MSI 7411 Motherboard Sneak Peek (share your thoughts!) - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 3490 Old 12-01-2008, 07:21 PM
NickB's Avatar
Wow, that doesn't look good. With things being shipped by slow boat I wonder if these got damaged some how in transit.
I know how frustrating it is dealing with RMA's (and have cursed many a MB in my time), but I promise that once you get a good board you'll forget all about it
NickB is offline
post #632 of 3490 Old 12-01-2008, 07:34 PM - Thread Starter
Java Jack's Avatar
Hmm, that does not look good. I will send this directly over to MSI to see if they have any feedback.
Please PM some details on where you got it and date. Also check to see if there are any stickers that indicate SN, etc.
I can't promise anything, but I will see what I can find out for you.
Regards.
Java
There are 10 types of people in the world, those that understand binary, and those that don't.
AMD@Home Blog: http://links.amd.com/Home
Twitter: http://twitter.com/Java_Jack
Java Jack is offline
post #633 of 3490 Old 12-01-2008, 07:36 PM
DonTHB's Avatar
I finally got a 7.1 working this weekend, but I have found that the only way to get 5.1 sound is with the four RCA card added. The line out does not work. I wasted lots of time troubleshooting without the board. When I installed the pre-amp I finally got audio. Is this a hardware or software/driver problem?
Otherwise, I am pleased.
DonTHB is offline
post #634 of 3490 Old 12-01-2008, 07:41 PM - Thread Starter
Java Jack's Avatar
Line outs on the board will not work without the 3 RCA board installed, but it should work once the card is installed. You should not need the 4 RCA board cabled in though.
The 2 channel line outs require a driver to enable them without a card installed. This is in development now. No ETA on availability just yet.
Regards.
Java
post #635 of 3490 Old 12-02-2008, 12:47 AM
clayc's Avatar
Hi, I have a quick question... do you think that the 5.1 amp card would be able to adequetly power relatively "power hungry" speakers, like Magnepan MMG's in stereo mode?
clayc is offline
post #636 of 3490 Old 12-02-2008, 12:57 AM
DonTHB's Avatar
I removed the board and I am still missing the surrounds. The fronts are still associated with the top and bottom RCA connectors on the pre-amp. No change after uninstalling the Microsoft driver.
What do I need to do so that the driver reconfigures the audio so I can get 5.1 without the cabled card?
I am assuming that the line outs are for the front left and right speakers and the card's connectors are for the center speaker and left and right surrounds. A powered sub is always connected to the yellow RCA between the line outs and ins.
DonTHB is offline
post #637 of 3490 Old 12-02-2008, 01:02 AM
vladd's Avatar
Liked: 39
I'm pretty sure that the line outs would be the surrounds. I would need to test it though.
Edit: I tested it and the line outs on the motherboard mirror the front left and front right connectors on the preamp board (sound for front left and right are sent to both the m/b line outs and the preamp card). It's not possible to use this configuration for 5.1, only 3.1. Test was done on Vista x64.
vladd is offline
post #638 of 3490 Old 12-02-2008, 02:59 AM
barryrs's Avatar
Im surprised so many are having trouble with the audio setup, mine was very easy and required minimal input from me.
I also dont have a powered sub so i have connected the sub up to the centre output so this is running both and although this could be seen as a bit of a bodge im perfectly happy with the sound quality im getting.
barryrs is offline
post #639 of 3490 Old 12-02-2008, 05:57 AM
stgdz's Avatar
Its a computer, stuff is bound to go wrong. I expect it with every build I do and always will. It took me a little bit to get everything the way I like it.
JJ, about the input switcher. Will it be a plugin that VMC, MCE, or sagetv will be able to control through their interface?
stgdz is offline
post #640 of 3490 Old 12-02-2008, 09:32 AM
nkrtwx's Avatar
Thanks Java Jack!! You saved me so much time and trouble!!
nkrtwx is offline
post #641 of 3490 Old 12-02-2008, 10:35 AM - Thread Starter
Java Jack's Avatar
It is a plug in for VMC.
Regards.
Java
post #642 of 3490 Old 12-02-2008, 10:36 AM - Thread Starter
Java Jack's Avatar
Not sure what you mean by power hungry speakers, but I would expect it to work. The solution has been tested with both 4 and 8 ohm speakers, including some very high dollar speaker solutions.
Regards.
Java
post #643 of 3490 Old 12-02-2008, 10:38 AM - Thread Starter
Java Jack's Avatar
Hmm, the line outs will mirror L/R when the full 7.1 solution is installed. However, when just the 3 channel card is installed, the MB line outs should act as surrounds.
Regards.
Java
post #644 of 3490 Old 12-02-2008, 11:52 AM
vladd's Avatar
Liked: 39
Didn't work for me. I even did a hard reboot with the daughterboard unplugged before testing.
vladd is offline
post #645 of 3490 Old 12-02-2008, 12:50 PM
DonTHB's Avatar
I had it working as you described with 7.1 configured as 5.1 in Vista. When I removed the 3 channel card nothing changed with outs. Same as Vladd.
DonTHB is offline
post #646 of 3490 Old 12-02-2008, 01:29 PM - Thread Starter
Java Jack's Avatar
Thanks for the feedback. I will bring this up with the team at D2Audio. When I tested it previously, I had it working as described, but that was a while back.
Regards.
Java
post #647 of 3490 Old 12-02-2008, 02:30 PM
DonTHB's Avatar
Has anyone tried to install an ATi 650 into the farthest slot from the CPU? On the motherboard there are capacitors near the bracket for this slot that make seating the 650 difficult (or in my case impossible) due to the audio-in.
Anyone using a tuner card in this slot? If so, which one? Thanks.
DonTHB is offline
post #648 of 3490 Old 12-02-2008, 03:30 PM
nkrtwx's Avatar
Does anyone know if MSI will have a new version of live barebones,with this better mb inside?
nkrtwx is offline
post #649 of 3490 Old 12-02-2008, 05:05 PM - Thread Starter
Java Jack's Avatar
Hello Don,
I have the Theater 650 installed in slots 1 and 2. I did not use Slot 4 because I wanted to give the amp card some room to breathe. Likewise, with the Pre Amp card installed, slot 4 would normally be taken up.
I was aware of the capacitor issue and did raise that with MSI. It is my understanding they switched the caps to lower profile components for future builds.
Regards.
Java
post #650 of 3490 Old 12-02-2008, 05:07 PM - Thread Starter
Java Jack's Avatar
To my knowledge, they don't have plans for a barebones at this time. This board would not fit in that existing chassis due to the add in cards being low profile.
That chassis measures 80mm as I recall and 1/2 height cards are around 90mm if I remember correctly.
Regards.
Java
post #651 of 3490 Old 12-02-2008, 05:09 PM
nkrtwx's Avatar
Thanks so much!!!
nkrtwx is offline
post #652 of 3490 Old 12-02-2008, 07:17 PM
stgdz's Avatar
Are they planning on building a full ATX version?
I would really like to use crossfire or a dual slot GPU.
stgdz is offline
post #653 of 3490 Old 12-02-2008, 07:44 PM - Thread Starter
Java Jack's Avatar
I don't know. I would guess not just yet. There needs to be some level of success with this first platform before they will invest in creating a 2nd one.
Right now, we are seeing some interest in this platform, but I don't think MSI is selling a ton of them just yet. I think the Gbyte board is probably capturing the bulk of the market share for uATX 780 boards at the moment.
Regards.
Java
post #654 of 3490 Old 12-03-2008, 06:02 AM
stgdz's Avatar
Gigabyte has also been out for a bit longer with the 780g uATX.
May I suggest changing the thread title to
MSI 7411 780M Motherboard (Onboard 5x100 amp or 7.1 pre-amp)
I think it would help a bit.
stgdz is offline
post #655 of 3490 Old 12-03-2008, 06:05 AM
nathangunn's Avatar
Hi,
I am having trouble sourcing the motherboard. I would like to purchase the motherboard with 5.1 amp so I can plug my speakers back straight into it. Can anyone tell me where to get one from?
Many thanks.
nathangunn is offline
post #656 of 3490 Old 12-03-2008, 06:44 AM
TedTheNanite's Avatar
Newegg seems to have them in stock.
http://www.newegg.com/Product/Produc...Tpk=msi%20diva
TedTheNanite is offline
post #657 of 3490 Old 12-03-2008, 10:21 AM - Thread Starter
Java Jack's Avatar
I don't think changing the title of the first post will change the title of the thread.
Perhaps it would be better to have one of you owners start a new, "official" thread for discussion and close this thread off.
Regards.
Java
post #658 of 3490 Old 12-03-2008, 01:22 PM
jschoorl's Avatar
According to MSI Europe the board + 5.1 AMP will only available to OEM's not to "regular" shops. So probably have to import one from the US. Not a wise thing to do MSI, cause there is a lot of interest in Europe I think.
Anyone knows a reliable US online shop that has the 5.1 version in stock and ships to Europe ?
Read more about my HTPC Plus project
jschoorl is offline
post #659 of 3490 Old 12-03-2008, 09:34 PM
brian of oz's Avatar
Does the spdif out function without the 7.1 preamp installed? I want to use this board in a slim case and will settle for spdif out if it will work.
brian of oz is offline
post #660 of 3490 Old 12-03-2008, 10:38 PM
vladd's Avatar
Liked: 39
Yes. The SPDIF is part of the onboard RealTek and not the D2Audio though.
vladd is offline
Reply Home Theater Computers
