Playing MKV files through VMC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 74 Old 04-27-2008, 05:24 PM - Thread Starter
MoX
MoX's Avatar
I have searched other threads for answers to my problem but have not been able to find a solution.
I have some MKV files that i can play fine when not in VMC buy using core AVC and media player classic but when i go into VMC to play the file it says it was unable to locate or open the correct codec.
Has anyone else had success with getting MKV files to play through VMC ??
MoX is offline
post #2 of 74 Old 04-28-2008, 09:58 AM
huskerpat's Avatar
rename the extension to avi.
Life is tough, but it's tougher when you're stupid. - John Wayne
huskerpat is offline
post #3 of 74 Old 04-28-2008, 10:15 AM
d60pdp's Avatar
You can use CCCP
d60pdp is offline
post #4 of 74 Old 04-28-2008, 11:18 AM
umdivx's Avatar
First you need to edit the registry so that VMC can recognize the .mkv extensions.
The what I did to get 100% smooth playback was to install Haali splitter and core AVC. If you have FFdshow installed make sure you have vc-1 and h.264/x.264 decoding disabled in FFdshow codec settings.
Once you do all that you should be able to get 100% smooth .mkv playback in VMC.
- Josh
umdivx is offline
post #5 of 74 Old 05-16-2008, 10:44 AM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Im interested in backing up my HDDVD's and Blurays to my HDD. Will VMC recognize them in the DVD library??
Has anyone gotten this to work??
Xzener
xzener is offline
post #6 of 74 Old 05-16-2008, 05:25 PM
archer75's Avatar
Quoted: 187 Post(s)
Liked: 73
VMC uses different decoders. What I had to do is use radlight filter manager to set the priority of various directshow filters to get it to work.
Nvidia Shield Android TV, 2x Roku 3's, 1st and 2nd gen chromecast, Amazon Fire TV stick 2nd gen, Apple TV 4, Vizio M602i-B3, LG OLED65B6
Retired - HTPC: Intel e6300 2.8ghz, Intel DG45ID, 2gb DDR2, Radeon 5570, MCE IR receiver, Yamaha RX-V663 receiver via HDMI, panasonic ax100u, 145" S-I-L-V-E-R painted screen,
archer75 is offline
post #7 of 74 Old 05-16-2008, 11:23 PM
crabnebula's Avatar
Media Player Classic has its own internal filters and decoders, which include a Matroska splitter and an H264 decoder, so succesful playback there doesn't mean other apps like Media Center will be able to play them.
As pointed out above, you should install the Haali Media Splitter which can split .mkv files, and if you already have CoreAVC installed you're already covered for the decoding portion.
Also, you can associate .mkv files with Media Center by right-clicking on a file, choosing Open With... and selecting Media Center. No need to edit the registry.
crabnebula is offline
post #8 of 74 Old 05-16-2008, 11:27 PM
crabnebula's Avatar
No, VMC will not see them. However with My Movies you can rip your discs and browse your library through the VMC interface, although you need PowerDVD to play them. My Movies will launch it automatically for you.
post #9 of 74 Old 05-17-2008, 03:57 AM
talon95's Avatar
Quoted: 130 Post(s)
Liked: 63
This is not correct, or at least it's not what I've seen. I have Vista Ultimate SP1 installed and VMC recognized mkv's right out of the box. Once I installed Halli, CoreAVC, and AC3Filter, they play back perfectly also.
talon95 is offline
post #10 of 74 Old 06-19-2008, 05:55 PM
rrussell50's Avatar
I'm having absolutely no success at all playing MKV files in VMC. It plays fine through Windows Media Player and Classic.
This is a 1080p file w/ ac3 audio
I have tried renaming it to avi and it has not worked
I followed the following instructions
I did this
C:\\windows\\system32\\cmd.exe /C start /affinity 1 C:\\windows\\ehome\\ehshell.exe
I installed COREAVC w/ Haali and made sure AVI support was enabled
I disabled h.264/x.264 and VC-1 in FFDshow
I am running a 8800Gt by Nvidia w/ Vista Ultimate 64bit quad core
what am I doing wrong?
Is there a step by step tutorial to get this thing to work?
thanks
rrussell50 is offline
post #11 of 74 Old 06-19-2008, 06:15 PM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Maybe, but did it recognize them as "DVDs" or just as video files? i.e. do they appear in the Video library in VMC or the DVD library?
kapone is offline
post #12 of 74 Old 06-19-2008, 06:42 PM
DraZtiK's Avatar
Worked fine afterwards for me. copy the code below and paste into notepad and save as "mkv.reg". make sure it doesn't add the .txt extension afterwards. it should now see the mkv files properly. make sure the files are in the monitored folders.
Code:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\\.mkv]
@="MatroskaVideo"
"Content Type"="video/x-matroska"
"PerceivedType"="video"
[HKEY_CLASSES_ROOT\\.mka]
@="MatroskaVideo"
"Content Type"="audio/x-matroska"
"PerceivedType"="audio"
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Multimedia\\WMPlayer\\MIME Types\\video/x-matroska]
@="MatroskaVideo"
"UserApprovedOwning"="yes"
"Extensions.SpaceSep"=".mkv"
"Extensions.CommaSep"="mkv"
"Extension.Key"=".mkv"
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Multimedia\\WMPlayer\\MIME Types\\audio/x-matroska]
@="MatroskaVideo"
"Extensions.SpaceSep"=".mka"
"Extensions.CommaSep"="mka"
"Extension.Key"=".mka"
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Multimedia\\WMPlayer\\Groups\\Video\\mkv]
@="MatroskaVideo"
"Description"="Includes files with .mkv extensions."
"Extensions"=".mkv"
"FriendlyTypeName"="Matroska Media File"
"MIME Types"="video/x-matroska"
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Multimedia\\WMPlayer\\Groups\\Audio\\mka]
@="MatroskaVideo"
"Description"="Includes files with .mka extensions."
"Extensions"=".mka"
"MIME Types"="audio/x-matroska"
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Multimedia\\WMPlayer\\Extensions\\.mkv]
"Permissions"=dword:0000000f
"Runtime"=dword:00000007
"MediaType.Description"="Matroska Media File"
"Extension.Handler"="MatroskaVideo"
"Extension.MIME"="video/x-matroska"
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Multimedia\\WMPlayer\\Extensions\\.mka]
"Extension.MIME"="audio/x-matroska"
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\MediaPlayer\\Player\\Extensions\\Descriptions]
"819"="Matroska Media File (*.mkv;*.mka)"
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\MediaPlayer\\Player\\Extensions\\MUIDescriptions]
"819"="Matroska Media File"
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\MediaPlayer\\Player\\Extensions\\Types]
"819"="*.mkv;*.mka"
[HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\MediaPlayer\\MLS\\Extensions]
"mkv"="video"
"mka"="audio"
DraZtiK is offline
post #13 of 74 Old 06-19-2008, 07:18 PM
rrussell50's Avatar
now i can't view mlv using media player or VMC
no tutorial?
post #14 of 74 Old 06-19-2008, 08:25 PM
umdivx's Avatar
I read on here somewhere, forgot where, but what I did on new installs of windows to get mkv as well as other file extension support in VMC was to close VMC, go to an mkv file with windows explorer, then right click on said file, in this case an .mkv file, then go to "open with"
once you are in the section where is say choose application to open the file, click the down facing arrow to show other programs, and choose Media Center.
From then on it, MCE will recognize said file extension, will show up in your videos folder and will play them with no issues, barring you have CoreAVC, FFdshow, or some other codec installed that supports .mkv playback.
for me I have CoreAVC, Halli splitter, and FFdshow installed with vc-1, h.264, and mpeg4 disabled in FFDshow so that if forces CoreAVC to decode the .mkv files.
- Josh
umdivx is offline
post #15 of 74 Old 06-19-2008, 08:49 PM
bob2300NX's Avatar
Forget the reg hacks. Just install "My Movies". I love that add on.
bob2300NX is offline
post #16 of 74 Old 06-19-2008, 09:23 PM
archer75's Avatar
Quoted: 187 Post(s)
Liked: 73
You need graphedit to show you what each mkv files is using for codecs.
Then you use radlight filter manager to set the priority of each codec.
Then mkv's play just fine.
archer75 is offline
post #17 of 74 Old 06-19-2008, 10:06 PM
jeffreydeng's Avatar
That is exact what I am doing. Register the mkv file as a movie and play it from MM. You don't need to do any reg hacks. At runtime, the mkv file will be passed to vmc/WMP from MM. Using this way, wahtever file you can play using WMP, it will play with VMC.
jeffreydeng is offline
post #18 of 74 Old 06-19-2008, 10:25 PM
umdivx's Avatar
Again the whole "right click and open with" and choosing media center works EVERY time.
- Josh
umdivx is offline
post #19 of 74 Old 06-22-2008, 12:17 PM
rrussell50's Avatar
what codecs should I have graphedit use to play it? do you have a screen shot of it working correctly ?
thanks
post #20 of 74 Old 06-22-2008, 12:27 PM
archer75's Avatar
Quoted: 187 Post(s)
Liked: 73
More important is what graphedit says you are currently using. Then you use radlight filter manager to change the priority of various codecs until graphedit shows you are using the ones you want.
AC3filter for audio, CoreAVC or Cyberlink for video.
archer75 is offline
post #21 of 74 Old 06-22-2008, 12:44 PM
rrussell50's Avatar
thanks
bourne-ac3audio.mkv video - WMvideodecoder DMO - VMR Input0 (Video Render)
audio - mpa decoder filter - ac3 filter - audio input in (rendered) default directsound device
i downloaded the trial of COREAVC and installed it, i'm not paying for it until i verify it works. It is not showing up in the filters section, what category should it be listed under?
post #22 of 74 Old 07-02-2008, 06:29 PM
astrocramp's Avatar
I am also using My Movies to play *.mkv files, but the chapters don't work. The "next track" button on my remote simply skips ahead 30 seconds. On Media Player Classic the chapters work fine. Any idea of what the problem would be there? Otherwise VMC plays back the files fine, but chapters are actually pretty important to me.
astrocramp is offline
post #23 of 74 Old 07-03-2008, 10:35 AM
umdivx's Avatar
Media center doesn't support chapters, or "next" with any media playback of .avi, divx, mkv, ect... for media files like that, it only supports skip ahead.
- Josh
umdivx is offline
post #24 of 74 Old 07-03-2008, 11:25 AM
astrocramp's Avatar
- Josh
Well, that's disappointing. Does wmvhd support chapters? I really don't want to transcode, this takes way too much computing power and i'd prefer to keep the quality of the rips.
Are people just living with that or do they use an external player launched within VMC?
post #25 of 74 Old 07-03-2008, 11:44 AM
umdivx's Avatar
for me I just live with it, don't really care for chapters, but what I do miss that I get with MPC is picking up where you left off. I wish I could get that in VMC.
- Josh
umdivx is offline
post #26 of 74 Old 07-03-2008, 11:56 AM
ProAm500's Avatar
- Josh
i believe you can do that with media control
ProAm500 is offline
post #27 of 74 Old 07-17-2008, 10:58 PM
ZenithPete's Avatar
Yep, but you need to use ffdshow with that, not coreavc. However its one of the most useful plugins out there so it may be worth it, especially if you watch a lot of mkvs, navigating is so much easier with it.
ZenithPete is offline
post #28 of 74 Old 07-18-2008, 07:05 AM
ballenjr's Avatar
You do have to have ffdshow installed, but you can still use core AVC as your decoder.
In ffdshow goto codecs and disable all of ffdshows codecs except for under Raw Video. Select all supported for Raw Video.
Doing this allows me to keep CoreAVC as the video decoder and retain the resume and chapters function of the Media Control Plugin.
Not sure about other functions as Resume and Chapters are all I use the plugin for.
BTW, coreAVC looks miles better than the ffdshow decoder.
ballenjr
ballenjr is offline
post #29 of 74 Old 07-18-2008, 07:43 AM
GooberedUp's Avatar
ballenjr
Really? I thought the general consensus was opposite.
GooberedUp is offline
post #30 of 74 Old 07-18-2008, 02:00 PM
ballenjr's Avatar
I can't speak for the consensus but I definately find it more pleasing. The lower CPU utilisation is also a bonus.
What do others think?
ballenjr is offline
Reply Home Theater Computers
