I should get the Jointenna and another Channel Master 3021?? Or should I go with a different antenna for my second one??
I get confused with all the different styles & models of antennas out there.
Also, why is WYZZ called channel 28? It's actually channel 43-1 on my TV.
post #9 of 11 Old 05-04-2007, 04:33 PM - Thread Starter
jester805's Avatar
Is channel 28 the frequency??
post #10 of 11 Old 05-04-2007, 06:40 PM
WYZZ-DT 43.1 is a digital channel and it really transmitt on channel 28 but it is remapped as Channel 43.1, as Analog channel is on 43 now.
Understand ?
-Willie
post #11 of 11 Old 02-16-2009, 09:21 PM
internetuser's Avatar
For details of why this will sometimes work, search google for hdtvprimer merging feedlines.
internetuser is offline
Reply HDTV Technical
