Da-Lite 106” (16x9 Diagonal) Cinema Contour Screen HCCV - AVS Forum | Home Theater Discussions And Reviews
Old 08-03-2014, 02:20 PM - Thread Starter
Joel Solid's Avatar
Da-Lite 106” Diagonal (16x9) Cinema Contour Screen HCCV
Local pick up only 92592
Original owner. non-smoker. Located in adedicated theater room. Screen is in great condition.
SOLD (retail price is over $1,500.00)
Or $170 for frame without screen material
High Contrast Cinema Vision: Viewing Angle: 50° Gain: 1.1
With its specially designed gray basesurface and a reflective top surface, this screen material is able to providevery good black levels without sacrificing the white level output. With itsenhanced black levels and brilliant white levels, this screen surface providesdeep life-like colors and greater detail and sharpness to the image. Front projection surfaces standard with blackbacking for opacity. Screen surface canbe cleaned with mild soap and water. Flame retardant and mildew resistant.
90271V Features: -Cinema Contour has a45-degree angle cut frame for a sleek, modern appearance.-Provides a perfectlyflat viewing surface for video projection applications.-Surface mounts to theback of an aluminum frame that provides a masking border.-
Color/Finish: -Frame standard with Pro-Trimfinish, a fabric frame covering that aesthetically enhances the appearance ofthe installation while absorbing light that surrounds the viewing area.
http://www.bestbuy.com/site/da-lite-cinema-contour-106-fixed-projector-screen/5021422.p?id=1218597391991
Joel Solid is offline
Old 08-12-2014, 01:05 PM - Thread Starter
Joel Solid's Avatar
New lower price.
Old 08-12-2014, 01:59 PM
scottnv's Avatar
Quoted: 56 Post(s)
Liked: 27
Would be all over it if I lived in same time zone!
scottnv is offline
Old 08-12-2014, 02:31 PM - Thread Starter
Joel Solid's Avatar
I hear ya. It is a great screen. It is obviously priced to sell!
