Hauppauge WinTV HD PVR (H.264) screenshot - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 5201 Old 04-29-2008, 07:13 PM
cybrsage's Avatar
Liked: 154
Originally Posted by SHS View Post
Only MCE honor CGMS-A
Vista Media Center?
And what does this actually mean to me? All I want to do is basically time shift...record now, play later, pause, etc. All from the same box.
And all from within the VMC front end, using the Microsoft remote.
cybrsage is offline
post #182 of 5201 Old 04-29-2008, 07:26 PM - Thread Starter
SHS
SHS's Avatar
Quoted: 57 Post(s)
Originally Posted by cybrsage View Post
Vista Media Center?
MCE = VMC
What dose it mean to you with CGMS-A
No HBO recording or any other channel that have it ON.
SHS is offline
post #183 of 5201 Old 04-29-2008, 08:11 PM
ChrisL01's Avatar
Your assuming...
a) HD-PVR support is coming from Microsoft
b) CGMS-A is actually being put on broadcasts by STBs
c) That when Hauppauage develops drivers they will respect CGMS-A.
So, with that in mind...
a) It's not coming from Microsoft, in fact I don't think they are providing a direct development path for such a tuner.
b) Are they?
c) Sure seems like it would be easy for them to ignore it.
Chris
ChrisL01 is offline
post #184 of 5201 Old 04-29-2008, 08:44 PM
stanger89's Avatar
Quoted: 2634 Post(s)
Liked: 1354
a) When MS adds support for it, you think they won't support it.
b) How many problems have we seen about CGMS-A from STBs with current cards, it would seem that boxes are outputting it now.
c) My impression is the card/drivers don't have to do anything special to support it, if they did, I wouldn't think it would work with current cards. Yet it does, so this leads me to believe it's buried in the audio or video data (like CC data).
stanger89 is offline
post #185 of 5201 Old 04-29-2008, 09:01 PM
ChrisL01's Avatar
a) I don't see why Microsoft would support it. They have a model for supported tuner cards for Media Center. Component capture isn't on that list. I don't think you will see support coming from Microsoft. Hauppauage is going to get lucky that Microsoft is adding H.264 support in Media Center, I think the rest will be a backdoor hack on Hauppauage's part.
b) I don't think you have see any problems in Media Center with CGMS-A being output on Component. Does CGMS-A on S-Video = CGMS-A on Component? Again, I don't know.
c) I don't understand what you are saying here, but if your talking about CGMS-A then it's VBI. What "current cards" do I don't know, I've never owned a Component capture card. Of course, if Hauppauage is taking it upon them selves to hack support into Media Center, then why respect CGMS-A even if it is being output? It could also be striped in the H.264 encoding process.
The key thing here is that Media Center doesn't currently do anything with Component capture as well as nothing with H.264. Both of these would be new to Media Center, and it has not exactly been developed around either. H.264 support is coming, but we have no idea what that in tells from a development perspective. I highly doubt the HD-PVR can parade as a standard analog tuner to Media Center and work correctly, which means it is very likely Hauppauage is going to do something behind the scenes t have it work correctly.
Chris
ChrisL01 is offline
post #186 of 5201 Old 04-29-2008, 09:25 PM
zaphod7501's Avatar
Quoted: 78 Post(s)
Liked: 65
B: CGMS-A is definitely being put out by STBs. There have been numerous reports of recordings blocked, locked, or encrypted when Media Center records (or attempts to record) premium channels or even AMC at times from the composite or S-Video STB connections.
C: Hauppauge has never built any DRM into any of it's drivers yet. All restrictions have come from the recording software application - generally Media Center.
A: Media Center should treat the HD-PVR like it does any STB capture device. Pick channels from an EPG and use a Blaster to control the STB. In place of a typical hardware mpeg capture card it would use the HD-PVR. Support would only be needed in the form of an upgrade to recognise the HD-PVR the same way it recognises any new capture card and video decoders for playback/viewing. It's not recording "Component", it's recording a .ts stream and it may just record it the same way it records from the HDHomerun.
While many have speculated that there is no way to add CGMS-A to Component connections, I sure wouldn't bet the farm on it. If it can be added to composite video, then it can be present on component video. The "Y" cable contains standard video + sync, albeit at potentially higher frequencies. A 'scope of the signal ought to look exactly like Composite luminance, just at a different horizontal range setting.
This might actually be partially testable.
Pick a channel sure to be restricted. (HBO?)
Set the STB to 480i output.
Connect the Y (Green) cable to the composite input of your capture card. (It'll be in Black and White)
Attempt to record with Media Center.
Whether any potential flag gets carried through when Component is converted to H264: I couldn't guess.
Sturgeon's Law: "Nothing is always absolutely so."
Sturgeons Revelation: "Ninety percent of everything is crud."
My Thoughts: "A reasoned argument must share some basic common points."
zaphod7501 is offline
post #187 of 5201 Old 04-29-2008, 10:16 PM
ChrisL01's Avatar
I'm not questioning the existence of CGMS-A. I can tell you for a fact that some STBs output it and some remove it. This is present using Coax or S-Video (never tried Composite).
I'm questioning if CGMS-A is output on Component from STBs. I really have no idea.
Do realize that HDHR is a hack, which kind of defines my overall point.
It's on VBI, so yes it can be on Component (or S-Video, or DVI, etc).
Right now I'm questioning this the most. VBI data is encoded into the video stream, but that original video stream is going to be decompressed (eg. raw) and then recompressed to H.264 while still in the HD-PVR (so before it gets to software).
Unless the HD-PVR is actually examining the video contents, I assume it would just disregard anything on VBI (which would include CGMS-A). Of course, if this is the case then closed captions wouldn't be possible using the HD-PVR.
If anyone knows anything about VBI I'd love to know.
Chris
ChrisL01 is offline
post #188 of 5201 Old 04-29-2008, 11:11 PM
vladd's Avatar
Liked: 39
Not when it's run in OTA mode. It's simply another ATSC tuner at that point with regular BDA drivers. Still streaming .ts in that mode too. The fact that it streams it over ethernet instead of a usb cable is not exactly something I would consider a "hack".
vladd is offline
post #189 of 5201 Old 04-29-2008, 11:24 PM
B Leisle's Avatar
Correct me if I'm wrong, but I think what Chris is saying is the HDHR doesn't actually use a BDA driver, it's a hodgepodge that masks itself as a BDA driver to the software you're using. That's why you have (had?) to tinker with it for it to work with some apps like BeyondTV.
B Leisle is offline
post #190 of 5201 Old 04-30-2008, 12:58 AM
mindbender9's Avatar
Originally Posted by mindbender9 View Post
I apologize in advance for asking what seems to be a dumb question, but how exactly do you burn the video streams (*.ts format?) to a DVD?
I know that the unit comes with bundled software (ArcSoft TotalMedia Extreme), but how do you use it? Are you able to burn the video streams to a 4.7GB DVD?
Wow, that was more that one dumb question, wasn't it?
So does anyone know how to use this unit? All I want to do is burn video feeds from a SA8300HD DVR to a 4.7GB DVD. So how do you do this? Thanks!
Bump
"I was thinking of the immortal words of Socrates, who said: 'I drank what?' " - Real Genius, 1985
mindbender9 is offline
post #191 of 5201 Old 04-30-2008, 06:14 AM - Thread Starter
SHS
SHS's Avatar
Quoted: 57 Post(s)
Bump
mindbender9 I made a reply go back to page 9 see the post I made
SHS is offline
post #192 of 5201 Old 04-30-2008, 06:15 AM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Exactly. The HDHR certainly has a BDA driver, whether in ATSC mode or Digital cable mode. In fact all it is IS ATSC, to MC when you have an HDHR connected. Whether it's pulling direct ATSC, or using their channel mapping to pull content from digital cable, to MC, it's still ATSC and a perfectly valid BDA tuner/driver.
From Hauppage's perspective, what they "ideally" need to do is have a BDA driver, and if/when MC supports H.264, the card "should" work like any other tuner. Another thing to ponder is whether the card even needs to be recognized as "analog" or a digtal card. Once MC has H.264 support, there's no logical reason, the Hauppage card should be considered "analog". It can be a perfectly valid digital tuner card that supports h.264, the fact that it uses component capture as input should have no bearing on MC.
I believe, it will all boil down to Hauppage for writing the right drivers, and MC to support H.264.
kapone is offline
post #193 of 5201 Old 04-30-2008, 06:27 AM
cybrsage's Avatar
Liked: 154
MCE = VMC
Not even a record once type?
If this is the case, then Hauppage is going to lose the lion's share of HTPC users.
cybrsage is offline
post #194 of 5201 Old 04-30-2008, 07:37 AM - Thread Starter
SHS
SHS's Avatar
Quoted: 57 Post(s)
It not up to Hauppage they have fellow rule under MS guild line and well know law DMCA anti-circumvention provisions.
That all depend on the channel station boardcast which can be no copies, one copy, or unlimited.
SHS is offline
post #195 of 5201 Old 04-30-2008, 07:47 AM
ChrisL01's Avatar
SHS: Do we know if the HD PVR supports closed captions?
Chris
ChrisL01 is offline
post #196 of 5201 Old 04-30-2008, 10:24 AM
ak3883's Avatar
I don't think the Hauppauge will be required by law to honor CGMS, since it is not a DVD recorder, but like many have mentioned, if they want to get support for the device in MCE down the road, then they might have to.
If the hardware doesn't even support it, then they can't make a future version of their software support it, but if they build in support in the hardware, could they just enable it in a certain version of their software or some kind of update to make it work with MCE?
I wish this thing would ship already, getting antsy
ak3883 is offline
post #197 of 5201 Old 04-30-2008, 10:57 AM
IowaBrian's Avatar
You can use videoredo to convert .ts to mpeg sometimes it works (720P) and does a good job and sometimes it sucks and tells me no stream(many but not all 1080i) found. nothing is 100% in this game...and everyone has a different program that they like for different reasons... best bet it to get trail download test it and buy it if you like it... now back to our regular topic
IowaBrian is offline
post #198 of 5201 Old 04-30-2008, 11:30 AM
Ah. Thank you for your assistance. I'll take a look at the Ulead software that you mentioned. I appreciate your help!
post #199 of 5201 Old 04-30-2008, 11:54 AM
vladd's Avatar
Liked: 39
When it first came out there were no BDA drivers which is why developers were working on ways to get it working in the various apps. I worked on the GBPVR support myself. BDA drivers were released later. It is an actual BDA driver.
The "hack" (which is the wrong term since no MCE compiled files are modified) is that when tuning QAM, it remaps the channel to the 2-69 RF range since Media Center (and a couple others) will only tune in that range.
It also reencapsulates the stream to be ATSC compliant but that is because of other issues.
No tinkering is involved when tuning ATSC OTA. Much less tinkering is involved for QAM than there used to be.
vladd is offline
post #200 of 5201 Old 04-30-2008, 02:51 PM
ChrisL01's Avatar
Chris
Got an answer from Hauppauge...
"At the moment the software doesn’t display or record the close caption data."
This would tell me that (currently??) they are not doing anything with VBI, so the CGMS-A data wouldn't even make it to the PC for interpretation by Media Center.
Interested what they mean by "at the moment" though. Implies that it might be able to read the VBI data (in relation to closed captions).
Chris
ChrisL01 is offline
post #201 of 5201 Old 04-30-2008, 04:52 PM
B Leisle's Avatar
Ah, ok.....that sounds right. Been a while since I followed the HDHR stuff.
"At the moment the software doesn't display or record the close caption data."
Chris
Also, that they noted their software couldn't currently do it, but no mention of the hardware.
B Leisle is offline
post #202 of 5201 Old 04-30-2008, 05:02 PM
ak3883's Avatar
Chris
Interesting. Could mean 2 things:
1. The software just doesn't support it yet, but might later on(leaving open the possibility of honoring CGMS in a future update/version)
2. No support for closed captions because the VBI isn't even read in the hardware, so it wouldn't even see the CGMS, along with the cc.
Unfortunetly the answers from their support are usually wide open to interpretation on everything from multiple unit support, to this, to the actual ship date.
ak3883 is offline
post #203 of 5201 Old 04-30-2008, 05:42 PM
stanger89's Avatar
Liked: 1354
My last word on the whole CGMS-A "issue"...
I say look to the SD cards for what to expect. They don't "support" CGMS-A in that they don't do anything special with it, they just record the video (VBI included) and create a video file. It's Windows Media Center (the app) that views/interprets the CGMS-A flag in the VBI (or wherever it resides) and adds the rights management to it.
The same cards that MCE "supports" CGMS-A with, work without it in other apps (SageTV, etc), the card/drivers don't do anything with it.
I see no reason to expect the HD PVR to be any different. I'd bet that there will be no CGMS-A support with the HD PVR in most apps, and if/when it works in Media Center, I would not be surprised if it MCE supported it.
post #204 of 5201 Old 05-01-2008, 03:04 AM
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
This is what CGMS-A and EIA-608 closed captioning look like. CGMS-A is on line 20 (in both fields) and closed captioning is on line 21 (in this example, just in the first field). This image was created by moving the capture window up 12 lines on an MPEG-2 encoder.
A correctly aligned SD MPEG-2 (or H.264) encoder does not encode the VBI. However, it is captured and processed. For CGMS-A, the encoder may be disabled or the output stream encryption turned on. For closed captioning, the data is inserted into picture_user_data (or gop_user_data for DVD recordable).
There is a standard for CGMS-A on 720p and 1080i component outputs. Is is CEA-805C. Whether STB's actually implement CEA-805C remains to be seen
There is no standard for analog closed captioning on 720p or 1080i component outputs.
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is online now
post #205 of 5201 Old 05-01-2008, 05:42 AM
TomsHT's Avatar
I have a question, I dont have an HTPC but I do have a PC elsewhere in the house with XP & media center also with a Blu-ray burner drive. What I would like to do is, take some high def sports games on my cablebox dvr, transfer them to my PC and burn on a BR disc to keep in high def? Will this product enable me to do this?
TomsHT is offline
post #206 of 5201 Old 05-01-2008, 06:51 AM
dsinger's Avatar
Quoted: 316 Post(s)
Liked: 320
Ron: Please excuse my ignorance. As a practical matter, if my STB has a copy once flag on HBO and I try to capture a movie saved to my HD on the box (SA8300HD) will I get a picture like in your example or will I get nothing that is useable at all? By using the resizing feature on my video processor, I can move the lines up and out of the viewable picture. Thanks
dsinger is offline
post #207 of 5201 Old 05-01-2008, 07:05 AM
bdraw's Avatar
Quoted: 161 Post(s)
Liked: 70
Originally Posted by schmoppa View Post
What separates consumer from professional? Price, or price and complexity?
Depending on those factors it still could be an option for us. What's a ballpark cost for one, and do you know of a an example make/model?
Looks like something close is about to come out, but not quite.
http://www.engadgethd.com/2008/05/01...-to-your-hdtv/
Ben
How good could it be if it isn't HD?
No longer contributing to Engadget HD
bdraw is offline
post #208 of 5201 Old 05-01-2008, 07:09 AM
cybrsage's Avatar
Liked: 154
I will take the "wait and see" approach to this product now.
I hope I can use it to record in VMC, but it is starting to look like another failed product.
Time will tell, I have not written it off yet.
cybrsage is offline
post #209 of 5201 Old 05-01-2008, 08:00 AM
stanger89's Avatar
Liked: 1354
If you can see it on your TV, you can record it with this, the (cable) box has no idea it's not connected to a TV.
Why is that, because VMC doesn't support it now? There's lots of products that are successful that VMC doesn't support. It's a bit arogant to think that a product can't succeed without VMC support.
How can it be failed, when it's exactly the product that has been asked for twice a day on this forum for the last five years.
post #210 of 5201 Old 05-01-2008, 10:17 AM
B Leisle's Avatar
It's really just semantics. One person's definition of failed may be very different from anothers. IMO, if a product does what it's advertised to do, it's not a failure from a customer perspective. However, if a company producing a product is predicting they'll sell X number of units and only sell 25% of their target, then that would generally be considered a failure from the manufacturer's perspective.
B Leisle is offline
Reply Home Theater Computers
