speaker hum from verizon FiOS HD box - hdmi related)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 11-29-2007, 10:03 AM - Thread Starter
elbarto1's Avatar
Hello all,
I just had verizon FiOS installed the other day and i am noticing a low level (ungrounded?) hum coming through my TV's speakers.
the FiOS cable box is a motorola HD DVR that connects to a HDMI powered splitter and then goes into my LG CRT HDTV.
I tried other HDMI cables (with and without the splitter) and the sound still persisted.
The hum is present when the FiOS box is on/off and even if it is not plugged in!
If i remove it (at any point) from the loop the hum stops so I am confident that it is the FiOS box and it is some form of grounding issue.
i should also note that I had comcast (which used a similar motorola box) and i had no problems like this but i was using a DVI to HDMI on that box w/ audio over Optical.
and the TV's speakers are set to OFF because I run the sound to a reciever (over optical) yet the hum is only present on the TV.
any ideas?
thanks.
elbarto1 is offline
post #2 of 13 Old 11-29-2007, 11:29 AM
mjones73's Avatar
What happens if you hook it up via component?
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
post #3 of 13 Old 11-29-2007, 11:42 AM - Thread Starter
elbarto1's Avatar
thats what i am going to try when i get home from work...
I suspect it will fix the issue but since my HDTV is older and is limited in its # of component (2) and HDMI (1) input's (I have to use splitter boxes for all my "high tech gadgitry" which degrades the component signals) I prefer the HDMI.
but, if it fixes the issue, that will be worth the minor sacrifice because the hum is driving me nuts.
it just seems really odd, no?
elbarto1 is offline
post #4 of 13 Old 11-29-2007, 12:25 PM
Scooper's Avatar
There's GOT to be a ground loop problem in your gear somewhere. If the FIOS stuff was the most recently added - start there. Check that they grounded to the same ground wire all the rest of the house grounds goto. If not - get them back out there to fix it.
videobruce likes this.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #5 of 13 Old 11-29-2007, 12:39 PM - Thread Starter
elbarto1's Avatar
can you explain that in a little more detail?
sorry i am not very savvy when it comes to household wiring.
should i be looking at the big FiOS box they installed in the basement?
or elsewhere?
i'd rather solve this on my own because (in my experience) tecs think that customers are ignorant and i just dont feel like having to deal w/ missing school/work while i wait around for a service call.
thanks for the replys so far
elbarto1 is offline
post #6 of 13 Old 11-29-2007, 12:44 PM
Scooper's Avatar
Then have Verizon's tech or an electrician come and look at it - I guarantee Verizon will probably cost you less.
or elsewhere?
That's where I'd start - it should have a 3 pronged outlet, that should go to the same wiring as the rest of your house (same ground). Also check at the FIOS TV box for the same thing.
Scooper is offline
post #7 of 13 Old 11-29-2007, 12:48 PM - Thread Starter
elbarto1's Avatar
ok, so in a nutshell - i want the main FiOS box (in the basement) to be plugged into an outlet that is on the same ground that the STB/TV/Stereo/Etc is plugged into upstairs?
or is it much more complicated?
(dont worry I'm not going to go fiddling w/ live wires like a fool - just trying to get my head around what would cause this issue, when i dont understand something it just irks me...)
thanks.
elbarto1 is offline
post #8 of 13 Old 11-29-2007, 01:12 PM - Thread Starter
elbarto1's Avatar
i just happened upon this -
http://www.digitalhome.ca/forum/showthread.php?t=56203
and thought it would be worth a look since i have a PS3 hooked in as well.
cant try it till i get home but i never would have thought to check that.
edit
this explains a ground loop in plain english (incase some other noobs like me need help) and may be the cause of my problems -
http://boardsus.playstation.com/play...cending&page=1
cant wait to test this theory.
elbarto1 is offline
post #9 of 13 Old 04-05-2013, 10:08 PM
ungroundthmeter's Avatar
My Verizon FiOS technician connected the ground to my incoming service meter -- thus causing the speaker hum. Disconnect the ground wire from any electrical panel or box. This will stop the speaker buzz.
ungroundthmeter is offline
post #10 of 13 Old 04-06-2013, 04:39 AM
mikepier's Avatar
Quoted: 16 Post(s)
Do you have anything else connected to the tv or STB like an coax cable? Try removing any connection one at a time. My issue was my coax cable connected to my tv for OTA broadcasts. I grounded he splitter in my basement and the hum went away.
mikepier is offline
post #11 of 13 Old 04-06-2013, 06:45 PM
RollTide2011's Avatar
Quoted: 118 Post(s)
Liked: 95
Your Verizon optical node should be grounded to the common electrical ground shared by Power Co., Tel Co. And Cable Co. Do not remove this ground. If you are having problems such as you describe I would call Verizon back to check their installation and if necessary call Power Co and then finally you may need a licensed electrician. Just don't follow ungroundthemeter's advice!!!!!
RollTide2011 is offline
post #12 of 13 Old 04-07-2013, 05:19 PM
pwfletcher's Avatar
Have you tried a ground lifter? 60Hz hums are the worst ;-(
I like shiny stuff.
pwfletcher is offline
post #13 of 13 Old 04-10-2013, 03:24 PM
Wisiwyg's Avatar
This... also may want to Google 'ground loop isolator'
Wisiwyg is offline
Reply HDTV Technical
