720/1080p h.264.mkv playback with P4 3.0ghz possible? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 03-09-2008, 12:28 PM - Thread Starter
Kelfa's Avatar
Been having a nightmare trying to get a Celeron 2.66ghz to play 720p h264 files.
Took all the advice here, coreAVC, MPC, and heali. Still wouldn't play smoothly, cpu was always 100%.
My dad is giving me his P4 3.0ghz w/1gig of ram to try out. With the same program setup should this rig be able to handle 720/1080p h264.mkv files 2-10gigs in size?
I'm not sure what vid card is has yet but could upgrade if needed to something that accelerates h264. I heard the ATI hd 2400 or something would be good.
Kelfa is offline
post #2 of 17 Old 03-09-2008, 12:30 PM
rob2687's Avatar
It won't be able to play high bitrate 1080p movies smoothly.
rob2687 is offline
post #3 of 17 Old 03-09-2008, 12:41 PM
NathanC's Avatar
Have the same processor and can play 720p smoothly with CoreAVC/AC3filter, but 1080p is definitely a no-go. 1080p is a slideshow and even getting 720p to play smoothly took a decent amount of codec tweaking.
NathanC is offline
post #4 of 17 Old 03-09-2008, 12:56 PM
tetsuo55's Avatar
My athlonXP 2600 @ 2.0 GHZ plays back 720p with 70-95% cpu usage, the image never stutters.
1080P is unwatchable, good thing i have a DXVA videocard for those
tetsuo55 is offline
post #5 of 17 Old 03-09-2008, 02:48 PM
KingLion's Avatar
I have a Dell XPS Dimension with a P4 3.0 Ghz Processor and 1GB of Ram. I can play any 720P movie fine at around 75 to 100 % cpu usage. 1080P are a definate no go though. I have tried WMV HD 1080 files from Microsoft and iTunes 1080P files and even the Batman Trailer from Nero Digital which is an mp4 1080P File
http://www.nero.com/enu/trailer.php?id=102
My video card is ATI Radeon AGP 9800 Pro
KingLion is offline
post #6 of 17 Old 03-09-2008, 04:12 PM
talon95's Avatar
Quoted: 130 Post(s)
Liked: 63
Same story here. I have a 2.6Gig P4 overclocked to 3.2 (250x13). 720p is no problem, but 1080p maxes out at 100% and skips frames badly using CoreAVC. x850Pro vid card.
talon95 is offline
post #7 of 17 Old 03-09-2008, 06:22 PM
KingLion's Avatar
Yeah, and after reading alot of threads I think alot of people are having troubles with 1080P files playing correctly, whether it be a $700 Computer or $5000 dollar computer
KingLion is offline
post #8 of 17 Old 03-09-2008, 06:38 PM
klipsch's Avatar
Quoted: 183 Post(s)
Liked: 94
I'll chime in with the rest and say 1080p is a no go but 720p is good with codec tweaking. I have a P4 2.4 with a ATI 9600pro that can do 720p with aboud 90% usage (depends on the file bitrate). My Quad core Q6600 with 8800gt plays 1080p with about 35% (again depends on the file bitrate (audio and video)).
klipsch is offline
post #9 of 17 Old 03-09-2008, 07:24 PM
Xelloss101's Avatar
My 3.0 GHz P4 HT 1.5GB Ram won't play 1080p movies, will play 720p fine. But my laptop 2.0 Ghz Dual Core with 2GB Ram will play a 1080p movie just fine at 40-80 CPU%.
Xelloss101 is offline
post #10 of 17 Old 03-09-2008, 08:35 PM - Thread Starter
Kelfa's Avatar
Sounds good guys, hopefully this will work smoothly. I'll update in a day or so when I get it.
Kelfa is offline
post #11 of 17 Old 03-09-2008, 11:19 PM
kraze98nyc's Avatar
Is this true even with a full offloading video card?
Emotiva XMC1 - Emotiva XPA2 - Emotiva XPA5 - 2 x GE Triton Two - GE Supersat 60c - 4 x GE Supersat 3 - 2 x Powersound XS30se - Epson 5030UBe - Dalite High Power
kraze98nyc is online now
post #12 of 17 Old 03-10-2008, 07:07 PM
KingLion's Avatar
Ok so an update here, That file that I had posted earlier from Nero, I think something is wrong with it. I have tried on my computer, a iMac 1.83Ghz Core Duo, 1.5GB Ram, and the new 24in iMac and a Quad Core mac Pro..."I work at Apple" and none of them played it smoothly. So I went to the Dark Knight official website and the download there 1080P.mov file and it played smoothly on the iMac 1.83Ghz. I then downloaded the file on iMac running Windows XP and it played smoothly in Windows Media....Still though, I cant play on my home computer so
KingLion is offline
post #13 of 17 Old 03-10-2008, 09:07 PM
Jesse S's Avatar
My old htpc was a p4 3ghz; it plays 720 and can't handle any 1080p.
My new (cheap) htpc is an e4500 overclocked a little (2.2@2.6ghz) and it can play all 1080p content using ffdshow.
There is a lot of hype about offloading dxva videocards but I think it's irrelevant when a cheapo $120 cpu can handle anything out there.
Jesse S is offline
post #14 of 17 Old 03-11-2008, 06:16 AM
h8redv2's Avatar
I have a P4 3.0 HT, 2048 MB DDR2, ATi HD2600XT PCIe.
I can do 1080p blu-ray/HD/DVD onto my philips tv 1x1 pixel @ 24Hz, no hassle.
My cpu is not doing overtime, GPU does it all...
h8redv2 is offline
post #15 of 17 Old 03-27-2008, 03:15 PM
chriscic's Avatar
Quoted: 21 Post(s)
What software are you using to play it? Thinking you need to use something that supports the acceleration, like PowerDVD, to do this. Thanks.
chriscic is offline
post #16 of 17 Old 04-02-2008, 01:06 PM
youngryu's Avatar
MPC-HC supports hardware acceleration. but files have to be dxva to support it.
youngryu is offline
post #17 of 17 Old 04-02-2008, 01:46 PM
kyungkim's Avatar
media portal + pdvd (and its h264 codec)
2.5ghz amd x2,
ati 2400
720p is cake, can do it all day long, 1080p every now and then pegs the cpu full and gets a little hitch. The nice thing is that audio never gets out of sync.
I think pdvd is an absolute necessity to do hd. The codec is invaluable, hd video is unplayable if I didnt have it.
kyungkim is offline
Reply Home Theater Computers
