Avisynth Script for doubling video frame rates - Page 66 - AVS Forum | Home Theater Discussions And Reviews
post #1951 of 1969 Old 03-30-2012, 03:31 PM
Chainik's Avatar
SubJunk
You DO understand that you lose both speed and quality with absolute 60000/1001 frame rate, right?
Chainik is offline
post #1952 of 1969 Old 03-30-2012, 03:47 PM
SubJunk's Avatar
Maybe speed but not quality, though you and I have never agreed on quality anyway
SubJunk is offline
post #1953 of 1969 Old 03-30-2012, 04:09 PM
Chainik's Avatar
With 5/2 you'll always get 1 source frame for every 4 interpolated.
With 60000/1001 you'll get almost (depends on source) all frames interpolated (*).
More interpolated frames - more visible artifacts (in motion of cause, not on screenshots ).
(*) Not for 23.976 source
Chainik is offline
post #1954 of 1969 Old 03-30-2012, 05:10 PM
SubJunk's Avatar
Which is 99% of videos
However it should be noted that InterFrame changes its output framerate depending on the source framerate, and that I suggested a similar improvement to Widezu's script here
SubJunk is offline
post #1955 of 1969 Old 05-09-2012, 01:20 PM
janderclander14's Avatar
Hi,
I'm using this script code with the new SVP libraries, which basically corresponds to Inteframe's defaults.
svp_scheduler=true
SetMemoryMax(1024)
LoadPlugin("C:\\Program Files (x86)\\SVP\\plugins\\svpflow1.dll")
LoadPlugin("C:\\Program Files (x86)\\SVP\\plugins\\svpflow2.dll")
SetMTMode(3,15)
V = ffdshow_source()
SetMTMode(2)
S= V.SVSuper("{scale:{up:0,down:4},gpu:1,rc:false}")
A = S.SVAnalyse("{main:{search:{coarse:{distance:-10},bad:{sad:2000}}},refine:[{thsad:250}]}")
V.SVSmoothFps(S, A, "{num:5,den:2,algo:13,mask:{cover:80,area:0,area_sharp:1.2},s cene:{blend:true, mode:0}}", url="www.svp-team.com", mt=15)
GetMTMode(false) > 0 ? distributor() : last
Smoothness is great and cpu usage is very low, but it seems to produce more artifacts (mainly around moving objects) than the old script with search parameter at the minimum value.
Any suggestion to minimise artifacts?
janderclander14 is offline
post #1956 of 1969 Old 05-09-2012, 02:45 PM
Chainik's Avatar
Originally Posted by janderclander14 View Post
mainly around moving objects <..> any suggestion to minimise artifacts?
"algo:21"
It seems that you're using not the latest version, libs bundled with SVP 3.1.1 have one serious quality issue.
Chainik is offline
post #1957 of 1969 Old 05-15-2012, 08:49 AM
tigermaster's Avatar
Hi SubJunk, so now with interframe 2 how the script should be in MeGui avs script editor in order to use the new version? your guide is updated to interframe 1.14.
I suppose it now uses svpflow libs instead of mvtools2 right ? removegrain still needed ?
can you please paste here a working script for use it in megui for an offline conversion?
thank you for all your effort.
also is it safe to use the new avisynth mt dll 2.6.0.3 or it's better to keep the one installed by svp 3.1.1 ?
thanks
tigermaster is offline
post #1958 of 1969 Old 06-13-2012, 03:47 AM
SubJunk's Avatar
Sorry for the late reply, I usually get email notifications of new posts but didn't get one this time.
Sure, here's the sample script from the InterFrame discussion link in my signature:
Code:
Setmemorymax(512)
SetMTMode(3,4)
LoadPlugin("svpflow1.dll")
LoadPlugin("svpflow2.dll")
Import("InterFrame2.avsi")
dss2("video.mkv", fps=23.976).ConvertToYV12()
SetMTMode(2)
InterFrame(Cores=4)
thanks
SubJunk is offline
post #1959 of 1969 Old 06-20-2012, 04:24 PM
widezu69's Avatar
@jander, how about try this one? I've tried to keep artifacts on a minimum but maintain smoothness:
Code:
svp_scheduler = true
URL = "www.svp-team.com"
SetMTMode(2,15)
S = V.SVSuper("{gpu:1, scale:{up:2, down:4}}")
P = S.SVAnalyse("{main:{search:{coarse:{distance:-1, bad:{SAD:2000}}}}, refine:[{thsad:250}]}")
V.SVSmoothFps(S, P, "{rate:{num:60, den:1, abs:true}, algo:13, cubic:1, mask:{cover:0, area_sharp:2}, scene:{mode:0, blend:true, limits:{blocks: 50}}}", url=URL, mt=15)
widezu69 is offline
post #1960 of 1969 Old 08-19-2012, 10:04 PM
Ratul Upadhyay's Avatar
Hey guys, I've read through this whole thread for a while now. I'm using the script given below since the past few weeks. The thing is, it is giving me quite a lot of artifacts and ghosting (Mblockfps does perhaps), even though the smoothing is great, just as I want it. I use the 64-bit version of ffdshow and WMP, I just have to, so I'm using the 64-bit plugins and avisynth with them. Here is my script, how can I improve on the visual quality here with maintaining that smoothness. Oh and I tried shifting to more current scripts having Msmoothfps and Mflowfps but alas it breaks up everything. Some help needed here. smile.gif
My config :- X6 1090T, 9600GT, 8GB DDR3. This script is running at around 75% per core.
Code:
SetMTMode(2,24)
ffdshow_source()
spline64resize(1152,864)
super=MSuper(pel=2, hpad=0, vpad=0, rfilter=4)
backward_1=MAnalyse(super, chroma=false, isb=true, blksize=16, blksizev=16, searchparam=3, plevel=0, search=3, badrange=(-24))
forward_1=MAnalyse(super, chroma=false, isb=false, blksize=16, blksizev=16, searchparam=3, plevel=0, search=3, badrange=(-24))
backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, blksizev=8, searchparam=2, search=3)
forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=8, blksizev=8, searchparam=2, search=3)
backward_3 = MRecalculate(super, chroma=false, backward_2, blksize=4, blksizev=4, searchparam=1, search=3)
forward_3 = MRecalculate(super, chroma=false, forward_2, blksize=4, blksizev=4, searchparam=1, search=3)
MBlockFps(super, backward_3, forward_3, num=60, den=1, mode=0)
SetMTMode(1)
Ratul Upadhyay is offline
post #1961 of 1969 Old 12-20-2012, 10:04 AM
SuperBilleN's Avatar
Hi, just bought the zotac id82 with i3-2330m and 8g ddr3 and HD3000 gpu, what would be the best way to get svp working without any dropouts?
ive been,trying with but i cant get it to play without crashing.
iam am planning to use custom xbmc with lav decoders to play my 1080p mkv files.
do you have some tips? Mayby the perfect files packages to an easy install?
thnx for the time you give me for an answer
Dennis
SuperBilleN is offline
post #1962 of 1969 Old 03-29-2013, 12:04 PM
Domas4's Avatar
Hi peeps.
Since this thread dead and I've got nowhere to post here is my comeback with the script that I've been finally am happy with. I know most you guys switched to SVP and yes they did amazing job, but in some scenes I still get crazy artifacts even if I change lambdas, plevels and stuff. So here is recent script that I've had absolutely no artifacts. Yes, it has a high penalty level, but now I get no ghosting, no fast motion artifacts or artifacts around edges of the screen. It is something between fluid motion and flicker picture. It's just about right to not notice the stuttering but get the film effect. BTW, it is using old SVP's modified mvtools2.
You need
http://www.svp-team.com/files/gpl/mvtools-2.5.11.9-svp.zip
this
http://forum.doom9.org/showthread.php?t=148782
and ofcourse avisynth 2.6 and ffshow. Those who have experience with installing this stuff should have no problems. Notice that SetMTMode(3,5) is just for 4 thread computers, if you have 8 or more I think it should SetMTMode(3,10) or SetMTMode(3,9). I don't really know - investigate that. Also, you'll see that num2 and num1 is set to get 60 fps for 23,976/25/24/30 fps movies. Adapt it if you have like 72hz monitor/projector. Oh, and one more point, I use CPU for decoding instead of GPU, coz my GPU is busy with madVR renderer. So if you have a fast GPU you can change the and remove the finest=F part and use "libflowgpu.dll" instead of "libflowsse.dll"
Also, the directory below might not be the same in your computer as it is in mine.
svp_flow_lib="C:\Program Files (x86)\Avisynth 2.5\plugins\libflowsse.dll"
Enjoy.
svp_scheduler=true
svp_cache_reduce=true
SetMemoryMax(1280)
SetMTMode(3,5)
ffdshow_source()
SetMTMode(2)
super=MSuper(pel=2, hpad=6, vpad=6, rfilter=4)
F=MFinest(super)
back=MAnalyse(super,isb=true, overlap=4, overlapv=4, lsad=1000, lambda=4000, blksize=16,blksizev=16, search_coarse=3, plevel=1, pelsearch=2, search=3, searchparam=2, badrange=-24,badSAD=8000)
forward=MAnalyse(super,isb=false, overlap=4, overlapv=4, lsad=1000, lambda=4000, blksize=16, blksizev=16,search_coarse=3, plevel=1, pelsearch=2, search=3, searchparam=2, badrange=-24,badSAD=8000)
num2=1
den2=1
Framerate<=30 && Framerate>=29 ? Eval("""
num2=2
den2=1
""") : Framerate<=24 && Framerate>=23 ? Eval("""
num2=5
den2=2
""") : Framerate<=25 && Framerate> 24 ? Eval("""
num2=12
den2=5
""") : NOP
MSmoothFps(super, back, forward, finest=F, num=FramerateNumerator(last)*num2, den=FramerateDenominator(last)*den2, algo=13, block=false, sadgamma=0.5, sadml=160, blend=true,thSCD2=155)
SetMTMode(1)
smegatron likes this.
Domas4 is offline
post #1963 of 1969 Old 04-09-2013, 12:11 PM
smegatron's Avatar
Hay, thanks for the script.
I too still use mvtools.
Your script does help with ghosting.
I did not update any binary's though. I have been having problems with missing frames and some of the later updates.
My script, ruining on an i7 3770K at 50% load 1080p. Powerful gpu is reqired for fft3dGPU.
denoise=2
sharpen=1.5
threads=22
multinum=5
multiden=2
algo=23
block=false
ml=0
search=3 #search type
dist=1 #search distance
sadml=160
sadgamma=0.5
blend=true
pel=2
sharp=0
blkh=16
blkv=16
blkh2=8
blkv2=8
overlap=4
overlapv=4
dct=9
SetMemoryMax(2048)
svp_scheduler=true
svp_flow_lib="C:\Program Files (x86)\AviSynth 2.5\plugins\libflowgpu.dll"
SetMTMode(1,threads)
ffdshow_source()
SetMTMode(5)
fft3dGPU(plane=0,sigma=denoise/8,sigma2=denoise/4,sigma3=denoise/2,sigma4=denoise,precision=2,mode=1,sharpen=sharpen)
SetMTMode(3)
gradfun2db(2)
SetMTMode(2,threads)
S = MSuper(pel=pel, hpad=16, vpad=16, rfilter=4)
F = MFinest(S)
A = MAnalyse(S,isb=true, blksize=blkh, blksizev=blkv, overlap=overlap, overlapv=overlapv, search=search, searchparam=dist, pelsearch=dist, plevel=1, dct=dct, lsad=1000, lambda=4000, search_coarse=3,badrange=-24,badSAD=8000)
B = MAnalyse(S,isb=false, blksize=blkh, blksizev=blkv, overlap=overlap, overlapv=overlapv, search=search, searchparam=dist, pelsearch=dist, plevel=1, dct=dct, lsad=1000, lambda=4000, search_coarse=3,badrange=-24,badSAD=8000)
C = MRecalculate(S,A, chroma=false, blksize=blkh2, blksizev=blkv2, overlap=int(overlap/4)*2, overlapv=int(overlapv/4)*2, search=search, searchparam=dist, dct=dct, lambda=4000)
D = MRecalculate(S,B, chroma=false, blksize=blkh2, blksizev=blkv2, overlap=int(overlap/4)*2, overlapv=int(overlapv/4)*2, search=search, searchparam=dist, dct=dct, lambda=4000)
num2=1
den2=1
num2=2
den2=1
num2=5
den2=2
num2=12
den2=5
""") : NOP
MSmoothFps(S, C, D, finest=F, num=FramerateNumerator(last)*num2, den=FramerateDenominator(last)*den2,algo=algo, ml=ml, sadml=sadml, sadgamma=sadgamma, block=block, blend=blend, thSCD2=155)
SetMTMode(1)
smegatron is offline
post #1964 of 1969 Old 08-22-2013, 09:03 PM
Joloch's Avatar
Hey guys, do you know which script works nice with my laptop?
CPU: AMD Vision E1-1200 (dual core)
GPU: AMD Radeon HD 7310
RAM: 6GB
Thanks in advance!
Btw, I use KMPlayer, I've obtained better results than using MPC, but video still too slow althought I tried several scripts D':
Joloch is offline
post #1965 of 1969 Old 09-14-2013, 12:54 PM
batista11b5's Avatar
pumpppppppp
batista11b5 is offline
post #1966 of 1969 Old 10-06-2013, 11:12 AM
supra297's Avatar
Hi, I've read this thread and am still confused since everything is so outdated. Is there a newer way to do this still?
I'm a complete noob and have never used any of these programs before.
But I did manage to find and install all the apps but I'm not sure how to use them. I know MT.dll is no longer needed as avisynth 2.6 already incorporates multi threading?
I know it's asking a lot, but can someone please post a complete walkthrough with the most current method to interpolate?
I'm running a i7 920 @ 3.8ghz on a EVGA x58 SLI and 2x GTX 285's hooked up to a Acer HN274H 120hz monitor.
Any help in the right direction is appreaciated.
supra297 is offline
post #1967 of 1969 Old 10-06-2013, 03:17 PM
Stealth5325's Avatar
Hi Supra,
I personally am using the SVP project now. www.svp-team.com
It's the newest version of this kind of tech, all setup for you and it makes custom scripts.
Search for 'SVP' around here and you'll find lots of info.
Hope this helps.
Stealth5325 is offline
post #1968 of 1969 Old 10-06-2013, 05:05 PM
supra297's Avatar
SVP project is exactly what I need. Thanks a ton Stealth!
Stealth5325 likes this.
supra297 is offline
post #1969 of 1969 Old 09-12-2016, 12:39 PM - Thread Starter
Bahn Yuki's Avatar
Quoted: 193 Post(s)
Liked: 112
Send a message via AIM to Bahn Yuki Send a message via MSN to Bahn Yuki Send a message via Yahoo to Bahn Yuki
A friend of mine reminded me of this, talk about a blast from the past.
JVC RS400, Denon X6300H, Klipsch RP-280F x 2, RP-450C, RB-51 II x 2, RS-42 II x 2, RB-41 II x 2, R-150M in 7.1.4, 180" Painted wall
LG 65C7, Denon X4300H, Klipsch RF-26 x 2, RC-52 II, Onkyo speakers in 5.1.4 setup
TCL 55P605, Onkyo 636, Theatre Research bi-amp tower speakers in 3.0 Setup
Vizio D40u-D1, Klipsch 2.1 THX certified speakers, Xtension Pedestal Sit Down cabinet
Bahn Yuki is offline
Reply Home Theater Computers
