ATI Radeon HD 4600 & 4800 series support 7.1 channel HDMI audio! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 2819 Old 05-26-2008, 10:14 PM
mcnabney's Avatar
Originally Posted by ToTTenTranz View Post
Another confirmation of the 4800's HDMI 7.1 channel support:
http://www.tomshardware.tw/549,news-549.html
In one of the slides there's the following statement:
- Built-in HDMI with 7.1 surround sound support
The newly released pictures of the cards show two DVI ports and an S-video. Do they use some kind of DVI to HDMI adapter? I got confused because I didn't think that the DVI connector had space or the capability for audio.
mcnabney is offline
post #92 of 2819 Old 05-26-2008, 10:17 PM
SpHeRe31459's Avatar
Quoted: 16 Post(s)
Like all the HD 2x00 and 3x00 series before it, there is special DVI port on the card that is also HDMI compliant and carries audio over unused pins of the DVI port when combined with ATI's proprietary HDMI adaptor (typically included in the box).
And that's not S-video, that's a 9-pin port that can be either s-video, or component video, just to be clear.
SpHeRe31459 is offline
post #93 of 2819 Old 05-26-2008, 10:22 PM
jimwhite's Avatar
There are no extra pins for the audio... maybe a shorted pair to indicate presence, but the audio is multiplexed into the video signal...
Jim
Jim White
St. Petersburg, FL
jimwhite is offline
post #94 of 2819 Old 05-26-2008, 10:23 PM
Quoted: 16 Post(s)
Jim
true story, I wasn't thinking clearly, the extra pins simply detect the presense of the ATI HDMI adapter, since it's been proven generic adapters don't provide an HDMI audio signal when attatched to the DVI port.
post #95 of 2819 Old 05-26-2008, 10:30 PM
hlkc's Avatar
Jim
When I saw the picture form Taiwan Tom's Hardware this afternoon, I have the similar question myself... Today, all 2XXX and 3XXX with gray ATI dongle, we can have 2 channel SPDIF output audio. If that is the picture for the 4XXX in tom's hardware, so HDMI 7.1 support means we need to use similar dongle too. So we might not getting a true bitstreaming 7.1, right? Or this kind of dongle can do bitstreaming 7.1?
hlkc is offline
post #96 of 2819 Old 05-26-2008, 10:36 PM
tsb
tsb's Avatar
that's a big disappointment
no upgrade from my 2600XT until they have pure HDMI 1.3 output via a dedicated HDMI chipset fully 1.3a compliant
tsb is offline
post #97 of 2819 Old 05-26-2008, 10:43 PM
Quoted: 16 Post(s)
Well again, it's really about what's going on inside the GPU, yes the older models only had a basic connection for their integrated audio codec, the slides for the 4x00 series imply ATI woke up and did a proper 8-channel implimentation. The dongle itself isn't the limitation.
No it might not do bitstreaming, but nothing from the PC can so far, what it can do is sent multi-channel PCM, which is basically the same, you simply have the player software doing the decoding before sending it over HDMI.
post #98 of 2819 Old 05-26-2008, 11:12 PM
hlkc's Avatar
I am not 100% sure what you mean.
So let's assume this 4XXX is not bitstream but what you are saying is, it might do 7.1 LPCM and with PDVD with just regular LPCM receiver the out come will be about same as bitstream 7.1 to lossless receiver, is that what you refer to?
hlkc is offline
post #99 of 2819 Old 05-26-2008, 11:43 PM
Quoted: 16 Post(s)
yes.
post #100 of 2819 Old 05-26-2008, 11:55 PM
hlkc's Avatar
yes.
Thank you. I was under the impression that this 4XXX is at least can do that, 7.1 LPCM. So with luck we can have bitstream 7.1.
Btw, I have about 50+ BD title. I noticed if they offer loseless, they are 5.1 loseless TureHD. So how do they go but doing 7.1 LPCM or 7.1 bitstream to 5.1 loseless?
hlkc is offline
post #101 of 2819 Old 05-27-2008, 01:27 PM
Quoted: 16 Post(s)
The 7.1 in the specifications of the Radeon, just mean it can transport up to 7.1 channels. It can send 5.1 as well. It will send through whatever number of channels it gets from a player application.
post #102 of 2819 Old 05-27-2008, 01:41 PM
ajamils's Avatar
I'm kinda confused about one thing....lets say that I get a 780G mobo (Gigabyte GA-MA78GM-S2H) right now and in future, if i decide to do HD audio, I can just upgrade the video card to HD4800 ?? Or will I need to change sound card / mobo too ?
[color=Blue]
psn id: hunter4life
Live Gamertag: huntre4life (notice "re" not "er" in hunter)
ajamils is offline
post #103 of 2819 Old 05-27-2008, 02:27 PM
Quoted: 16 Post(s)
No you just drop in the Radeon and have it take over, it should disable the onboard video.
post #104 of 2819 Old 05-27-2008, 02:35 PM
ajamils's Avatar
i understand the video part........ my question was about the audio.
[color=Blue]
psn id: hunter4life
ajamils is offline
post #105 of 2819 Old 05-27-2008, 02:58 PM
hlkc's Avatar
Hi SpHeRe31459,
Question about LPCM - let's assume we can only do 7.1 LPCM in 4XXX, how do we send it from HTPC/PDVD8 to receiver? Analogue 8 mini-RCA or SPDIF? Can we do HDMI 1.3b via LPCM?
hlkc is offline
post #106 of 2819 Old 05-27-2008, 03:00 PM
hlkc's Avatar
The audio will output from the DVI 4XXX port via using ATI dongle, same as current 2XXX and 3XXX series.
hlkc is offline
post #107 of 2819 Old 05-27-2008, 04:31 PM
Quoted: 16 Post(s)
Hi SpHeRe31459,
Huh? You use HDMI. HDMI carries 7.1 LPCM, it's been in the specs since HDMI 1.0. Remember, LPCM = raw/uncompressed digital audio.
Analog is analog, in other words it is LPCM converted to analog via a sound card's DACs. And S/PDIF doesn't have the bandwidth to support 7.1 LPCM.
post #108 of 2819 Old 05-27-2008, 04:33 PM
Quoted: 16 Post(s)
As hlkc said the add-in card does the audio too. You might be missing a piece of information: all Radoen HD 2x00, 3x00, 4x00 and related chipsets (780G) have an integrated sound device right in the GPU. So what you're disabling is the GPU on board (780G) so the HDMI sound should disabled with it and the new 4x00 card's HDMI audio support takes over.
post #109 of 2819 Old 05-27-2008, 05:22 PM
hlkc's Avatar
I have both HDMI 1.3b from my HTPC 3650 GC now and SPDIF from MB if need. I am not sure how to output 7.1 LPCM. Do you mean if 4XXX can output 7.1 LPCM then I can simply use HDMI output 7.1 LPCM from 4XXX via ATI grey dongle to receiver, exactly like what I have today with my 3650, right?
hlkc is offline
post #110 of 2819 Old 05-27-2008, 05:58 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
ding ding ding.
yeah that's the point integrated 7.1 HDMI audio from the GPU HDMI output.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #111 of 2819 Old 05-27-2008, 06:06 PM
Davinleeds's Avatar
Guess it would have Protected Video/Audio Path PAVP enabled in it's driver /Qimonda GDDR5. I guess it would enable the one connection "HDMI" cable to your receiver. The XP and Vista note needs deciphering as I don't think XP can do PAVP. But I'm saving my money now cause this could be a non mother board solution.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
post #112 of 2819 Old 05-27-2008, 07:01 PM
hlkc's Avatar
Originally Posted by sotti View Post
ding ding ding.
thank you scotti,
let's hope the best - 4XXX will able to do bitstreaming but at least we know that it will do 7.1 LPCM. I already change my set up and using all HDMI 1.3b cables from my SAT to HTPC instead of DVI and SPDIF before. Either way I will get 4XXX as soon as release and do LPCM at the minimum. Btw, I am playing BD using PDVD8 and use AC3/DTS pass thru today and it sounds better than my SPDIF set up before. Can't wait the LPCM or bitstream lossless audio!
hlkc is offline
post #113 of 2819 Old 05-31-2008, 07:20 PM
archer75's Avatar
Quoted: 187 Post(s)
Liked: 73
I hope they come out with a lower end model soon. I don't need the gaming power. Just the 7.1 HDMI and something smaller that uses less power.
Nvidia Shield Android TV, 2x Roku 3's, 1st and 2nd gen chromecast, Amazon Fire TV stick 2nd gen, Apple TV 4, Vizio M602i-B3, LG OLED65B6
Retired - HTPC: Intel e6300 2.8ghz, Intel DG45ID, 2gb DDR2, Radeon 5570, MCE IR receiver, Yamaha RX-V663 receiver via HDMI, panasonic ax100u, 145" S-I-L-V-E-R painted screen,
archer75 is offline
post #114 of 2819 Old 06-01-2008, 12:14 PM
MikeSM's Avatar
MikeSM is offline
post #115 of 2819 Old 06-01-2008, 12:52 PM
hlkc's Avatar
Originally Posted by MikeSM View Post
More confirmation: http://www.fudzilla.com/index.php?op...=7626&Itemid=1
But it did not say anything it rill be PCM or bitstream...
hlkc is offline
post #116 of 2819 Old 06-01-2008, 03:14 PM
MikeSM's Avatar
True. But we'll know very soon. The 4850 should be available for purchase in 2 weeks...
MikeSM is offline
post #117 of 2819 Old 06-01-2008, 03:15 PM
benbell's Avatar
I am yet to see any confirmation whatsoever that these new cards can bitstream or even pass 8ch LPCM.
benbell is offline
post #118 of 2819 Old 06-01-2008, 03:32 PM
hlkc's Avatar
Shouldn't be one way or the other if they official indicated that it will able to do 8 channels audio?
hlkc is offline
post #119 of 2819 Old 06-01-2008, 03:37 PM
hlkc's Avatar
I am not sure mid-June launch date any more... why? if a product is going to release in retail market in 2 weeks, we should know all the details by now. But we couldn't even know what these card can or can't do today. As a potential end user, of course I wish I will see this card in my hand 2 weeks and let's hope it is the case and more importantly bit stream 8 channels is what I really hope so now
hlkc is offline
post #120 of 2819 Old 06-01-2008, 04:07 PM
ymarker's Avatar
Quoted: 27 Post(s)
I'd buy it and replace my nvidia 880gtx if it can atleast do LPCM on 6/8 channels. If it can bitstream that'd be just great.
The other (non-mobo) option is one of the HDMI audio cards by asus/auzentech whenever they come out finally.
ymarker is offline
Reply Home Theater Computers
