Hauppauge WinTV HD PVR (H.264) screenshot - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5201 Old 04-04-2008, 06:56 AM - Thread Starter
SHS
SHS's Avatar
Quoted: 57 Post(s)
Yes it has been delayed to May -June
SHS is offline
post #2 of 5201 Old 04-04-2008, 07:00 AM
ChrisL01's Avatar
Are those dual inputs?!?
Chris
ChrisL01 is offline
post #3 of 5201 Old 04-04-2008, 07:02 AM - Thread Starter
SHS
SHS's Avatar
Quoted: 57 Post(s)
Yes
SHS is offline
post #4 of 5201 Old 04-04-2008, 07:02 AM
JoelGordon's Avatar
Probably passthrough.
JoelGordon is offline
post #5 of 5201 Old 04-04-2008, 07:03 AM
cybrsage's Avatar
Liked: 154
It is quite pretty, really. I had hoped it would not be butt ugly.
I wonder if I can control it with my MCE remote...using one of the IR buds from it.
cybrsage is offline
post #6 of 5201 Old 04-04-2008, 07:10 AM
ChrisL01's Avatar
Originally Posted by SHS View Post
Yes
Wow, that's unexpected. If it has dual inputs and is still expected to go for ~$250 or so this looks 100% better to me then it did before.
Chris
ChrisL01 is offline
post #7 of 5201 Old 04-04-2008, 07:16 AM - Thread Starter
SHS
SHS's Avatar
Quoted: 57 Post(s)
ChrisL01 I find out for sure if it dual inputs but farI can tell it look like a dual inputs but then agiane as JoelGordon said Probably one is passthrough
SHS is offline
post #8 of 5201 Old 04-04-2008, 07:25 AM
Fonceur's Avatar
Indeed the second sets of component connectors are most likely outputs, based on another report that "The second SPDIF connector is labeled on the PCB as SPDIF out."
Fonceur is offline
post #9 of 5201 Old 04-04-2008, 07:39 AM
StanF's Avatar
So how will this work? Is it intended to work with WinTV? If so, how will you change the channel? I do not see any IR ports where you could pass the IR signal to the settop box (unless there is a single port by the USB port).
Will it come with MCE or VMC drivers and look like a capture card over the USB port if someone wants to use it like that? Same thing with the optical SPDIF - one input and one output. Coaxial SPDIF would have been nice too.
If it integrated well with digital cable and MCE 2005, then I would be more likely to upgrade to digital cable from the analog cable I have now. (I currently get my local HD channels with an ATSC tuner)
I agree with the other poster that the component connectors are likely pass-thru - one set in and one set out.
StanF is offline
post #10 of 5201 Old 04-04-2008, 08:03 AM
ilkhan4's Avatar
It looks like there's an IR emitter jack between the optical port and the USB port.
ilkhan4 is offline
post #11 of 5201 Old 04-04-2008, 08:06 AM
DVDO+WESTY=1080p's Avatar
where is the screenshot?
DVDO+WESTY=1080p is offline
post #12 of 5201 Old 04-04-2008, 08:07 AM
nevermind probs with my PC
post #13 of 5201 Old 04-04-2008, 08:12 AM
tsb
tsb's Avatar
looks very nice
if it integrates perfectly into VMC I may jump
I still may wait for a similar unit that can encode with higher bitrates though
tsb is offline
post #14 of 5201 Old 04-04-2008, 09:01 AM - Thread Starter
SHS
SHS's Avatar
Quoted: 57 Post(s)
There is only one set of Component, RCA Audio and SPDIF connector inputs. The set above are the loop throughs.
SHS is offline
post #15 of 5201 Old 04-04-2008, 09:02 AM
ChrisL01's Avatar
Dang. Thanks for the conformation.
Chris
ChrisL01 is offline
post #16 of 5201 Old 04-04-2008, 09:05 AM - Thread Starter
SHS
SHS's Avatar
Quoted: 57 Post(s)
By the way a Pre-order page should be up today I post a link to it here
SHS is offline
post #17 of 5201 Old 04-04-2008, 10:24 AM
gjvrieze's Avatar
Very cool pictures, a question I have though: will it only output h.264 to the pc or can it pass mpeg2 straight through??
And, has the unit been made ready to Sage TV so that support is in place?
KD0MOF
All opinions expressed (unless otherwise noted) are the poster's only and NOT that of the poster's employers.
gjvrieze is offline
post #18 of 5201 Old 04-04-2008, 10:44 AM
cybrsage's Avatar
Liked: 154
How long until a Vista Media Center plug in?
I also want to use my MCE remote to change channels, etc. I can just have my cable box change the channels, and let the HD PVR be just a pass through device to the MCE.
Will the preorder page also include specs, user manual, etc., so we can read up on it?
Delaying until June is a good thing, I am out of money!
cybrsage is offline
post #19 of 5201 Old 04-04-2008, 11:50 AM - Thread Starter
SHS
SHS's Avatar
Quoted: 57 Post(s)
A new HD clip made at the Cebit show from HD satellite this 80MB file
ftp://ftp.shspvr.com/download/moive_..._1080i_h264.ts
SHS is offline
post #20 of 5201 Old 04-04-2008, 12:59 PM
replayrob's Avatar
Quoted: 666 Post(s)
Liked: 626
The Box looks nice, but.....
Really wish Hauppauge would spend another 50 cents to upgrade that ancient retread $2 remote. I have the same one from their Media MPV device and another clone of it from my Hauppauge Satellite card. I'm sure if I dug my old Hauppauge PVR card out of the attic... it would be the same old tired $2 remote. Looks like every other Chinese el-cheepo remote on the market.
C'mon Hauppauge, time to update your product with a better remote.
“You cannot play God and then wash your hands of the things you created.”
Commander Bill Adama
replayrob is offline
post #21 of 5201 Old 04-04-2008, 01:12 PM
MKANET's Avatar
Quoted: 50 Post(s)
Liked: 24
Didn't those screenshots come from Andy at SageTV?
Edit: It might have been you SHS... a friend sent me this link:
http://feeds.engadget.com/~r/weblogs.../~3/264117565/
MKANET is offline
post #22 of 5201 Old 04-04-2008, 01:46 PM - Thread Starter
SHS
SHS's Avatar
Quoted: 57 Post(s)
S-Video and Composite inputs it's on the front, but was hidden behind the remote control.
SHS is offline
post #23 of 5201 Old 04-04-2008, 01:47 PM - Thread Starter
SHS
SHS's Avatar
Quoted: 57 Post(s)
No image they are from Hauppauge the image are link to shspvr.com and it where I put them.
The Real image are really big 2100x1400
SHS is offline
post #24 of 5201 Old 04-04-2008, 01:57 PM
MikeSM's Avatar
Awhile. VMC doesn't support h.264 now.
If you are using MCE, then you don't care what the remote is on the unit itself. It'll get controlled through the VMC plugin in any case. But I think you'll have a while to wait for h.264 support, so it can slip quite a bit more and still not affect the VMC schedule.
MikeSM is offline
post #25 of 5201 Old 04-04-2008, 05:40 PM
cybrsage's Avatar
Liked: 154
Heck, I would be happy with a program which launches from VMC and plays the items, then returns me to VMC when it is done. I am not picky.
It just has to be integrated, so the wife can use it without having to call me to walk her through it each time.
cybrsage is offline
post #26 of 5201 Old 04-04-2008, 06:09 PM
chillspace's Avatar
Product info is up on the website now.
http://www.hauppauge.com/site/products/hd_pvr.html
I don't see a pre-order link yet. Nothing on their online store, either.
Eric
Eric
My Stuff: Panasonic TC-P65ZT60 w/  Ideal-Lume Bias Lighting, Yamaha RX-V3800, Oppo BDP-103D
chillspace is offline
post #27 of 5201 Old 04-04-2008, 07:30 PM - Thread Starter
SHS
SHS's Avatar
Quoted: 57 Post(s)
pre-order link is not ready chillspace
SHS is offline
post #28 of 5201 Old 04-04-2008, 09:46 PM
Hatecrime69's Avatar
Eric
that confirms the jacks in the back at least, there loop-though, not dual-input..ir blaster too
Is this one meant as a regular usb pvr or is it control on your pc, watch on your tv kind of thing? (if the first, wouldn't usb be a bit bandwith limited for it?)
Hatecrime69 is offline
post #29 of 5201 Old 04-04-2008, 10:09 PM
sodaboy581's Avatar
Quoted: 25 Post(s)
Liked: 38
The loop through ports... those are for showing the same image on another source, right?
If I'm guessing right, and please correct me if I'm wrong, I could connect the my XBox360 through component on the HD-PVR then use the loop through out to my TV, so I could capture using the card while playing it on the TV. (So there's no problem with timing and delay for game play purposes..)
Samsung UN65KS800, Denon AVR-X2300W, Polk CS20 Center, Polk Monitor 75T Fronts, Polk TSI300 Rears, Power Sound Audio S1500 Subwoofer.
sodaboy581 is offline
post #30 of 5201 Old 04-04-2008, 10:18 PM
tsb
tsb's Avatar
very unimpressive
tsb is offline
Reply Home Theater Computers
