Screen Innovations SolarHD screen material: 122" 2.40 ratio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-05-2013, 02:45 PM - Thread Starter
Smackrabbit's Avatar
Quoted: 31 Post(s)
Liked: 92
This is a 122", 2.40 aspect ratio screen made from Screen Innovations incredibly well reviewed Solar HD material. This is only the screen material itself and the snap connectors to attach it to a compatible frame. The full dimensions of the screen are visible in the first image, making it easy to build your own screen, or to contact Screen Innovations to order a frame for it. The SolarHD material is a 1.3 gain, very color neutral material. Measurements of the material can be found here: http://www.accucalhd.com/documents/accucal_front_projection_screen_report.pdf
The screen was bought new direct from Screen Innovations in the winter of 2011 and has been kept on the wall in a non-smoking, no pet household in a dedicated theater room with no exposure to sun or the elements at all. It is in perfect condition and being sold as I replaced it with the new SolarHD 4K material (which snapped directly into the screen that previously held this material). I have repacked the material directly into the box that the new material came in, so it is well protected and padded, and should arrive in perfect shape. The snaps that are used to attach the material into a frame are included, as well as instructions for building a Screen Innovations frame.
Shipping is via UPS Ground and paid by buyer. Box is around 12"x12"x48" so not small, only weighs around 15 lbs. Please email with any questions. Ships from 97219 zip code.
Chris Heinonen
Writer, The Wirecutter
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Senior Editor, Secrets of Home Theater and High Fidelity, Displays Editor, AnandTech.com, Contributor, HDGuru.com and Electronic House
Smackrabbit is offline
Reply Front Projector
