Hauppauge WinTV HD PVR (H.264) screenshot - Page 174 - AVS Forum | Home Theater Discussions And Reviews
post #5191 of 5201 Old 06-13-2012, 06:45 PM
rebkell's Avatar
Quoted: 413 Post(s)
Liked: 285
Originally Posted by Swederic View Post
Same issue for me and also the same cure: new power supply Works great now!
That cured mine, same symptoms, 5V and 2.0Amps or more amps. My original PS was 5V@3.0A, but the specs only call for 5.0V@2.0A ... I found an old 5.0V@2.0A and it's been working fine ever since(that was a month or so ago.
rebkell is offline
post #5192 of 5201 Old 06-13-2012, 08:42 PM
m. zillch's Avatar
Quoted: 1958 Post(s)
Liked: 1244
Pareidolia.
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #5193 of 5201 Old 06-22-2012, 11:16 AM
ncinsguy's Avatar
new power supply did the trick
ncinsguy is offline
post #5194 of 5201 Old 06-22-2012, 12:50 PM
Ralarcon's Avatar
Quoted: 169 Post(s)
Liked: 132
Originally Posted by m. zillch View Post
Pareidolia.
Well, it seems to be working where it did not before , so there must be something to it.
Cheers
Ralarcon is offline
post #5195 of 5201 Old 02-13-2014, 08:48 PM
lbeck's Avatar
I have the Hauppauge and have been successful in recording video from my Dish VIP722.  I also have a roku player, a DMPBDT330 HD dvd player and AppleTV, which have only HDMI out.  I'm considering purchasing a KanexPro HDMI to Component Converter so that I can record video through the Hauppauge.  Will HDCP encryption prevent me from doing this?  If so, is there anything that can go HDMI -> component or composite?
lbeck is offline
post #5196 of 5201 Old 02-13-2014, 10:35 PM
nikknightt's Avatar
Quoted: 69 Post(s)
Liked: 27
I have an HD Fury for such things. However, I dont think theyre available in the USA any more.
Try this thread for more help. This thread hasnt been active in a long time..
http://www.avsforum.com/t/1055232/hauppauge-hdpvr-1212-owners-thread/3750#post_24086643
I've heard theres a HDMI splitter that will solve your problem. videohelp.com might be a good place to research too.
nikknightt is offline
post #5197 of 5201 Old 04-16-2015, 02:22 PM
AllenDB's Avatar
Quoted: 46 Post(s)
RCTVCAP & Builder
From the dark ages of rctvcap and rcgraphbuilder. My HTPC bit the dust in a major way a month ago. Its resurrection seemed a difficult task so I opted for the DVR option from DirecTV. While impressed with its capabilities I need to get the HTPC back up and running. I use rctvcap to record off two DTV boxes. To get rctvcap to run in the past I used rcgraphbuilder.
Now when I run rcgraphbuilder I get the dreaded "can't find filter: File Dump". Having grown a bit older since the early 2000 I can't remember how to get around this problem.
Somebody out there remember????
Please and thank you.
AllenDB is offline
post #5198 of 5201 Old 04-16-2015, 03:10 PM - Thread Starter
SHS
SHS's Avatar
Quoted: 64 Post(s)
http://www.shspvr.com/graph_build/download/dump.zip
SHS is offline
post #5199 of 5201 Old 04-16-2015, 03:31 PM
AllenDB's Avatar
Quoted: 46 Post(s)
RCGraphBuilder
Originally Posted by SHS View Post
Thank you. I tried the file to no avail. Looking at the contents it almost looked like an executable???
AllenDB is offline
post #5200 of 5201 Old 04-16-2015, 03:35 PM
AllenDB's Avatar
Quoted: 46 Post(s)
I don't remember if I have to run RCGraphBuilder in a special; way to direct it to File Dump.
You sent a file labeled Dump. If I recall correctly RCGraphBuilder looks for a file "File Dump". I've got one but it is zero length, empty. ?????
AllenDB is offline
post #5201 of 5201 Old 04-16-2015, 06:48 PM - Thread Starter
SHS
SHS's Avatar
Quoted: 64 Post(s)
The file has be register like below at command prompt in administer mode like regsvr32 -u dump.ax if you drop in system32 folder or get RadLight Filter Manager
SHS is offline
Reply Home Theater Computers
