JVC DLA-RS56 90000:1, THX, ISF - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-27-2013, 04:47 PM - Thread Starter
Mod & Bluray Reviewer
Moderator
Lee Weber's Avatar
Quoted: 137 Post(s)
Liked: 402
50 hours on the bulb, mint condition-- will come with FULL warranty.
This was hand picked out of 8 units for me. It performs amazingly!
The DLA-RS56, upgraded for 2013, is our most affordable fully-featured home cinema projector. Equipped with JVC's new e-shift2 technology, HD material is upconverted to a stunning 3840 x 2160 resolution with superb contrast and clarity. 3D images are brighter than ever with negligible crosstalk. And a new wiregrid polarizer boosts the native contrast ratio to 90,000:1. The DLA-RS56 is clearly the best value in a totally customizable 3D home theater projector.
90,000:1 Native Contrast Ratio
1920x1080(x3) 0.7-inch D-ILA devices
e-shift2 4K Precision 3840 X 2160 Projected Image
MPC (Multiple pixel control) with JVC's 8 Band Detection 2K to 4K Upscaling Engine
New 230 Watt NSH Illumination System
(lamp life up to 4,000 hours in normal mode)
THX® 3D Certified
ISF (Imaging Science Foundation) Certified
Highly customizable
6 picture modes and 3 color spaces
Darkness and lightness correction
Lens memory function memorizes 10 positions for focus, zoom and shift.
Maintains constant height for 2.35, 1.85, 1.78 on same screen.
Screen Mode Presets for different screen material (255 memory positions)
Convergence Correction - 1/16th Pixel Increments
Stunning 3D Performance with new RF active shutter glasses (optional)
Improved 3D Brightness
Advanced 3D Crosstalk Cancellation Control
3D Anamorphic Mode
Parallax adjustment for fine tuning 3D effect
Highly customizable built-in 2D-3D converter
Accepts all modern 3D formats (Blu-ray, side-by-side, top-and-bottom)
Optimum Flexibility and Convenience
Inputs: (2) HDMI 1.4a; (1) VGA; (1) Component
LAN connection for system control and firmware updates
Remote control via LAN, RS-232C, IR
12V Screen Trigger Output
V: 80%/H: 34% motorized lens shift
1.4:1 to 2.8:1 lens throw
Smartphone remote control app available
2 Year Warranty
Lee Weber is offline
Reply Front Projector
