Panasonic PT-AE700U 720p projector, with mount and new lamp - AVS Forum | Home Theater Discussions And Reviews
Old 07-30-2012, 07:10 PM - Thread Starter
daveidmx's Avatar
Panasonic PT-AE700U 720p LCD projector with zoom and lens shift, and remote. The current lamp has about 1500 of 3000 hours. Also included are a ceiling mount, an additional brand new lamp, and optionally a 25' VGA cable and a 25' HDMI cable. One of the screws holding the cover on is broken, however there is no optical damage.
Local pickup in Atlanta, GA, or PM me your zip code for shipping estimate.
If you're doing local pickup (or can figure out how to ship it) I'll also offer my DIY 80" 16x9 rigid screen for free. It's 1/2" MDF with sprayer-applied grey surface. I can't remember which paint mix exactly, but it's one that was popular on this board a couple years back.
daveidmx is offline
Panasonic Et Lae700 Replacement Lamp For Pt Ae700u
