Q6600 and 8800GTS 320MB able to play 1080p? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 05-19-2008, 04:47 PM - Thread Starter
FordGT's Avatar
I'm in the process now of building a new system. One of it's purposes is to be able to play back HD content. I'm sort of limited in my budget but I'm trying to get the best parts I can afford. Right now I've settled on getting a Q6600, either the Gigabyte DS3L or DS3R, 4GB of DDR2 800 memory and Vista Home Premium 64-bit along with an Antec 500W power supply.
I plan on getting a blu-ray drive in the future but would like to be able to play web/HDD based HD content now like Apple's movie trailers, etc. You may have seen the recent drop in price of the 8800GTS 320MB cards. I picked one up for $87.98 shipped and was hoping to use that. However, the lack of PureVideo HD 2 gives me second thoughts. I'm not a big gamer at all but wanted something powerful enough to play most games. The 8600GT is around the same price but isn't nearly as powerful as the 8800 series cards. My question is whether or not the 8800GTS 320MB G80 will be sufficient enough for 1080p playback? I can always upgrade my graphics card in a year or so but would it be OK for now?
FordGT is offline
post #2 of 19 Old 05-19-2008, 06:56 PM
hdtv00's Avatar
Quoted: 131 Post(s)
Liked: 72
You could probably go with no video card and the pure power of the quad core 6600 will work just fine on its own. Only thing I've question is using Vista 64bit, that's where you're more likely to run into real issues.
Marantz 7702MKII/Outlaw 7140 65" 4k Samsung KS8000
i7 4770K/16 gig 2133/970's SLI 840 PRO SSD
Paradigm Studio v3 100/570/20's/2200 Sub
hdtv00 is offline
post #3 of 19 Old 05-19-2008, 07:46 PM
Metric's Avatar
Quoted: 182 Post(s)
Liked: 57
im running a q6600 and an 8800gt, i can rip a br, remux a br and playback a ripped br at the same time and my cpu barely breathes.
I want to die in my sleep like grandpa... not kicking and screaming like the people in his car.
FS: Sony 40ES with UH-380
FS: New Xbox One S
Metric is offline
post #4 of 19 Old 05-19-2008, 07:51 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
The 8800GT has the G92 core, and has hardware acceleration, the 8800GTS 320 does not. In fact, the 8600GT would probably be a better choice for HD playback than the GTS, unless gaming was in the cards.
jdcrox is offline
post #5 of 19 Old 05-19-2008, 07:55 PM - Thread Starter
FordGT's Avatar
What do you guys think about the ATI HD3650 or 3850? I've heard ATi has better image quality than nVidia and either one of those should play most games OK. I would really like a 8800GT which I think uses nVidia's newer PureVideo HD 2 chip but it's nearly $100 more than I have to spend on a video card right now.
Good to know the Q6600 is up to the task though!
FordGT is offline
post #6 of 19 Old 05-19-2008, 08:44 PM
Bobby Blaze's Avatar
Are a Q6600 and 8800GTS enough for BR playback? If they aren't then who exactly is playing them on a PC?
Bobby Blaze is offline
post #7 of 19 Old 05-19-2008, 08:57 PM
nm88's Avatar
My Q6600 only uses 15% CPU to play HD/BD discs in full software mode (no acceleration), best quality with PowerDVD.
nm88 is offline
post #8 of 19 Old 05-20-2008, 12:20 AM - Thread Starter
FordGT's Avatar
I just got the shipping email. I guess even if the 8800GTS 320MB doesn't decode blu-ray that well my Q6600 should do the job just fine anyway.
FordGT is offline
post #9 of 19 Old 05-20-2008, 03:24 AM
ENDContra's Avatar
Sorry for the thread hijack, but somewhat related...how would an E8400 do with BD playback? Should I look at a graphics card or will I be good with just the processor and a decent motherboard with onboard graphics?
ENDContra is offline
post #10 of 19 Old 05-20-2008, 05:56 AM
Xylon's Avatar
Yes.
Xylon is offline
post #11 of 19 Old 05-20-2008, 06:03 AM
trailergod's Avatar
Q6600 is more than enough.... and you can even overlclock easily to 3.6Ghz @ 1600Mhz FSB ..... thats having 4 CPU cores @ 3.6Ghz and most players are multi thread capable....
nm88 ...i"m wondering.... how do u frce powerdvd not to use your video cards acceleration ?
trailergod is offline
post #12 of 19 Old 05-20-2008, 07:20 AM
Metric's Avatar
Quoted: 182 Post(s)
Liked: 57
True but i often run HA off; the q6600 is a great chip.
FS: New Xbox One S
Metric is offline
post #13 of 19 Old 05-20-2008, 07:36 AM
arfster's Avatar
A Q6600 could probably play four h264/vc1 Bluray movies simultaneously even without a graphics card helping :-)
arfster is offline
post #14 of 19 Old 05-20-2008, 10:52 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
You don't even need a quad core, I have an 8800/GTS 320 and it works fine with a 6800 dual core.
JDLIVE is offline
post #15 of 19 Old 05-20-2008, 01:09 PM
nm88's Avatar
XP + pre-HA (162.18) Nvidia drivers.
And while 3.6 overclocks are certainly possible on the Q6600s, I wouldn't call it "easy". With current steppings, 3.2 is a fairly safe bet though.
nm88 is offline
post #16 of 19 Old 05-20-2008, 02:52 PM
Metric's Avatar
Quoted: 182 Post(s)
Liked: 57
Sadly my mobo is bios locked for overclocking but stock 4 cores at 2.4ghz as mentioned above is a great chip for full software decoding. I guess your answer OP is yes, your setup is more than able, even overkill to some degree.
FS: New Xbox One S
Metric is offline
post #17 of 19 Old 05-20-2008, 03:58 PM
XxDeadlyxX's Avatar
Yep, Q6600 is an awesome processor and I'm very glad I bought it
XxDeadlyxX is offline
post #18 of 19 Old 05-20-2008, 04:47 PM - Thread Starter
FordGT's Avatar
I probably would have went with the E8400 too if I didn't do a lot of Photoshop/Dreamweaver work as well as video editing(not a lot but some). I figure 4 cores should last me a few years until I upgrade to Nehalem.
The graphics card is on its way here, the PSU should be shipping soon and I'll be ordering the Q6600 and motherboard soon as well. I'm really excited to get building!
Thanks for all the assurance guys!
FordGT is offline
post #19 of 19 Old 05-20-2008, 04:52 PM
nm88's Avatar
Don't worry, you'll love the Q6600.
And I see it's only $219 now at Newegg, what a steal.
nm88 is offline
Reply Home Theater Computers
