Sony VPL-VW100 LCD Projector SXRD Xeon Bulb w / ceiling mount 1500hr left on bulb - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-25-2014, 12:06 AM - Thread Starter
bjnesbitt's Avatar
Sony VPL-VW100 LCD Projector**PRICE REDUCED $900
SOLD!!!
Will take less than $900!! We hate to part with it but we are down sizing with no theater room at the new house. Need to sale by May 30th. This is a high end professional grade projector with pure xenon lamp makes the picture INCREDIBLE! We didn't even use a projector screen the off-white taupe wall was perfect!!! Picture is off our wall with lights off. Will come included with the mount that's usually $200. Is used in a smoke free environment, and was purchased new from Ultimate Electronics back in May of 2011.
Unit is in working order so you can come see it in action if you live close to Oklahoma.
Sony VPL-VW100 High-Definition Front Projector SonyElectronics presents the new 1920 x 1080p (progressive) high-definition front projector based on the company's exclusive Silicon X-tal Reflective Display (SXRD(TM)) technology.
The VPL-VW100 joins the two new Grand WEGA SXRD rear-projection micro display televisions, the KDS-R60XBR1 and KDS-R50XBR1, utilizing the world's smallest 0.61 SXRD chip to deliver more than 2 million pixels and the full power of high-definition.
The projector incorporates three SXRD chips -- one each for red, green and blue color reproduction -- to deliver more than 6 million native pixels.
Features:* 400 watt Pure Xenon lamp that delivers unrivaled color reproduction. The lamp approximates sun light and can reproduce colors closest to the natural spectrum including the red bandwidth, and is widely used in professional film projectors.
The new Advanced Iris produces accurate blacks and works with three 0.61 SXRD chips to deliver an over-all contrast ratio of up to 15,000:1 when "auto" Iris mode is on.
Extremely low fan noise of 22dB, which is one of the lowest in the industry and critical for home theater applications. * 1.8x powered lens zoom and powered focus as well as lens shift to adjust the vertical and/or horizontal manual location of the image for flexible installation locations.
Input options:
1080p HDMI and DVI-D and RGB and component video.
Specifications:
Brightness (Lumens) : 800 ANSI
Contrast: 15000:1
Zoom: Power, 1.80:1
Lens Shift: H+V
Screen size: At minimum zoom projector mounted at 15 ft from screen the diagonal size is96 in
Screen size: Max zoom, mounted at 15ft from screen the diagonal size is 144in
Max Screen size: At maximum mount distance of 30 ft throw distance the diagonal size can range from 230in to 300in
Screen size calculator for Sony VPL-VW100: http://www.projectorcentral.com/Sony...ulator-pro.htm
Compatibility:
HDTV: 1080p Component VideoVideoDigital Input: HDMI (HDCP)Personal Computers
Lamp Type: 400W Xenon Display: Type: 0.6" SXRD (3)
Native: 1920x1080 Pixels
Aspect Ratio: 16:9 (HD)
Audible Noise: 22.0
Features:
It supports Full HD with three SXRD 1920 x 1080p Panels
up to 15,000:1 contrast ratio (with Advanced Iris function on)
ARC-F (All Range Crisp Focus) Lens
12-bit panel drive full digital chassis
User selectable over scan function (choice of ON or OFF)
Product Details:
Manufacturer:SonyManufacturer
Mode: VPLVW100
Product Dimensions:22.6 inches x 19.5 inches x 6.9 inches; 41.9 pounds
Shipping Weight:54 pounds
ASIN:B000DZM8A2
Link to short video showing the projector in action playing BluRay movie:
Please only serious buyers email me at: bjnesbitt@cox.net
Last edited by bjnesbitt; 07-10-2014 at 05:45 PM. Reason: stating product has been sold.
bjnesbitt is offline
post #2 of 2 Old 07-10-2014, 05:43 PM - Thread Starter
bjnesbitt's Avatar
Sold!!!
Reply Front Projector
Sony Vpl Vw100 Lcd Projector
