Infocus 4805 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-04-2012, 01:38 PM - Thread Starter
marjen's Avatar
Quoted: 102 Post(s)
Liked: 55
Infocus 4805 projector. Good running condition. Not sure where bulb is at, says 1 hr on bulb but i think maybe it just reset or something over time as it has not been used in ages. I plugged it in and let it run for awhile and it still works well. Does not include shipping.
marjen is offline
post #2 of 3 Old 02-24-2013, 08:59 PM
auditron's Avatar
Hello,
Regarding your InFocus 4805:
Do you still have it? How was the brightness, relatively?
Did it project all the colors like when it was new?
How about the focus?
I am faced with repairing mine or getting your used one.
The cost would be around the same amount.
Thank you for your time,
Darryl Widman
auditron@juno.com
auditron is offline
post #3 of 3 Old 11-15-2013, 03:15 PM
BillFree's Avatar
Quoted: 36 Post(s)
Darryl
FYI,
The Infocus SP-4805 was my first great little projector years ago and still being used as need by our family.. Later on I got a HDMI adapter to plug in a HDMI cable to my bluray drive and big screen viewing was great. A friend of mine had a Panamorph anamorphic lens and I tried it out and found out it has a rare scaler built in. (X2 doesn't). Right away I had 33% more color and great 2:35 wide screen capability. with vertical compression (vc). I have gone on to other projectors but You can't believe what the SP-4805 can do. Don't under estimate it. Replacement lamps are cheap if you look for them. Some people always kept a spare if you place a wtb ad. Check out AVS forum under SP4805 and see pictures what others show. Thanks, Bill
BillFree is offline
Reply Front Projector
