MIT MDP-130DVI Problem When Switching From HD Mode - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-26-2007, 10:16 PM - Thread Starter
rick761953's Avatar
Sometimes when I switch from hd mode to windowed mode on my PC with Viewsonic 22" flat panel monitor I get a bunch of green lines across the entire screen. If I switch back and forth a few times it fixes it. Anybody else have this happen or know of a fix? Using the MDP-130 DVI daughter card. Think I got a bum card? Thanks a ton in advance.
rick761953 is offline
Reply HDTV Technical
