Convert coax cable to HDMI? Yes, only with DTV tuner. - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 87 Old 02-26-2012, 12:56 PM
sytyguy's Avatar
Originally Posted by Ken H View Post
It will not work for Digital TV or HDTV. It will only work for analog cable, which is soon to be extinct in most places.
It says it will work for satellite systems like Directv, which is what I want.
Coax Video Demodulator For CATV Satellite CCTV System
This is a perfect RF/coax demodulator for those TVs or desktop monitors without coaxial inputs or broken coax terminals. It also works for other RF coaxial sources such as satellite receivers, CCTV surveillance camera system and so on.
This coaxial to DVI HDMI converter will convert the RF coax signals or analog cable TV signals into digital DVI or HDMI signals with higher picture quality output to any flat panel monitor or LCD TV.
The coax input of this video demodulator can also be used for those satellite receivers with modulated TV2 out from DirecTV, Dish Network and FTA satellite for NTSC regions.
sytyguy is offline
post #62 of 87 Old 02-26-2012, 01:24 PM
Ken H's Avatar
Let's be clear about what this device does or doesn't do.
It will take any RF input, including from a DirecTV box, and upconvert the signal to HDMI, but it will not output native HDTV on HDMI from the RF input.
From the specs, the only way to get HD out of the box you bought is to have an existing HD source on HDMI or component video going into it, and it should pass that out on HDMI.
If you have an HDTV or display that has an HDMI input, and you want to watch DirecTV HDTV, the only way is to get a DirecTV HD box.
This topic's original discussion was using a source of digital cable or antenna, and how to convert that to HDMI. The only way is to use a digital cable or Digital TV tuner that takes the RF input, tunes the desired channel, and has an HDMI output.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #63 of 87 Old 02-26-2012, 08:29 PM
sytyguy's Avatar
I REALLY DO NOT CARE ABOUT NATIVE HD. And yes, I realize it is only upconverting the signal. I guess you think I cannot READ?
But let me be clear. I don't care if I have native HD, in fact, I don't care if the PQ is the same, all I want is an HDMI connection that is as good or better than what I currently have. And the only reason I purchased this item is because Directv changed their GUI (software), and some premium channels will not allow me to view channels that I have recorded because there is no HD cables attached to my modulated TV.
And I thought someone here might be interested in the device, and, of course, I am will to try it at my expense.
sytyguy is offline
post #64 of 87 Old 02-26-2012, 10:10 PM
msgohan's Avatar
This won't help. As far as the Directv box is concerned you are still using only the RF output.
Panasonic CX850 (TC-55CX850U, 2015)
PS3, WD TV Live
Denon AVR-890 (2009)
msgohan is offline
post #65 of 87 Old 02-26-2012, 10:18 PM
Ken H's Avatar
You do know this is an HDTV forum, don't you? The assumption here is always HD, unless someone calls it out otherwise.
Very, very unlikely.
Good luck, but based on what you've said, it probably will not help; see the comment directly above this.
Ken H is offline
post #66 of 87 Old 03-28-2012, 09:02 AM
sytyguy's Avatar
I canceled that device, and purchased this item, http://apicdn.viglink.com/api/click?...p%3Ft%3D201586
Keep in mind that I am not interested in HD viewing, just the capabilty to view recorded material, and this device gets rid of that nasty error message about lowering the resolution.
Anyway, thanks for your help
sytyguy is offline
post #67 of 87 Old 05-05-2012, 01:12 PM
jjl1329's Avatar
I have anew HP 610-1050F touch screen PC with built in TV. The TV only has a coax connector input. How may I connect devices with HDMI? Can the coax input be converted to accept hDMI?
jjl1329 is offline
post #68 of 87 Old 05-05-2012, 04:28 PM
Scooper's Avatar
If all you have is a coax input - you can't accept an HDMI HD input. Devices that take an HDMI input and output an ATSC DTV signal are as scarce as hen's teeth.
You CAN put antennas on your owned and/or controlled property...
http://www.fcc.gov/mb/facts/otard.html
Being A Beacon of Knowledge in the darkness of FUD
Scooper is offline
post #69 of 87 Old 05-07-2012, 08:52 AM
jjl1329's Avatar
I merely want to plug in a VCR, that has an hdmi connection
jjl1329 is offline
post #70 of 87 Old 05-07-2012, 08:57 AM
BCF68's Avatar
HDMI would be useless on a VCR.
BCF68 is offline
post #71 of 87 Old 05-07-2012, 05:30 PM
Ken H's Avatar
No such thing as a VCR that has HDMI. Do you mean DVR?
I looked at the specs for the HP 610-1050F, and there is no way to get an external HDMI input into the unit.
Also, there is no affordable way to convert HDMI to ATSC RF on a coax cable.
Ken H is offline
post #72 of 87 Old 05-28-2012, 12:11 AM
Darr247's Avatar
Why isn't anyone recommending an inexpensive AVR to do these hookups?
e.g. Denon AVR-1312 5.1 Channel ($140 USD)
Darr247 is offline
post #73 of 87 Old 05-28-2012, 01:26 AM
Ken H's Avatar
Because that won't work. Not even close.
From the original question, an RF cable carries a modulated ATSC signal. Nowhere on an AV receiver, any AV receiver, is an RF input for a modulated ATSC signal.
From the most recent question, the PC in question has no HDMI input, and no AV receiver can help with that, either.
Ken H is offline
post #74 of 87 Old 08-17-2012, 01:04 AM
hbindfw's Avatar
hbindfw is offline
post #75 of 87 Old 08-17-2012, 03:06 AM
sneals2000's Avatar
Quoted: 240 Post(s)
Liked: 127
Don't you guys have VCR/DVD+/-R combos in the US - a combined VCR and DVD Recorder in one box. They're mainly sold over here to allow you to archive VHS content to DVD, or to continue to replay VHS content. These days they're the only real VHS decks on sale in most aras.
Example here : http://www.amazon.co.uk/Toshiba-DVR20-Digital-Recorder-Freeview/dp/B003LO2RIU/ref=sr_1_2?s=home-theater&ie=UTF8&qid=1345194279&sr=1-2
This contains a VCR and has an HDMI output.
sneals2000 is offline
post #76 of 87 Old 08-17-2012, 08:35 AM
jjeff's Avatar
Quoted: 687 Post(s)
Liked: 245
Yes we do or I should say did. They've basically disappeared from the market replaced by nothing frown.gif
Even when they were available most did not output VHS over HDMI, HDMI was reserved for DVD and tuner output if the recorder had a tuner.
Instead of a combo a regular DVDR would be more plentiful but alas even those are very hard to fine. DVDRs are basically dead in N. America and like the UK if you want a new VCR your only bet is a very cheap combo player, standalone VCRs haven't been available in the consumer market for quite a few years frown.gif
Funai made Toshibas may be the only models currently available with a tuner, Panasonic dropped out a while back. Magnavox(Funai built) is slated to come back out with a couple(not VHS) models later this year but new they've only been available through the internet from Walmart.
jjeff is online now
post #77 of 87 Old 08-17-2012, 04:55 PM
sneals2000's Avatar
Quoted: 240 Post(s)
Liked: 127
You still see one or two VCR+DVDR combos on sale in most decent AV shops, or AV departments in decent department stores. There is also a VCR with built in USB Video capture for PC archiving, made (or badged) by the same company (Ion) that also does audio cassette and record player USB capture devices.
post #78 of 87 Old 01-15-2013, 08:20 AM
tryoung74's Avatar
Ok my problem is a little different. I want to convert a cable line from the cable company to a hdmi cable. I have a home a/v set all ready and I just got cable analog from the cable company. I don't want to run another cable up to the tv. I there such a animal that will convert to a hdmi to fix my problem.
tryoung74 is offline
post #79 of 87 Old 01-15-2013, 08:47 AM
sitlet's Avatar
How is that "a little different"? That's exactly the same problem. And the answer again is no, there is no magic cable that can convert an RF cable to hdmi. You need a cable box.
sitlet is offline
post #80 of 87 Old 01-15-2013, 08:55 AM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
Yeah.... a cable box or old VCR (as suggested above), assuming your A/V receiver can upconvert/transcode non-HD analog (composite/s-video) to HDMI. Otherwise, just run the cable feed/coax directly to the TV.
Ratman is online now
post #81 of 87 Old 01-15-2013, 12:04 PM
jjeff's Avatar
Quoted: 687 Post(s)
Liked: 245
If I read your question right it sounds like you want to convert whats available on a coax cable to HDMI and this would be a no. Your only option is to hook your coax cable to a tuner with HDMI output and then run that HDMI output to your device. Whats different about this is to change the channels you'd need access to the tuner(or somehow use a RF remote) and the HDMI cable would only have one signal or channel on it, not like a coax cable that can have 100s. Is this what you meant by your question being different?
jjeff is online now
post #82 of 87 Old 12-04-2013, 08:27 PM
ajdjer's Avatar
I think this question has been asked before but I can't tell that it's been answered. So, here goes. I built a house 12 years ago and had it wired for what was current at the time. In my great room I have all of my components in cabinets on the left of my fireplace, and my TV is in cabinets to the right of the fireplace. I bought a new HDTV yesterday and the cable company is coming out next week to upgrade everything. Here's my challenge: My new receiver has HDMI inputs for my DVD player, Apple TV and the new HD cable box. The output should be HDMI to the TV, but the only cable that runs from the component cabinet to the TV is coax, and it'd be impossible to pull an HDMI cable through the wall behind the fireplace. I was told there is a device that converts coaxial to HDMI on both ends...in other words, the HDMI output from the receiver would plug into this device, which would connect via the existing coax to another device at the TV, which would then output HDMI to the TV. I was told it's about $500. Does this make sense? Is there anything cheaper?
ajdjer is offline
post #83 of 87 Old 12-05-2013, 12:26 AM
RollTide2011's Avatar
Quoted: 118 Post(s)
Liked: 95
Look up HDMI over ethernet you can get the adapters for less than $100 at Monoprice or Amazon, I think that will meet your needs.
RollTide2011 is offline
post #84 of 87 Old 12-05-2013, 08:14 AM
Ratman's Avatar
Liked: 1022
HDMI over single coax:
http://www.amazon.com/C2G-Cables-40575-TruLink-Receiver/dp/B005SHWWO2
EDIT:
Here's a "kit":
http://buddymall.com/products/Cablestogo-40574-HDMI%252dover%252dcoaxial-extender-kit.html
As for HDMI over ethernet, I believe that requires cat5/5e/6 cable. So if new cable(s) can't be run, this solution may not work.
post #85 of 87 Old 01-02-2015, 06:53 PM
Liked: 0
Originally Posted by raouliii View Post
If your LCD has a QAM tuner, you need to perform a digital scan to find the unencrypted DT (HD) channels that may be available from your cableco. Does your set have a QAM tuner? It may just have an analog NTSC/digital ATSC tuner. What model is it?
I have 2 recent Panasonic HDMI TV’s both hooked to a paid cable service through an HD cable box. I also have a third identical TV without a cable box, on which I can only receive a limited number of basic non-HD channels through the TV input.
I’d like to know how can I watch these channels in HD through the built-in QAM tuner without having to buy or rent a 3rd cable box from the cable provider.( I suppose this TV has a built-in QAM tuner, too, because the other 2 TV’s , which are exactly the same, can scan for digital channels.)
Thank you
Ittiandro
ittiandro is offline
post #86 of 87 Old 01-02-2015, 06:56 PM
Liked: 0
How to use built-in QAM tuner
Thank you
Ittiandro
post #87 of 87 Old 01-02-2015, 07:04 PM
Liked: 0
How to connect QAM tuner
I’d like to know how can I watch these channels in HD through the built-in QAM tuner without having to buy or rent a 3rd cable box from the cable provider.( I suppose this TV has a built-in QAM tuner because the other 2 TV’s , which are exactly the same, can scan for digital channels.)
Thank you
Reply HDTV Technical
