satellite signal through window screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-03-2008, 03:42 PM - Thread Starter
bradyman's Avatar
Probably a dumb question, please don't flame -
I'm limited to possibly receiving satellite signal through a window (will put up plexiglass) but the landlord is a stickler and requires the window screen remain in place (liability reasons, won't budge on it). I'm 95% sure it's fiberglass mesh - so would the screen itself be signal transparent or reflective?
bradyman is offline
post #2 of 2 Old 01-03-2008, 04:00 PM
Scooper's Avatar
fiberglass mess shouldn't be a problem, but a metal mesh may as well be solid
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
Reply HDTV Technical
