Samsung LN-T4081F 40" 1080p LED Backlit HDTV + WMN-5090 Motorized Wall Mount - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-04-2012, 01:38 PM - Thread Starter
wooblewobble's Avatar
This 40 inch TV is flawless in every way and the matching Samsung WMN-5090 motorized wall mount is as well. It was Samsung's top-of-the-line model. You control the motorized wall mount with the TV's remote control using its arrow keys to swivel up, down, left, and right from the comfort of your seat. It'll be sure to wow your friends. The built-in stand also swivels from side to side. It is LED backlit as opposed to edge lit like so many other models so the contrast is great and it also has a built-in subwoofer in the back so the sound is very good even without a home theater system. I actually like the picture and sound of this set better than the one I bought to replace it, but I needed something bigger so this one has to go. I still have the manuals and special cleaning cloth that came with it as well. I'll also throw in the HDMI cable shown in the pictures.
TV is located in Chicago.
wooblewobble is offline
Reply LCD Panels
