I did the registry, i still can't get my DVD folders to show in Media Center? - AVS Forum
post #1 of 14 Old 03-30-2008, 07:01 PM - Thread Starter
yellow360f's Avatar
I checked it over and over again. I don't have a tuner, but that should not be a problem, right? Why doesn't my 2 DVD's that are ripped don't show. I have them in my local drive. The writeup says, right click or you should see DVD in the menu, i don't see either one. Right click won't show anything either. Plz help.
yellow360f is offline
post #2 of 14 Old 03-30-2008, 07:30 PM
kapone's Avatar
Liked: 39
This is what your registry settings should look like after the modifications.
- Note the path at the bottom of the image. That's where you should be making the changes.
- Note the "FolderSearchDepth" parameter. I have mine set to decimal 20, but you can choose to use whatever you want. (20 is a fairly safe number).
- After you have made the changes, reboot.
- If the changes your successful, you should have a "dvd library" icon on your "TV + Movies" strip. IF not, something went wrong.
- If it was successful, GO INTO the DVD library, THEN right click and select "Add Movies" and choose the folder where you stored your movies.
kapone is offline
post #3 of 14 Old 03-30-2008, 08:01 PM
AVS Club Gold
rdjam's Avatar
Hi Kapone - do you think you could link the thread that discusses this in detail? I'd like to apply this mod also!
rdjam is offline
post #4 of 14 Old 03-30-2008, 08:06 PM
umdivx's Avatar
umdivx is offline
post #5 of 14 Old 03-30-2008, 08:33 PM - Thread Starter
yellow360f's Avatar
I have done it correct. see the picture.
hmmmm. first step of HTPC and failed. oh well. should have known, it's darn microsoft product.
post #6 of 14 Old 03-30-2008, 08:38 PM
kapone's Avatar
Liked: 39
Does it show the "DVD Library" icon in the "TV + Movies" strip?
kapone is offline
post #7 of 14 Old 03-30-2008, 08:42 PM - Thread Starter
yellow360f's Avatar
No. nothing, just like the snap shot i posted earlier.
I can open powerdvd , browse to those folders and play them. The files have been ripped using dvd shrink. Dvd shrink creates the Video + Audio folder. Also, i don't have a high end video yet, but powerdvd plays the dvds just fine.
also no tuner yet. I don't believe tuner or video card can affect the DVD not showing up.
could it be ripping from DVD shrink?
post #8 of 14 Old 03-30-2008, 08:47 PM
kapone's Avatar
Liked: 39
Do you have a DVD Drive in this machine? The reason I ask is because, by default it should have a "Play DVD" option in the "TV + Movies" strip This is what changes to DVD Library, but I don't see a Play DVD in your screenshot either.
Try going into Settings and run the Express setup once again, and then reapply the registry changes (and reboot).
kapone is offline
post #9 of 14 Old 03-30-2008, 08:49 PM - Thread Starter
yellow360f's Avatar
I do have 2 dvd writer/burner +- all the options that come with the DVD. it's not the Blue-ray , just regular dvd burner/player.
this is a new install of vista ultimate, interesting that it doesn't show play DVD.
I am really confused now.
thanks again.
post #10 of 14 Old 03-30-2008, 10:33 PM - Thread Starter
yellow360f's Avatar
The video card had 32mb, i guess for DVD (even though powerdvd works just fine), media center wanted 64mb or more for the DVD option to show up on the menu. I installed a 64mb agp video card i had and the DVD menu came up.
post #11 of 14 Old 04-22-2008, 01:09 PM
wsharp's Avatar
I'm having this exact same problem but with a brand-new HP 9200T machine. Vista SP1 plus BluRay/HD drive and a custom HP BluRay/HD player integrated into the Vista media center interface.
This green button thread has someone with the same issue and said it was a registry setting (different than the "Gallery" one) that is specific to new HP machines with BluRay/HD drives. Does anyone know what the registry setting is?
thegreenbutton.com/forums/257922/ShowThread.aspx#257922
FWIW, HP has nicely integrated their BluRay/HD playback software right into the interface. But I can't get it to play any of ripped DVDs.
wsharp is offline
post #12 of 14 Old 04-22-2008, 03:34 PM
gtfoltz's Avatar
I'm having the problem too. Just installed Vista Home Premium, and pointed VMC to my ripped DVDs, and it doesn't see them. I'll try this registry trick tonight. Thanks.
gtfoltz is offline
post #13 of 14 Old 04-28-2008, 06:18 AM
wsharp's Avatar
I finally tracked down the new key by comparing two HP machines I have (one with BluRay and one without) using Process Monitor. Setting this key to "0" makes the DVD Library show up after the "Gallery" key change.
HKLM\\SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Media Center\\Start Menu\\HideDVD
wsharp is offline
post #14 of 14 Old 04-28-2008, 08:19 AM
gtfoltz's Avatar
Well, I never did get mine to show up either--I just installed MyMovies instead, and it found them just fine...
gtfoltz is offline
Reply Home Theater Computers
User Tag List
