XP Pro SP3, any issues or problems? - AVS Forum
post #1 of 6 Old 05-08-2008, 11:42 AM - Thread Starter
Jetlag's Avatar
I've downloaded but not yet installed the whopping 316.4MB SP3 for Windows XP.
I have not read much about any horror OR success stories yet and was wondering what your experience has been?
The only negative I have seen is issues with some partitioning software, but no specifics.
What can you share about your experience with service pack 3?
Jetlag is offline
post #2 of 6 Old 05-08-2008, 12:09 PM
dabish's Avatar
I'm on Vista for all 4 PC's in my house BUT I loaded a new machine for a friend last week and immediately put SP3 on it. He has not experienced any negative effects in a week so far. Not exactly a long test but so far so good. I have NOT loaded it on any of my company pc's yet.
dabish
dabish is offline
post #3 of 6 Old 05-08-2008, 12:12 PM
nm88's Avatar
No difference for me.
nm88 is offline
post #4 of 6 Old 05-08-2008, 12:30 PM
siege911's Avatar
When I first installed it, I had some quirks but it wasn't on a HTPC, just my laptop. Seemed to freeze oddly when I'd right click. It only did that the first day I had it installed. After a few days, I haven't really noticed a difference. I was told there would be speed increases but nothing noticeable on my laptop.
siege911 is offline
post #5 of 6 Old 05-08-2008, 03:41 PM
bastafidli's Avatar
yes, some applications that put icons into task bar notification area have little issue, the icon is sometimes there and sometimes not (skype, symantec antivirus, etc.)
bastafidli is offline
post #6 of 6 Old 05-08-2008, 03:51 PM - Thread Starter
Jetlag's Avatar
Heck that already happens to me without SP3!
Jetlag is offline
Reply Home Theater Computers
User Tag List
