Function of the FM trap, UHF/VHF combine,UHF separate on CM-7777 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-12-2007, 09:22 PM - Thread Starter
dukkha2's Avatar
Hi everybody,
Please forgive my ignorance
I'm a newbie. I search this forum on the question in the title but I can't find it.
My zip code is 27527. I currently has a CM-4308 antenna gave it to me by the local TV station. I add CM-7777 to it. Put it up 4 days ago.
I have no idea what is the function of the FM-trap and the Combine UHF/VHF port or the VHF separate port on the CM-7777. I just leave the preamp "as is" and connect the TV to the Combine port.
1) Any guiding and explanation of these ports is greatly appreciated.
I want to get UHF channel only through the OTA antenna to get HD. We currently has basic Directv package so it provides enough channel for our need but we can not afford tp subscibe their HD and we don't want to.
2) What should I do to get more HD channel ?
Thanks for your help
dukkha2 is offline
post #2 of 3 Old 10-12-2007, 09:49 PM
Rick0725's Avatar
you are 8 mies from towers
the cm 4308 is a uhf LD antenna.
You got it. but the cm7777 is not the appropriate preamp...too much gain for yellow and 8 miles .
the winegard hdp 269 would be a better alternative if a preamp is necessary.
Rick0725 is offline
post #3 of 3 Old 10-12-2007, 11:42 PM
jtbell's Avatar
You are very close to your local transmitters so you should not need a pre-amp. Have you tried the antenna without the pre-amp?
The FM radio band is in the middle of the VHF TV band, in fact it's very close to TV channel 6. If you have FM transmitters nearby, they can cause problems with nearby VHF TV channels, or overload the pre-amp and cause problems on other channels. I don't have any FM stations nearby so I have my FM trap set to "off".
If you have separate antennas for VHF and UHF then you would set the switch inside the unit appropriately and connect them to the separate inputs. For a single combination VHF/UHF antenna you leave the unit set "as is" and connect the antenna to the "combined" port.
More than what? Based on your ZIP code you should be able to receive at least the local ABC, CBS, NBC, FOX, CW and MNT (MyNetworkTV) stations. Your PBS station (WUNC) surely also has a digital channel with some HD programming, but for some reason it doesn't appear in Antennaweb's default list. That's all you can expect to receive over the air. For other HD channels you have to pay for HD cable or satellite service.
jtbell is offline
Reply HDTV Technical
