Envision L32W761 VGA resolution problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-13-2008, 01:45 PM - Thread Starter
magnumforce2006's Avatar
I'm having problems displaying a resolution higher than 1024x768 on my Envision HDTV using a VGA connection from my laptop. The manual states that a resolution of 1360x768 is not only supported, but recommended. The refresh rate is also correct (60Hz). However, any time I attempt to display a resolution higher than 1024x768, the HDTV screen goes blank and displays the message "mode not supported"
Any ideas?
magnumforce2006 is offline
post #2 of 3 Old 02-13-2008, 01:49 PM
mjones73's Avatar
You may have better luck posting this in the Flat Panel section, this area isn't for displays. Welcome by the way, good luck with your issue.
Matt
Please don't PM me with technical questions that should be posted in the forum.
mjones73 is offline
post #3 of 3 Old 02-13-2008, 01:56 PM - Thread Starter
Will do, thank you.
Reply HDTV Technical
