Pioneer Elite Pro 150fd - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-06-2013, 01:16 PM - Thread Starter
Xae
Xae's Avatar
Hi all,
I'm selling my 60" 8g elite. It is currently functional albeit a few issues. There was an issue with some pixels misfiring but I have corrected this via a voltage increase.
There is also some very light burn/super persistent IR in on the lower right (I hate channel logos) that is only really visible during a static bright screen. 99% of normal viewing you likely won't notice it but it is there. I have been running the WoW pixel flipper and it is lessening and hopefully will eventually completely fade. There is also a single stuck blue pixel in the same area.
The repair shop also put a 1 inch scratch on the frame (lower right) but again only really noticeable up close.
The panel has been calibrated by Doug Weil since I purchased it. The last tune up was roughly two years ago.
I"m in the Chicago area and would prefer local pickup. I will consider shipping if it makes sense at the buyer's expense.
Damn Bakery
Xae is offline
post #2 of 2 Old 11-11-2013, 03:19 PM - Thread Starter
Xae
Xae's Avatar
With the help and advice from some of the forum members here I managed to fix the pixel misfiring issue by increasing the voltages slightly via the service menu. I will update the original posting to reflect this.
The issue was similar to what is described here http://www.jopezu.com/plasma.htm
Damn Bakery
Xae is offline
Reply Plasma Panels
