5 lnb question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-03-2007, 05:21 AM - Thread Starter
HDnut05's Avatar
I just upgraded to the 5 lnb dish. I was wondering can I connect a hddvr,hd reciever, and a sd reciever to the 5 lnb dish without using a mutiswitch? If so which outputs do I use to connect each reciever? Does it even matter which ones I use? Also I can delete the sd reciever if that helps.
HDnut05 is offline
post #2 of 3 Old 10-03-2007, 06:27 AM
arxaw's Avatar
You can connect 4 coax leads to the 4 terminals of the 5LNB dish, without adding any other hardware. You can connect all the equipment you listed. Mixed SD + HD equipment is fine. The SD equipment just won't see the extra LNBs.
2-tuner DVRs need 2 coaxes - 1 for each tuner.
Each non-DVR receiver requires 1 coax.
arxaw is offline
post #3 of 3 Old 10-03-2007, 02:54 PM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
Any of the available 4 output connections from the 5 LNB dish can be connected to any of your receiver's satellite inputs.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
Reply HDTV Technical
