Help with dual monitor function - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-01-2008, 09:23 AM
A&M 350Z's Avatar
I am trying to use my Mits 62525 DLP and a Samsung LCD monitor together with a cloned screen for use with XLobby or Media Center. I have a Radeon X300 with the monitor via DVI and Mits via VGA. I can not for the life of me get a good image on the Mits. I get blurry screen and usually zoomed in. It seems when I use ATI's control panel I have to use the same resolution for both screens. I have tried powerstrip, created some custom resolutions but cant seem to use it with the clone monitor feature. Suggestions? Do I need a better video card?
A&M 350Z is offline
post #2 of 8 Old 04-01-2008, 09:30 AM
James Mos's Avatar
You're correct that if you use the clone function, you have to have the same resolution on both displays, that's why I use the extended desktop option for my projector and I have 1680 x 1050 on my monitor and 1360 x 768 for my projector.
James Mos is offline
post #3 of 8 Old 04-01-2008, 09:44 AM
umdivx's Avatar
umdivx is offline
post #4 of 8 Old 04-01-2008, 09:53 AM
A&M 350Z's Avatar
I will try that. The extended monitor seems to work okay but then I would have to drag the htpc frontend from the monitor to the TV which is slight more cumbersome. Is there a way to make an app automatically open on the extended screen?
A&M 350Z is offline
post #5 of 8 Old 04-01-2008, 10:28 AM
A&M 350Z's Avatar
That worked sorta. It wont clone media center for some reason and the screen is still unclear
A&M 350Z is offline
post #6 of 8 Old 04-01-2008, 10:41 AM
umdivx's Avatar
well its probably because MCE is VMR9 and Ultramon can't clone screens running in VMR9.
I'd say do extended mode and call it a day, that or don't do a dual monitor setup.
- Josh
umdivx is offline
post #7 of 8 Old 04-01-2008, 11:04 AM
A&M 350Z's Avatar
Agreed. I do think it is odd that such an easy function cant be accomplished!
A&M 350Z is offline
post #8 of 8 Old 04-01-2008, 05:39 PM
James Mos's Avatar
I believe I read on the green button dot com's site that someone found an application that can program those extra colored buttons on the MCE remotes to launch a setting in the catalyst software that would accomplish either moving a certain program to the 2nd monitor or changing the setting from extended to clone or something like that. I wish I could remember the thread it was on, but I'm sure you could ask on that forum.
Reply Home Theater Computers
