F/S: Panasonic PT-AE2000U Home Theater Projector - $400 Needs Lamp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-25-2014, 03:27 PM - Thread Starter
BuckMerko's Avatar
The projector has been well maintained and is in mint condition. kept in dedicated theater room. No pets/smoking.
Will come with all the original accessories, power, remote, & packaging ext.
Bulb is good for another 50hrs so you will need a new lamp. I highly recommend (The Projector Peole) for the OEM replacement bulb.
After market lamps can also be found on eBay for less.
Some basic specs:
1500 ANSI Lumens Widescreen 1080p High Definition Home Theater Projector PT-AE2000U
with Smooth Screen Technology and up to 16000:1 Contrast Ratio
Price: $475 + actual shipping cost (CONUS ONLY) .
Would prefer local pickup. Can also drop off within 50 miles.
Thanks B.
BuckMerko is offline
Reply Front Projector
