Avisynth Script for doubling video frame rates - Page 19 - AVS Forum | Home Theater Discussions And Reviews
post #541 of 1969 Old 08-06-2010, 02:59 PM
travolter's Avatar
Originally Posted by dzid_ View Post
I modify Widezu's script so it uses a little less memory and in theory should be faster. Quality the same.
It seems that MSuper and MFlowFPS can work with mt in mode 1.
Code:
SetMTMode(1,8)
ffdShow_source()
super=MSuper(pel=1, hpad=8, vpad=8,  rfilter=4)
SetMTMode(2)
backward_1=MAnalyse(super, isb=true, blksize=16, searchparam=2, plevel=0, search=3)
forward_1=MAnalyse(super, isb=false, blksize=16, searchparam=2, plevel=0, search=3)
backward_2=MRecalculate(super, chroma=false, backward_1, blksize=8, searchparam=1, search=3)
forward_2=MRecalculate(super, chroma=false, forward_1, blksize=8, searchparam=1, search=3)
SetMTMode(1)
MFlowFps(super, backward_2, forward_2, num=FramerateNumerator*2, den=FramerateDenominator*1, mask=0)
GetMTMode(false) > 0 ? distributor() : last
Ps. It is on original script but personally I prefer pel=2 and MBlockFPS even with two pairs of MFlow.
wow.. fantastic.. I noticed less cpu usage. I need time for more tests and other combinations
Im really happy to see that our scripts can be improved =
travolter is offline
post #542 of 1969 Old 08-08-2010, 06:59 AM
Domas4's Avatar
Originally Posted by Minefield247 View Post
I'm going to be using Win7 64bit, should I use Avisynth and MVTools from here 'http://forum.doom9.org/showthread.php?t=152800' as these are for the 64bit platform?
I agree with SubJunk on 64bit matter.
Yesterday all day I was trying to get it work properly, however without any success. The MvTools x64, which was rewritten for 64bit systems is not working properly and just doubles the framerate without making the motion fluent. Besides, the author of that MT plugin is now gone (so no further development), and has had a bad reputation under a nickname of Jeremy Duncan.
But, you can still use 64bit operating system and run 32bit scripts no problem.
Domas4 is offline
post #543 of 1969 Old 08-09-2010, 06:25 AM
soulkeeper's Avatar
@Domas4
are there any other reports over the net about mvtools2 x64 not making the motion fluent?
I've managed to have a working configuration with 64bit versions of mpc-hc,ffdshow,avisynth,mvtools 2 and I believe I can see much better motion..
Ps.I've downloaded the 64bit versions of mvtools and avisynth not from the link provided few posts back but probably it's the same..
soulkeeper is offline
post #544 of 1969 Old 08-09-2010, 07:01 AM
Domas4's Avatar
SoulKeeper,
No there are no reports yet.
My setup was ffdshow x64, MPC-HC x64, MvTools x64 (from the link above) and MT x64 plugin by JoshyD. I ran MFLOWFPS and MBLOCKFPS functions, both provided no motion fluency, just doubling the framerate (microstuttering). It does make motion more fluent, but not as fluent as 32 bit plugin. Maybe MvTools x64 in the thread and yours are different afterall.
Do you have an option to compare the motion of 32bit plugin vs 64bit plugin?
Domas4 is offline
post #545 of 1969 Old 08-09-2010, 09:02 AM
soulkeeper's Avatar
Is it possible to have both 32 and 64 bit versions of the above programs installed and be able to run them or will I have conflicts?
I don't have other pc to try..
post #546 of 1969 Old 08-09-2010, 09:04 AM
widezu69's Avatar
I have both 32 bits and 64 bits installed and I prefer the 32 bits version, seems more stable. Plus, reclock has no 64 bit variant and for me it is essential for these scripts if you are using Haali renderer.
PS Turns out the hospital allows some internet so I can stick around for small amounts at a time.
widezu69 is offline
post #547 of 1969 Old 08-09-2010, 02:35 PM
travolter's Avatar
Im noticing that I can use lower values for setmemorymax with these settings!
testing setmemorymax(400) and its working ok.. so not necesary 1024. Lower values also decrease the seek time (no more buffered/ghost video playback when press forward in your player)
edit.- Its working also with (256).. probably is better dont use a very low value to avoid possible crashes at video startup... just using a value that dont produce ghost video playback when pressing forward is enough
post #548 of 1969 Old 08-09-2010, 04:56 PM
SubJunk's Avatar
Originally Posted by travolter View Post
Lower falues also decrease the seek time (no more buffered/ghost video playback when press forward in your player)
Nice find
SubJunk is offline
post #549 of 1969 Old 08-10-2010, 10:47 PM
blazed's Avatar
just to make sure, this is with reclock at 48frames right?
blazed is offline
post #550 of 1969 Old 08-11-2010, 02:03 AM
travolter's Avatar
umm sorry .. I dont use reclock...
anyway the cpu usage is all about the usage of pel=1 instead of 2
the big difference with the script is that you will be able to use less memory.. ( this is my test script just using setmemorymax(400) with a quadcore and kmplayer/potplayer as player
Code:
setmemorymax(400)
SetMTMode(1,5)
ffdShow_source()
super=MSuper(pel=2, hpad=8, vpad=8,  rfilter=4)
SetMTMode(2,9)
SetMTMode(1,2)
MBlockFps(super, backward_2, forward_2, num=60, den=1, mode=0)
post #551 of 1969 Old 08-13-2010, 02:38 AM
dzid_'s Avatar
Originally Posted by soulkeeper View Post
@Domas4
I reported it in that post http://www.avsforum.com/avs-vb/showt...=#post18645912. So now I use 32bit version.
Other thing I noticed yesterday is that when Aero is disabled I don't get periodic stuttering so there is no need to use trick with opening up aero enabled window (which not always fix annoying stuttering). I use reclock and without aero VSync position looks more stable. (ctrl+alt+shift+F9)
Despite all that during whole movie I can notice dropped frame few times.
dzid_ is offline
post #552 of 1969 Old 08-13-2010, 02:33 PM
soulkeeper's Avatar
Well i installed 32bit versions of mpc-hc and ffdshow as avisynth and mvtools2...
did some quick tests and didn't notice any differences...
the script i'm trying these days with 23,976fps movies is this..
Setmemorymax(1024)
SetMTMode(1,4)
ffdShow_source()
SetMTMode(2)
super=MSuper(pel=1, hpad=0, vpad=0)
backward_1=MAnalyse(super, isb=true, blksize=16, searchparam=3, plevel=0, search=3)
forward_1=MAnalyse(super, isb=false, blksize=16, searchparam=3, plevel=0, search=3)
backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, searchparam=1, search=3)
forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=8, searchparam=1, search=3)
MBlockFps(super, backward_2, forward_2, num=FramerateNumerator*2, den=FramerateDenominator*1, mode=2)
SetMTMode(1)
the soap opera effect is greatly reduced generally when i use multiples of 23.976(either x2=48 or x3=72) instead of num=60....
i'll keep doing some tests with 32 and 64bit to see if i can find any differences...
post #553 of 1969 Old 08-16-2010, 10:30 AM
travolter's Avatar
I usually work with monitor at 60hz so I use the script for create 60fps movies
Im testing now with 75hz (75fps in the script) and the movement is more fluid... so Im not using 60 anymore ;P
Anyone have one of these 120hz monitors to test the framerateinterpolation to 120fps?
post #554 of 1969 Old 08-16-2010, 05:57 PM
SubJunk's Avatar
Yeah, definitely. I recommend always using the maximum Hz of your monitor in the script I put the script at 60 because it seems more common than 75 at the moment.
SubJunk is offline
post #555 of 1969 Old 08-22-2010, 02:29 PM
sebastiaan4489's Avatar
Got this stuff working on my 2.0 Ghz Core 2 Duo T5870 processor.
My script:
SetMTMode(1,0)
ffdShow_source()
SetMTMode(2)
super=MSuper(pel=1, hpad=0, vpad=0, rfilter=4)
backward_1=MAnalyse(super, isb=true, blksize=32, searchparam=2, plevel=0, search=3)
forward_1=MAnalyse(super, isb=false, blksize=32, searchparam=2, plevel=0, search=3)
backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=16, searchparam=1, search=3)
forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=16, searchparam=1, search=3)
MBlockFps(super, backward_2, forward_2, num=FramerateNumerator*2, den=FramerateDenominator*1)
SetMTMode(1)
Anyone got some suggestions to improve this script?
Normally I get around 55~65% processor usage with peaks up to 75~80% in buzy scenes.
MFlow gives severe slowdowns and high CPU usage.
When adding mode=2 to MBlockFPS I get video-audio syncing problems(video slows down but sound doesn't, CPU usage normal)
sebastiaan4489 is offline
post #556 of 1969 Old 08-28-2010, 03:44 PM
travolter's Avatar
@sebastiaan4489
try
SetMTMode(1,0)
ffdShow_source()
SetMTMode(2)
super = MSuper(pel=1,hpad=0,vpad=0)
backward = MAnalyse(super, blksize=32, isb = true, chroma=false, searchparam=1,search=0)
forward = MAnalyse(super, blksize=32, isb = false, chroma=false, searchparam=1,search=0)
MBlockFps(super, backward, forward, num=FramerateNumerator*2, den=FramerateDenominator*1)
SetMTMode(1)
* get a new CPU!
post #557 of 1969 Old 08-29-2010, 09:20 AM
travolter's Avatar
anyone have sample test videos to check the scripts?
cause I change settings in the scripts.. ones consume more cpu than others.. and Im not sure when a high CPU script is "visually" better than other
post #558 of 1969 Old 08-29-2010, 06:19 PM
SubJunk's Avatar
There are comparison videos in my guide, linked to from my signature.
SubJunk is offline
post #559 of 1969 Old 08-30-2010, 07:46 AM
travolter's Avatar
@SubJunk
thanks pal!! I got them and Im testing... these fast motion scenes are nice to check scripts
post #560 of 1969 Old 09-02-2010, 03:58 PM
soulkeeper's Avatar
still trying to find the best script for my taste..
couple questions..
in the 3:2 pulldown box in avisynth's tab in ffdshow most recommend to check "ignore pulldown"..but i've seen also the "smooth timestamps" to be recommended..
assuming my display is at @60hz..what should i check if :
1)i interpolate with the script to 60fps
2) i interpolate to a multiple or 23.976..let's say 72fps..
Also,what do i select in the renderer settings of mpc-hc concerning V-sync?
It has v-sync,alternative v-sync and accurate v-sync as available options...
and something else...
i read the mvtools page
http://avisynth.org.ru/mvtools/mvtools2.html
and it refers the default values of some parameters..(ex. chroma=true by default or mode=2 for MBlockFps.. e.t.c)..
if i don't add a parameter in the script does that mean that it will be actually "active" at it's default value?
post #561 of 1969 Old 09-02-2010, 06:53 PM
SubJunk's Avatar
Yes
SubJunk is offline
post #562 of 1969 Old 09-03-2010, 02:06 AM
soulkeeper's Avatar
Ok..Thanks!
generally,i'm leaning towards using 72fps for interpolation instead of 60...the result is much less soap opera effect and less artifacts probably due to less interpolated frames used....
ok it's still not ideal because my display is at @60hz so there will be some judder due to different fps-refresh rate...
any suggestion about v-sync options in renderer settings and 3:2 pulldown in avisynth tab would be welcomed..
post #563 of 1969 Old 09-03-2010, 04:10 AM
widezu69's Avatar
Hi have you tried using powerstrip to override the refresh rates of your monitor? See if your monitor does 48hz or 72hz or even 96hz. If not then either interpolate to 60fps without any pull down, or 48/72fps with smooth timestamps. I don't use the v sync in mpc because I use Haali's renderer. Instead I install reclock and use that as the audio renderer. It has the ability to speed up or slow down your video to match the refresh rate. eg if you have a 58fps film to a 60hz monitor, it will speed it up slightly and resample the audio so you have a perfectly in sync video.
widezu69 is offline
post #564 of 1969 Old 09-03-2010, 05:01 AM
soulkeeper's Avatar
Well,I tried powerstrip with no luck..but I managed to creat a new .inf file with a custom resolution 1280x720@72hz for my HD ready projector(epson tw700)..the problem is that although I see in the info of my pj that it locks at the above resolution ,it's very unlikely that it plays at that refresh rate..it's almost sure that it internally converts 72 to 60(pulldown) and plays at that ref.rate..even newer pj which advertise that they accept 24hz signals they internally convert..
So I'll set smooth timestamps..
I'm using evr-cp..maybe I'll give haali a try..
As for reclock,I've never used it and I doubt that I need it..I'm bitstreaming audio to my avr if that makes any difference..
Is there any need to change something in the script depending on using or not reclock?
post #565 of 1969 Old 09-08-2010, 01:25 PM
neograniceni's Avatar
Ok..Thanks!
I am watching 23.976/24fps movies interpolated to 75fps on 50Hz display for months. Nothing can beat this if You have enough CPU power and 50Hz display (PAL). 90fps interpolation on 60Hz is another way to reduce soap, but to be able to watch 1080p this way You really need some fast quad core CPU + Nvidia CUDA enabled gfx.
neograniceni is offline
post #566 of 1969 Old 09-09-2010, 07:14 AM
Phyltre's Avatar
I just purchased a 120Hz monitor for my PC, can someone edit this code for 120Hz motion interpolation? Including the code since I know this formatting on my machine.
SetMemoryMax(1280)
SetMTMode(5,8)
ffdShow_source()
SetMTMode(2)
backward_1=MAnalyse(super, chroma=false, isb=true, blksize=16, blksizev=16, searchparam=3, plevel=0, search=3, badrange=(-24))
forward_1=MAnalyse(super, chroma=false, isb=false, blksize=16, blksizev=16, searchparam=3, plevel=0, search=3, badrange=(-24))
backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, blksizev=8, searchparam=0, search=3)
forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=8, blksizev=8, searchparam=0, search=3)
MBlockFps(super, backward_2, forward_2, num=FramerateNumerator(last)*2, den=FramerateDenominator(last)*1, mode=0)
SetMTMode(1)
I finally got this working after I realized the tutorial I was reading from was pointing to older avisynth.dlls than 2.5.8, so i was getting crashes. Finally found latest versions of everything and got it going. I'm certainly not confident enough to convert this code to 120Hz on my own. I'm definitely curious what it would look like, though...
Phyltre is offline
post #567 of 1969 Old 09-09-2010, 02:06 PM
SubJunk's Avatar
SetMemoryMax(1280)
SetMTMode(5,8)
ffdShow_source()
SetMTMode(2)
SetMTMode(1)
SetMemoryMax(1280)
SetMTMode(5,8)
ffdShow_source()
SetMTMode(2)
MBlockFps(super, backward_2, forward_2, num=120, den=1, mode=0)
SetMTMode(1)
SubJunk is offline
post #568 of 1969 Old 09-09-2010, 03:21 PM
Phyltre's Avatar
And all I can say is wow! Definitely some frames dropping with 1080p content, but even then, it's almost scarily good. Watched The Dark Knight for a few minutes and seeing the hospital explode, I really felt like I was watching it happen from a helicopter. I felt the faint urge to get away. Some textures get a bit mangled (think skyscraper window matrices) but the overall experience was beautiful. I think our brain is used to seeing "fake" things at a slow framerate, so when that gets sped up and interpolated, some of that magical suspension of disbelief comes back. Well, lots of people have thought that but you don't feel it until you see it!
Of course my machine is an i7 quadcore 930, and it's not quite there with perfect playback (CPU usage seems to hit ~78% on all cores) so it's not for everyone. And real 120Hz monitors (unlike the TVs) are still a tiny market. But in this very special situation, motion interpolation is like magic. I'm very impressed. Totally bypasses the watching-a-movie,-yawn filter we've all developed.
Phyltre is offline
post #569 of 1969 Old 09-09-2010, 08:07 PM
SubJunk's Avatar
You're welcome, and if you want an even more precise interpolation, check out the guide linked to from my signature. It's not for realtime, it's for conversion, which means with advance planning you can use the highest-quality settings available.
Give it a try and I think you'll see a jump in quality compared to your current script.
Oh and if you do want to try it, let me know and I'll modify it for 120Hz, since at the moment it's for 60Hz
SubJunk is offline
post #570 of 1969 Old 09-09-2010, 10:39 PM
kelvin2k10's Avatar
have anyone experience crash issue with mpc-homecinema version later than 1.3.2371 (the last working version with motion interpolation), any solution for this? thanks~
kelvin2k10 is offline
Reply Home Theater Computers
