MKV issues "cannot render the file"; CCCP installed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-26-2008, 10:42 PM - Thread Starter
gbajramo's Avatar
I can't play some of the newer mkv files I've got from different sources. Majority of my other mkvs play fine.
When I test newer ones in VideoInspector only info I get is
Valid: No
MPC says "Cannot render the file"
In VLC the slider is moving very quickly as in FF.
Files are x264 720p or 1080p from description.
I have the latest CCCP installed.
Any suggestions on steps to determine if problem is with file corruption or with my system?
gbajramo is offline
post #2 of 5 Old 04-27-2008, 01:38 AM
redondoman's Avatar
Maybe your latest downloads are bad. (nt)
redondoman is offline
post #3 of 5 Old 04-27-2008, 05:47 AM
arfster's Avatar
Probably the sound rather than the video. If that's the case you can try downmixxing it to just plain stereo (in VLC/MPC or via ffdshow), and see if it helps.
arfster is offline
post #4 of 5 Old 04-27-2008, 08:26 PM - Thread Starter
gbajramo's Avatar
Is there a way to be certain?
gbajramo is offline
post #5 of 5 Old 04-27-2008, 08:26 PM - Thread Starter
gbajramo's Avatar
In VLC audio menu is empty. No tracks, no choices.
gbajramo is offline
Reply Home Theater Computers
