Projector with high lumens capable playing videos in nightclub. Low budget - AVS Forum | Home Theater Discussions And Reviews
Old 01-23-2013, 02:20 PM - Thread Starter
sweetjayne's Avatar
If anyone has or runs across a projector that they would consider letting go that would work considering the smoke and room size that is in my budget, please contact. Current budget only $650.00. Realize low for what I need, can go higher if accept payments for difference over a few months. Thanks for any responses.
sweetjayne is offline
Old 03-12-2014, 01:46 PM
crebelo's Avatar
I have 2 NEC U300X projectors with mounts. Where are you located? Looking to get $700 each but $650 works let me know.
crebelo is offline
