Avisynth Script for doubling video frame rates - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 1969 Old 10-26-2010, 02:25 PM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Originally Posted by SubJunk View Post
You can try this as well for less artifacts
Code:
SetMTMode(1,12)
ffdShow_source()
SetMTMode(2)
super = MSuper(pel=2, hpad=0, vpad=0, rfilter=4)
backward_1=MAnalyse(super, isb=true, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24))
forward_1=MAnalyse(super, isb=false, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24))
backward_2=MRecalculate(super, backward_1, blksize=8, searchparam=1, search=3)
forward_2=MRecalculate(super, forward_1, blksize=8, searchparam=1, search=3)
backward_3=MRecalculate(super, backward_2, blksize=4, searchparam=0, search=3)
forward_3=MRecalculate(super, forward_2, blksize=4, searchparam=0, search=3)
MFlowFps(super, backward_3, forward_3, num=60, den=1)
SetMTMode(1)
GetMTMode(false) > 0 ? distributor() : last
Thanks for the reply is coreavc used for yours as well or do you do something else. I just want to add both of you are doing great work
and can't get that kick *** picture out of my mind from last night!
I am going to have fun tonight will post my thoughts will be using MKV Casino Royal 1080p
greg1292 is offline
post #632 of 1969 Old 10-26-2010, 02:47 PM
SubJunk's Avatar
CoreAVC will work for either one, glad you're enjoying it
SubJunk is offline
post #633 of 1969 Old 10-26-2010, 02:52 PM
soulkeeper's Avatar
has anyone tried playing around with hpad -vpad values and see any differences either in artifacts or performance?
default value is 8 according to mvtools2 documentation...
but the most scripts posted here recommend 0 for both..
soulkeeper is offline
post #634 of 1969 Old 10-26-2010, 02:55 PM
SubJunk's Avatar
Higher values would probably slightly boost performance at the expense of interpolation at the edges, that's why 0 is recommended. Higher than 0 means there is an area on the edges that is ignored.
SubJunk is offline
post #635 of 1969 Old 10-26-2010, 03:41 PM
soulkeeper's Avatar
Hi @SubJunk
is there any documentation for this or you found that just by experimenting with different values?
in the mvtools2 docum. it recommends hpad=blksize
post #636 of 1969 Old 10-26-2010, 03:45 PM
SubJunk's Avatar
I found it from testing. I can upload some comparisons if you'd like.
SubJunk is offline
post #637 of 1969 Old 10-26-2010, 07:56 PM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Coreavc and Halli produces 90% cpu with either script how do I dial it
back a notch. SetMemoryMax(1080)
SetMTMode(6,18)
ffdShow_source()
SetMTMode(2)
#change p=1 to p=2 if you have enough power left; however max CPU load should not exceed 75%;
p=2
super=MSuper(pel=p, hpad=16, vpad=8)
#change s=1 to 2 or 3 if you have no artifacts; The higher the number, the smoother it is;
s=1
backward_1=MAnalyse(super, chroma=false, isb=true, blksize=32, blksizev=16, searchparam=s, search=3, badrange=(-24))
forward_1=MAnalyse(super, chroma=false, isb=false, blksize=32, blksizev=16, searchparam=s, search=3, badrange=(-24))
backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=16, blksizev=8, searchparam=s, search=3)
forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=16, blksizev=8, searchparam=s, search=3)
#dn=FramerateDenominator(last)*1
#nm=FramerateNumerator(last)*2
dn=1
nm=60
MBlockFps(super, backward_2, forward_2, num=nm, den=dn, mode=2)
SetMTMode(1)
56% all 6 cores if this helps
greg1292 is offline
post #638 of 1969 Old 10-26-2010, 08:18 PM
SubJunk's Avatar
SetMTMode(6,18)
ffdShow_source()
SetMTMode(2)
p=2
s=1
dn=1
nm=60
SetMTMode(1)
That is already quite low-quality even if it ran smoothly. I recommend you convert videos before watching them so you can enjoy better quality.
SubJunk is offline
post #639 of 1969 Old 10-26-2010, 08:59 PM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
I am running Madvr with coravc and this script on my bluray rips and the picture
is really good right now what do you mean low quality and how do I improve the scaling?
SetMemoryMax(1280)
SetMTMode(6,0)
ffdShow_source()
SetMTMode(2)
super=MSuper(pel=1, hpad=0, vpad=0)
backward_1=MAnalyse(super, chroma=false, isb=true, blksize=16, blksizev=16, searchparam=3, plevel=0, search=3, badrange=(-24))
forward_1=MAnalyse(super, chroma=false, isb=false, blksize=16, blksizev=16, searchparam=3, plevel=0, search=3, badrange=(-24))
backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=16, blksizev=16, searchparam=2, search=3)
forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=16, blksizev=16, searchparam=2, search=3)
backward_3 = MRecalculate(super, chroma=false, backward_2, blksize=8, blksizev=8, searchparam=1, search=3)
forward_3 = MRecalculate(super, chroma=false, forward_2, blksize=8, blksizev=8, searchparam=1, search=3)
MBlockFps(super, backward_3, forward_3, num=60, den=1, mode=0)
SetMTMode(1)
Almost there but don't know what to tweak. Very happy with madvr and this setup. Pictures don't do it justice the movies
look alive now almost reach out and touch.
greg1292 is offline
post #640 of 1969 Old 10-27-2010, 11:40 AM
marfpilf's Avatar
For those of us with weak computers , here is a MeGUI friendly script to rock out max quality/smoothness with minimal artifacts. Not very practical but fun to tinker with. Try comparing with mirills' SplashPRO that uses proprietary motion interpolation technology to do this even on weak CPUs (albeit with more artifacts than these scripts)
See SubJunk's awesome guide to setting these kind of scripts up here:
http://www.spirton.com/convert-videos-to-60fps/
Here are the scripts:
#MEGUI VERSION AVS_48_FPS_MAX MFlow MAX Smoothness, Minimal Artifacts
#10x Real Time to render on Core2 Duo E8500
LoadPlugin("C:\\Program Files (x86)\\MeGUI\ ools\\avisynth_plugin\\mt.dll")
SetMTMode(1,4)
LoadPlugin("C:\\Program Files (x86)\\MeGUI\ ools\\avisynth_plugin\\mvtools2.dll")
SetMTMode(2)
super=MSuper(pel=2, hpad=0, vpad=0, rfilter=4)
MFlowFps(super, backward_3, forward_3, num=FramerateNumerator*2, den=FramerateDenominator*1, mask=0)
SetMTMode(1)
ConvertToYV12()
and.... the 60 FPS version:
#MEGUI VERSION AVS_60_FPS_MAX MFlow MAX Smoothness, Minimal Artifacts
SetMTMode(1,4)
SetMTMode(2)
MFlowFps(super, backward_3, forward_3, num=60, den=1, mask=0)
SetMTMode(1)
ConvertToYV12()
marfpilf is offline
post #641 of 1969 Old 10-27-2010, 05:21 PM
widezu69's Avatar
Just an update, I have found that with searchparam values, the first pair pass having value 2 is sufficient. The rest can all be 0 as blksize=8/4 are small enough. In other words, blksize=16 need at least searchparam=2 but also at most 2 because the larger the searchparam the more cpu and more artefacts actually. Increasing the param on blksize=8 and 4 is not necessary.
widezu69 is offline
post #642 of 1969 Old 10-27-2010, 06:30 PM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Thanks for the help my cpu must not be big enough What scipt will
give me the best quality without maxing out my system.
greg1292 is offline
post #643 of 1969 Old 10-27-2010, 07:21 PM
marfpilf's Avatar
Thanks for the tips.
marfpilf is offline
post #644 of 1969 Old 10-27-2010, 09:26 PM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Originally Posted by 8:13 View Post
________ advanced ffdshow: framerate doubler - CPU Easy________
Codecs tab
Set Mpeg2 to Libmpeg2, and check "DVD decoding".
Set Avisynth to Avisynth, Raw video to All supported
Decoder options tab
Uncheck "Detect soft telecine and average frame durations"
Subtitles tab, Unchecked
Uncheck "Decode closed captions"
Uncheck "Accept embedded subs"
Uncheck "Accept SSA, ASS, ASS2 Subtitle (experimental)
Vobsub subpage, uncheck Vobsub Enable.
Avisynth tab checked
YV12 checked,
Add FFdshow Video source Unchecked,
3:2 Pulldown box: Smooth timestamps checked,
check Buffer back/Ahead: 5, 5
setmtmode(2)
video=ffdshow_source()
A=video
B=A.MSuper(pel=2, hpad=8, vpad=8, rfilter=4)
One=B.MAnalyse(isb=true, blksize=32, search=1, searchparam=2)
Two=B.MRecalculate(One, chroma=false, blksize=32, blksizev=32, search=1, searchparam=2)
A.MBlockFps(B, One, Two, num=FramerateNumerator(video)*2, den=FramerateDenominator(video)*1, mode=1)
Resize & aspect tab checked if resizing to 1080p, this resizing step is for sddvd source video only, not HD video.
Process whole image checked
Specify horizontal and vertical Resize: 1920, 1080 (or your monitors resolution)
Process Pixel aspect ratio internally checked
No aspect ratio correction checked
spline
Luma Sharpen: 0.00
Luma Guassian Blur 0.50 (On small monitors like laptops it's best not to use this. Set it to 0.00)
Accurate rounding checked
Output tab
rgb32 checked
high quality yv12 to rgb conversion checked
rgb conversion tab
ycbcr: itu-bt 601
Dithering checked
input: standard
Output levels: Tv/Projector
Reclock: Be sure to use reclock vsync
ATI pixel format set to full rgb: 4:4:4
Different code to try.
Code:
setmtmode(2)
A=video
One=B.MAnalyse(isb=true, blksize=16, search=1, searchparam=2)
Two=B.MAnalyse(isb=false, blksize=16, search=1, searchparam=2)
Three=B.MRecalculate(One, chroma=false, blksize=32, blksizev=32, search=1, searchparam=2)
Four=B.MRecalculate(Two, chroma=false, blksize=32, blksizev=32,  search=1, searchparam=2)
A.MBlockFps(B, Three, Four, num=FramerateNumerator(video)*2, den=FramerateDenominator(video)*1, mode=1)
Note the way I wrote the script. it's the correct way I think.
To do quality test, download my test disk here.
Then play disk and frame step video. When bar on far right moves is when you can see the quality shine.
Thanks for all the help as I have settled on this one as best for
my system and quality. Cpus never go above 63 on all 6 cores and gives me the smoothest playback and works perfect with madVr. The thread
is a huge advancement in PQ and was worth the 2 day's of trial and
error! Look forward to the improvements in the coming years.
greg1292 is offline
post #645 of 1969 Old 10-27-2010, 10:57 PM
SubJunk's Avatar
As usual I disagree
SubJunk is offline
post #646 of 1969 Old 10-28-2010, 12:37 AM
widezu69's Avatar
As usual I disagree
Haha lol. Good thing with Avisynth is that no one needs the same script. But agree to disagree. Will rewrite a guide soon for the newcomers.
widezu69 is offline
post #647 of 1969 Old 10-28-2010, 12:59 PM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Look forward to it!!!!!
greg1292 is offline
post #648 of 1969 Old 10-29-2010, 01:29 AM
timgbpd's Avatar
Just share some test results.
I decide to use MBlockFps instead of MFlowFps for real time playback. The quality of MFlowFps is better indeed, but it really costs CPU power. In the same CPU usage condition, I found the quality of MBlockFps is better than MFlowFps.
SubJunk's quality script is the best, but need time to do conversion and it can't do real time playback in my i5 CPU (even overclock to 4G!). Widezu's MBlockFps script is OK for real time playback.
I also found that double frame rate is good enough for 60Hz refrash rate plasma TV. The CPU power should be used at better quality parameters first. 60fps interpolation is the second step. But maybe it will be different at LCD display.
timgbpd is offline
post #649 of 1969 Old 10-29-2010, 03:18 AM
SubJunk's Avatar
Thanks for the feedback, tim. It all seems reasonable.
SubJunk is offline
post #650 of 1969 Old 10-31-2010, 03:12 PM
soulkeeper's Avatar
well i also found that just doubling the framerate has better results than interpolating to @60fps concerning artifacts...
but there are other problems introduced ,like judder/stutter ..
because of difference in fps/ display refresh rate...
i believe it's a matter of choice...
the ideal would be to have a monitor that "locks" at 48hz and plays at that refresh rate or at a multiple of it ( e.t.c @96hz)
there is also a new version of mvtools2 2.5.11
"2.5.11 beta (17.10.2010 by Fizick)
MAnalyse, MRecalculate: added pure Horizontal and Vertical search types (requested by 'Null Null').
MRecalculate: Fixed Hexagon and UMH search types (was processed as Logarithmic)."
http://avisynth.org.ru/mvtools/mvtools2.html
post #651 of 1969 Old 10-31-2010, 04:02 PM
widezu69's Avatar
Powerstrip can lock your screen at any refresh rate your video card is capable of. I can manage between 20Hz and 65Hz so I just set it on 48Hz for films and 50Hz for PAL streaming such as iPlayer.
widezu69 is offline
post #652 of 1969 Old 11-01-2010, 02:25 PM
mark007's Avatar
Wow been looking for a good avisynth script like this for some time now! Really excellent, worked perfect first time, using it with madVR and mpc-hc, cpu usage only around 17% on 720p, 36% on 1080p clips so far.
I have two questions
1) My TV doesn't support 48hz so I'm stuck with 24hz, 25hz, 50hz or 60hz. Can the script be modified easily to triple frame rate upto 60hz?
2) How does this compare to interpolation methods used by some of the TVs like the Samsung Series 9 for example quality wise and are any of the figures in the script easily configurable to improve quality of the interpolation as playing Avatar blu-ray for example now I just saw some rather noticable artifacts at the 20th Century Fox main intro screen which are noticibly worse than artifacts on my series 9 tv. I tried this max quality script from SubJunks post on the previous page but my core i7 @ 3.6 dies although the quality looks amazing. Any core i7 users found a happy medium.
Code:
SetMTMode(1,0)
ffdShow_source()
SetMTMode(2)
backward_1 = MAnalyse(super, isb=true, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24))
forward_1 = MAnalyse(super, isb=false, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24))
backward_2 = MRecalculate(super, backward_1, blksize=8, searchparam=1, search=3)
forward_2 = MRecalculate(super, forward_1, blksize=8, searchparam=1, search=3)
backward_3 = MRecalculate(super, backward_2, blksize=4, searchparam=0, search=3)
forward_3 = MRecalculate(super, forward_2, blksize=4, searchparam=0, search=3)
SetMTMode(1)
mark007 is offline
post #653 of 1969 Old 11-01-2010, 02:37 PM
SubJunk's Avatar
Code:
SetMTMode(1,0)
ffdShow_source()
SetMTMode(2)
SetMTMode(1)
Since your TV supports 50Hz you could try changing num=60 to num=50
SubJunk is offline
post #654 of 1969 Old 11-01-2010, 02:50 PM
mark007's Avatar
Thanks I'll try that, I imagine quality wise, going from 24 > 60 would be alot nicer than 24 > 50. Some powerful tools though, will keep me playing about for some time to get a nice balance!
mark007 is offline
post #655 of 1969 Old 11-01-2010, 02:53 PM
SubJunk's Avatar
I think the difference between 50-60Hz will be less noticeable than changing any of the other settings Let us know how it goes
SubJunk is offline
post #656 of 1969 Old 11-01-2010, 03:33 PM
greg1292's Avatar
Quoted: 83 Post(s)
Liked: 27
Seems so, other filters in ffdshow are people's own preferrence. if you want to do resizing etc, be sure at drag the avisynth tab to the top of the list of filters so the frame doubling gets process first before anything else.
Missed this while reading earlier Makes a nice improvement.
greg1292 is offline
post #657 of 1969 Old 11-01-2010, 04:03 PM
soulkeeper's Avatar
well,first of all,powerstrip doesn't work with all video cards...
also,all of the displays have some limits...my projector for example has a range 50-75hz...so i think driving at a refresh rate out of it's capabilities is not recommended..
lastly and most important....even if you manage to lock your screen at @48hz or @72hz there are many chances that it internally converts and play at @60hz...this is true ,even for many displays capable of accepting @24hz...
personally i gave up trying to lock at 48 or 72hz...
i've decided to lock at 60hz and interpolate 23.976->60fps....
still testing to find the ultimate script!
Ps what is iplayer? Is it a media player?
post #658 of 1969 Old 11-01-2010, 05:11 PM
widezu69's Avatar
Haha iplayer is a BBC streaming service much like Netflix or Hulu your side of the pond. Its for tv catchup and being in the UK, everything is pal and therefore 25fps.
If your monitor can manage 50Hz why don't you set it to that and use the Frame Doubling script instead of the 60fps interpolation. The 48fps output will then be sped up slightly by reclock to sync up with your refresh rate. This way you get nice smooth motion tailored for your monitor and less artefacts by using less interpolation. Reclock also resamples your audio so it won't sound like chipmunks.
widezu69 is offline
post #659 of 1969 Old 11-01-2010, 05:29 PM
soulkeeper's Avatar
well that sounds very good!
i'm convinced that interpolating to 48fps has much better results for my setup..(less artifacts,less soap opera effect..)
as for reclock..i've just started messing around with it...i know that it's good at 23.976 to 25fps speed up..but i don't know how will it manage 48 to 50fps....especially when i bitstream to my avr through hdmi and don't use analogue outputs or decoded (by the software player) pcm stream i'm afraid i'll have issues with sound..
but i'll try it as soon as i get home!
post #660 of 1969 Old 11-01-2010, 05:52 PM
widezu69's Avatar
Well if reclock has no problem with ordinary 25fps speedup and it works over your bit stream then it shouldn't have any problems with 50fps. But try it out and report back.
widezu69 is offline
Reply Home Theater Computers
