Can I cut off HDMI cable then re-attach the adapter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-22-2008, 10:56 AM - Thread Starter
jacmyoung's Avatar
I am in the process of pulling HDMI cables to distribute HD signals throughout the house, can I cut the end of the HDMI cable off for easy fishing through the wall, then re-connect the adapter?
How far can an HDMI cable go without signal boost?
Thanks in advance.
jacmyoung is offline
post #2 of 10 Old 01-22-2008, 11:30 AM
raouliii's Avatar
You would have 19 conductors and maybe a shield to reattach. Seems like a lot of work. The HDMI plug is relatively small. Wiki HDMI Info has the pinout and a discussion on cable length.
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline
post #3 of 10 Old 01-22-2008, 12:29 PM
tlniec's Avatar
There are other options out there. I believe several companies make HDMI extenders (HDMI from source to sender, 2xCat5e cables from sender to receiver, HDMI from receiver to display). There's also a company called RapidRun that makes modular cabling -- you fish the cable without any ends on it, and then you can field-terminate it with any of several 'pigtails' (including an HDMI version, if I remember correctly).
Otherwise, you're stuck fishing cables with the ends attached. If your walls are open, not such a big deal. If not, it can be a big deal!
tlniec is offline
post #4 of 10 Old 01-22-2008, 04:05 PM
NetworkTV's Avatar
Quoted: 776 Post(s)
Liked: 1234
I'm pretty handy with a soldering iron, but there is no way I would attempt to reconnect an HDMI connector. Aside from the number of pins, those things are really tiny. Those things are machine soldered at the factory.
NetworkTV is offline
post #5 of 10 Old 01-22-2008, 04:15 PM - Thread Starter
jacmyoung's Avatar
And I don't even solder.
tlniec, thank you for the RapidRun link, judging from the pictures those connectors are not going to make my work much easier. Guess I will have to drill bigger holes than I like.
post #6 of 10 Old 01-22-2008, 04:53 PM
Scooper's Avatar
I had seen an announcment somewhere on here that some company has figured out how to convert HDMI to coax and back again - you might do some looking for that ?
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #7 of 10 Old 01-23-2008, 07:35 AM - Thread Starter
jacmyoung's Avatar
Is that the $700 device by Gefen you were talking about? Well it is still vaporware and not worth the expenses unless it can do a lot more, such as network several receivers.
post #8 of 10 Old 01-23-2008, 10:16 AM
sneals2000's Avatar
Quoted: 240 Post(s)
Liked: 127
When looking at HDMI over COAX solutions it is worth ensuring that they are lossless - i.e. they don't recompress the video to reduce the bitrate and will pass a full HDMI signal untouched.
sneals2000 is offline
post #9 of 10 Old 01-23-2008, 10:58 AM - Thread Starter
jacmyoung's Avatar
They say they can do 1080i now and is working on 1080p.
post #10 of 10 Old 01-23-2008, 01:28 PM
Scooper's Avatar
Yeah I think it was Gefen, but holy cow - that's pricey !
Scooper is offline
Reply HDTV Technical
