DISH Net remote code for OLEVIA TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-10-2007, 11:35 AM - Thread Starter
K6PH's Avatar
Does anyone have a DISH Net remote control code for operating OLEVIA HDTVs?
.......... Ed,
K6PH is offline
post #2 of 5 Old 07-10-2007, 01:31 PM
Scooper's Avatar
I would say you're probably going to be out of luck on that one. Probably will need something like a Harmony if you want a 1 remote solution.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #3 of 5 Old 07-11-2007, 07:49 PM
johnwcookjr's Avatar
I contacted Dish tech support last week on this same issue, the Olevia codes aren't current'y supported.
Building our dream theater one component at a time.. Thanks AVS for years of great advice and support!
Come visit The Pit
http://members.cox.net/home-theater/
johnwcookjr is offline
post #4 of 5 Old 07-16-2007, 08:26 AM - Thread Starter
K6PH's Avatar
By the way, the code to punch into the Olevia remote to operate the Dish Net receiver is 3030.............. Ed
K6PH is offline
post #5 of 5 Old 08-20-2007, 10:37 AM
IhateBestBuy's Avatar
Anyone got the code the dish network remote on olevia tvs?? Would rather use the dish one than the olevia one....
also just in case...how did you put the code on the olevia remote??
IhateBestBuy is offline
Reply HDTV Technical
